Old Feb 07, 2002, 08:58 PM
goofeyfoot is offline
Find More Posts by goofeyfoot
North Carolina
Joined Jan 2002
Radio Question
I just bought a first radio which is a Hitech 5 channel.
I haven't even built one plane yet, but I did check the radio out to see if everything was working.
I followed all the directions and hooked up all the servos. They all go back and forth except for the one for the elevator channel. That one seems to just go one way. In other words, when you move the control in one direction, you get pretty good throw. But when you move the control in the other direction, not much wiggles on the servo.
I switched the servo motors on the receiver and every time, it is the elevator channel that is half dead. I zeroed out the trims.
Is the new radio defective?
Thanks for your help.
Michael
goofeyfoot is offline Find More Posts by goofeyfoot
Old Feb 07, 2002, 11:15 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Michael,
Is there any chance of substituting the receiver with a borrowed one, and trying it again?
tim
tim hooper is offline Find More Posts by tim hooper
Old Feb 07, 2002, 11:29 PM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
I don't know much about hitec radios (is this a flash 5?), but is it possible there is a travel switch set wrong? I know when I had a defective jr radio servos would do strange things (little travel in one direction, servo jitter at the end of travel in the other).
opualuan is offline Find More Posts by opualuan
Old Feb 08, 2002, 12:44 AM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
michael:
go to "epa", channel #2, and check that the percentage is the same when you move the stick up then down. example up=100%/down=100%. if you change the epa, you must change it in both directions.
if the radio is new and you haven't done any programing, then it sounds like a defect..................gregg
gregg f is offline Find More Posts by gregg f
Old Feb 08, 2002, 05:32 PM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Hi,
I know this may sound silly, but you dont have your elevator servo plugged into the throttle socket do you. I have a feeling that on Hitec gear the throttle servo is in the socket number three, which would in fact be elevator on most other sets.
Just a thought
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Feb 09, 2002, 03:02 AM
Silver is offline
Find More Posts by Silver
T-52 over Seattle
Silver's Avatar
Seattle
Joined Jun 2001
Michael,
The phrase you want to memorize is "Always Easy To Remember".
Channel 1 = A = Aileron
Channel 2 = E = Elevator
Channel 3 = T = Throttle
Channel 4 = R = Rudder
If your plane doesn't have ailerons, channel 1 is used for the rudder instead. The throttle channel should only move one direction from its resting position. Check the manual for the channel numbers. Connecting the wrong servo to a channel makes a plane very hard to control. (Don't ask me how I know. )
Silver
Silver is offline Find More Posts by Silver
Old Feb 09, 2002, 06:03 AM
North Carolina
Joined Jan 2002
Greg F's solution turned out to be the correct one. I had set the "EPA" on one side, instead of both. Thanks for the responses everyone.
Michael
Radio question TerryJW Power Systems 1 Jan 06, 2002 02:43 PM
Help! Radio Question - Help Buffett323 Parkflyers 9 Dec 10, 2001 06:48 PM
Old radio question dano287 Beginner Training Area (Aircraft-Electric) 2 Sep 21, 2001 02:52 PM
RADIO QUESTION.... GUAIO/USA Foamies (Kits) 1 Jun 16, 2001 02:02 PM
Heli Radio Question? airwolf Electric Heli Talk 16 Jun 11, 2001 04:46 PM
