Old Apr 18, 2015, 02:15 AM
mlmcquiggjr is offline
Find More Posts by mlmcquiggjr
Joined Dec 2005
Help!
DX18 is a $700 paper weight!
I've got a brand new DX 18 purchased from Horizon Hobbies and the throttle stick makes the aileron and elevator operate as if mixed to the throttle. No mixes have been made. The transmitter is a mode 2, and the right stick is useless. I have been through all the menus, and read the manual, nothing is mentioned to have it work like a normal radio. What's up?
mlmcquiggjr is offline Find More Posts by mlmcquiggjr
Old Apr 18, 2015, 02:27 AM
reverse is offline
Find More Posts by reverse
Joined Jan 2015
LOL
reverse is offline Find More Posts by reverse
Old Apr 18, 2015, 04:02 AM
Evan D is online now
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
In helo mode? Sailplane mode? Do you know what you're doing?
Evan D is online now Find More Posts by Evan D
Old Apr 18, 2015, 10:04 AM
freechip is offline
Find More Posts by freechip
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Start by erasing the model and starting fresh, check the servo monitor and see if all operates properly.
If it does then you know your previous model has some programming doing something.
If I'm default blank model it still does this then contact hh and have it serviced.
As for the comment for reverse, never mind him he's a troll and does nothing but troll in spektrum threads.
freechip is offline Find More Posts by freechip
Old Apr 18, 2015, 11:52 AM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Did you try to contact Horizon Hobbies ?
srnet is offline Find More Posts by srnet
Old Apr 18, 2015, 11:54 AM
Joined Dec 2005
I probably don't know what I am doing!
I loaded in a fresh copy of airwave, which turns off the registration nag. I loaded up a fresh heli mode model, aileron, elevator and throttle still coupled. I loaded in a fresh sail plane, aileron, elevator and throttle still coupled. I placed an inquiry to Horizon and am awaiting reply.
Old Apr 18, 2015, 02:39 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
The helo mode using normal 120 degree awash will move the three cyclic servos with throttle so that's normal. If you have a sailplane loaded and have crow on throttle stick it will move ailerons, flaps and elevator compensation. Sailplanes have the servos plug in a different order to the receiver so that may cause some confusion.
It sounds like it is doing what it's supposed to. Look at the monitor screen.
Load a airplane with no mixing and try that. If all else fails find a club member that knows radios and get a short tutorial. Where are you located?
Old Apr 18, 2015, 02:50 PM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Create a new Acro Model. If any of the primary control moves another control then you should send it in/back. There is something like warranty, and Spek's service is top.
Mukenukem is offline Find More Posts by Mukenukem
Old Apr 18, 2015, 04:33 PM
reverse is offline
Joined Jan 2015
what comment ?
Old Apr 19, 2015, 06:42 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
He could be a troll, but the title is right
renatoa is offline Find More Posts by renatoa
Old Apr 19, 2015, 09:17 AM
reverse is offline
Joined Jan 2015
there are hundreds of DX18 issues posts and could stay here trolling 24/7 like him with no life out of the screen but I don't need to waste my free time.
Old Apr 19, 2015, 10:04 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
You could be outside learning to ride your tricycle.
richard hanson is offline Find More Posts by richard hanson
Old Apr 19, 2015, 11:14 AM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
This kind of tricycle?
coriolan is offline Find More Posts by coriolan
Old Apr 19, 2015, 11:47 AM
reverse is offline
Joined Jan 2015
Electromagnetic is by no means a wrecktum fanboy I like people like him.
DX18 owner but unhappy. He writes what he really believes not what others want to read.
http://www.rcgroups.com/forums/showp...3&postcount=48
Old Apr 19, 2015, 03:24 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
He's also an unhappy DX8 owner, and apparently now (based on his posts) an unhappy Jeti owner.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Discussion TT 999 Front Fork Paper Weights or what ?? Victor Vector Motorcycles 8 Jun 14, 2007 09:17 AM
Discussion Heli-Max AXE EZ Paper Weight ermedic Coaxial Helicopters 7 Feb 27, 2007 05:48 PM
Rant Another Kokam paper-weight P-51 fan Batteries and Chargers 10 May 04, 2004 10:08 AM
Foam board...paper makes up over 58% of weight research_guy Foamies (Kits) 5 Sep 28, 2002 10:40 AM
