Old Feb 21, 2012, 12:08 PM
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
Originally Posted by markus123456 View Post
This is a so called pot antenna. It's a form of a dipole. The outer metal cylinder you refer to is one of the poles. Soldering the legs to it is a big no no. What you can to to gain some of the cable is unsoldering it and the solder the legs to the mesh that is below the cylinder.
HTH
Markus
Thank you Markus...secretspy711 and Eastcoast78...
Cylinder will be removed before soldering legs.
Before attempting,the length of the mesh shield from the connector to the top of the cylinder is 65mm,is that an acceptable length for the cloverleaf to be from the connector?
I did read....http://www.rcgroups.com/forums/showp...&postcount=936
So i'm guessing (would like some confirmation) that this cable should be long enough.
This will be a 5.8Ghz antenna.
Ridgewalker
ridgewalker is offline Find More Posts by ridgewalker
Old Feb 21, 2012, 12:31 PM
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Ridgewalker
6cm is safe. The wavelength is around 5.1cm which is the minimum not to be within the so called nearfield.
Markus
markus123456 is online now Find More Posts by markus123456
Old Feb 21, 2012, 03:38 PM
Opt
New Zealand, Auckland
Joined Oct 2010
I just did a quick test on my newly built cloverleaf measuring the 500 mw vtx current.
I built it for lawmate channel 8 (2510 mHz). Channel 8 drew about 40 mA more than channel 1. But so did the stock whip, and the CL drew exactly the same current as the stock whip... I guess I didnt build it quite right, but I will try it anyway and hope it is close enough!
Opt is offline Find More Posts by Opt
Old Feb 21, 2012, 04:52 PM
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Cant find any link to cross hair antenna, help, help :-)
PLS
nakelp86 is offline Find More Posts by nakelp86
Latest blog entry: New (old) Disco gimbal
Old Feb 21, 2012, 04:59 PM
United States, NC, Wilmington
Joined Aug 2011
Go to FPVLab.com its on there not here.
MASHTON is offline Find More Posts by MASHTON
Old Feb 21, 2012, 05:07 PM
Nakelp
nakelp86's Avatar
Joined Sep 2004
Thx, no wonder I cant find anything LOL
Thx again
Old Feb 22, 2012, 05:34 PM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
My first 5.8ghz CL ... thx alex
octane81 is offline Find More Posts by octane81
Old Feb 22, 2012, 09:32 PM
readyman's Avatar
Joined Dec 2011
Markus or IBCrazy,
If I were to experiment with a thin film antenna of this CL design. What would be the best trace width, and would it differ for the different frequencies? And how 'sharp' a corner if I can print perfect right angles? I have some special 'fold away' requirements. I intend to keep the geometry intact.
From looking at your pictures, I get the impression that this CL whilie not the most beautifull one I ever saw should work. What caught my atention though is how close the camera is to the antenna. From the size (hard to judge on a pciture only) it looks like your on 1280Mhz right?
You must know that CP antennas, especially when made with thicker wire and not so sharp bends are fairly wideband. So it could be that the antenna intercepts EMI that comes from the camera or more likely the other way round?
Just a thaught. You could try to find this out by takeing the components out of the plane and do ground tests with them much more seperated, eventually even by carfully packing the camera into aluminium foil.
Could you try to quantify what you expected and how it performed?
Markus
readyman is offline Find More Posts by readyman
Old Feb 23, 2012, 12:12 AM
multi rotors,foamies,car lover
windfou's Avatar
Joined Dec 2008
It should be better in close range, eventually not reaching out the same (but not dramatically less). However, at that frequency (asuming you use a 500mW tx) you should get way more range with both antenna setups. So, eventually your area where you fly is very very polluted (high noise floor) or something else is not ok. CP antennas, especially helicals, pick up more signals from other frequencies than linear antennas, stuffing your receivers input stage thus lowering sensitivity by a great deal which could explain the phenomeon.
Now that I'm fully awake (tuff night behind me ) I don't think it's interference. How about flying your setup in a more rural area just to know if things are improved dramatically?
Markus
Dear Markus,
last summer i purchase from readymaderc theses antenna:http://www.readymaderc.com/store/ind...roducts_id=459
this antenna combined with fatshark and immersion rc 600mw was used for my quadcopter fpv . but since i have a crash i used my stock antenna 5.8ghz and i get better range around house and tree can you explain me why ? i don't say your 60$ antenna doesnt work but what happening if my signal decrease or out of range with the stock antenna and bluebeam ? blue screen ? thanks
windfou is offline Find More Posts by windfou
Old Feb 23, 2012, 01:13 AM
Registered FPVer :)
Joined Aug 2006
Originally Posted by windfou View Post
Dear Markus,
Ok, these are not "my" $60 antennas I'm not Alex. I charge $20 per antenna. So much about that.
These antennas should be used with a coax extension cable. If you mount them as is, the nearby rx or tx will violate the near field of the antenna, changeing it's radiation pattern significantly.
Wether they work well or not also depends on many factors. As a matter of fact, CP antennas on 5.8G - provided the individual antenna is not defective and well built and tuned - outperform linear antennas easily. However, if an antenna is not well built, bent, defective or mistuned, performance might be very poor. Those antennas, based on the wire thickness are obviousely delicate and one must take care not to bend them. You should asume that antennas you get fullfil the other requirements (well built, no dents, tuned). If not, this is IMHO a waranty kind of situation. I can only speak for myself but I figure Alex and Hugo also take their work seriousely. If one of my customers gets a not well performing antenna, he will get a free replacement. If the plane crashes and the antenna gets dented (or get's dented while handling it) one can send me the antenna for repair at the cost of the return shipping fee provided the antenna is not totally smashed.
I suggest you contact either redymaderc or Alex about that.
Regarding the general performance of CP antennas over linear ones I can say that CP antennas have two significant advantages. Advantage number one is that they almost totally cancel out reflections. Reflections are very very common the higher the frequency is. In fact, frequencies around 5Ghz and up are often used for radar applications because they DO reflect so well. Every reflection of the signal that arrives at the receiver antenna will cause an interfrenence in the receiver leading to a disorted signal / picture. Advantage nuber two is that CP antennas almost do not depend on the positioning of the receiver and transmitter antennas compared to each other. Linear antennas HAVE to be alligned for best performance. If they are "crossed up" (in a 90 degrees angle to each other), you loose 12dB and in layman terms, that's more than 100 times less of the signal. Not so with CP antennas.
Other than this, linear antennas as well as CP antennas have to radiate (in case of the tx antenna) and receive the signal. Both do that equaly well. What I'm trying to say is that there are no "wonder antennas". There are antennas which are well adapted to a specific problem (like CP antennas for FPV where the plane banks and where we have reflections due to the frequencies used) and some which are not so well adapted (linear antennas are not good with banking and reflections). If we compare these antenna types, we must assume that such comparison is made with tuned antennas such that each antenna has a chance to truly radiate or receive. If this is not given (like it seems to be the case with the antennas you have) such a comparison is pointless.
Markus
Old Feb 23, 2012, 01:26 AM
Registered FPVer :)
Joined Aug 2006
Originally Posted by readyman View Post
Markus or IBCrazy,
Nice idea about the thin film. I belive half of the world is seeking a solution to mass produce such antennas at low costs. The problem I see with the thin film aproach is the drag such an antenna would create in the air and the obvious subsequent dynamic deformation.
Regarding your specific questions I can't tell you much as I'm lacking experiance with PCB based antennas. However, in general the thinner the wire (trace) the more narrowband the antenna will be, and the more important it becomes that it is well tuned.
If you want to take your developement seriousely, you IMHO have to invest into a vector network analyzer and go through numerous design / prototype cycles to find a good solution. Constantin A. Balanis book called "antenna theory" most likely contains information about PCB antennas along with probably any other aspect and theoretical information about antenna design.
HTH
Markus
Old Feb 23, 2012, 06:18 AM
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Got my bixler mostly setup I will be flying LOS with others watching/recording on the laptop until I have CP antennas
sammyc is offline Find More Posts by sammyc
Old Feb 23, 2012, 11:11 AM
windfou's Avatar
Joined Dec 2008
Markus
ok so depend the side i turn the aicraft i can lose lot of signal with my linear stock antenna but the cp antenna the patern is diferent and you lose less signal and not need to turn my head to reach the siganl ok thanks i want a set from you please pm me
Old Feb 23, 2012, 11:45 AM
readyman's Avatar
Joined Dec 2011
Thanks Marcus,
Has anyone experimented with 1/2 wave or 1/4 wave versions of the CL design? If a flyer just wants the omnidirectionality attributes but does not need to fly into the next country. This in order to scale down the physical size.
I've searched this thread but nothing comes up.
Markus or IBCrazy,
Old Feb 23, 2012, 12:27 PM
Registered FPVer :)
Joined Aug 2006
Thanks Marcus,
That's not possible. If you make the lobes to be 1/2 or 1/4 of the wavelenght, you actually end up with double (1/2 size) or four times (1/4 size) of the resonant frequency.
Markus
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 1968 Today 06:40 AM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 412 Jul 08, 2014 05:19 PM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 301 Jun 26, 2014 07:48 PM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
