Old Apr 05, 2015, 10:01 PM
zeenon is offline
Find More Posts by zeenon
zeenon's Avatar
NJ
Joined Jul 2002
Immersion r/c 600mw and 12v camera
Folks,
I've read pages and pages of info here and on the other forums about hooking up a immersion r/c 600mw tx to a 12v camera (cs-600) and I'm not sure the best way. (Some posts are from 2013 so I'm not sure if something better came out since then).
I've seen use a 12v step up regulator between the 5v out/gnd of the immersion and the 12v out goes to the camera.
I've seen use a PNP50 which will give you the OSD and take care of your voltage issues.
I've seen just use a 'Y' off the battery(3S) since the camera supports 9v-12v.
What is the best sure fire method?
Z
zeenon is offline Find More Posts by zeenon
Old Apr 05, 2015, 11:09 PM
InFocus is offline
Find More Posts by InFocus
Joined Nov 2012
12v stepup (pololu) has worked great for me for almost 2 years now. No noise and easy to set up
InFocus is offline Find More Posts by InFocus
Old Apr 05, 2015, 11:20 PM
bansheerider is offline
Find More Posts by bansheerider
bansheerider's Avatar
United States, CA, Petaluma
Joined Feb 2014
This ^. Do not wire straight to the battery. Here is a good video on how to setup the 12v step up.....
ImmersionRC Transmitter Step-Up Regulator Wiring for 12v FPV Camera (10 min 36 sec)
bansheerider is offline Find More Posts by bansheerider
Sold Immersion r.c. 5.8ghz 600mw vtx with clover antenna viclick FPV Equipment (FS/W) 1 Jan 28, 2015 02:37 PM
Sold Immersion R.C. FPV SYSTEM (EZUHF DIVERSITY 8CH, TBS EZOSD, & 600MW 5.8 GHZ VTX viclick FPV Equipment (FS/W) 2 Jan 28, 2015 12:05 PM
Discussion Using a 12V camera with an Immersion 600mw 5v output VTX ALEX HEWSON FPV Talk 14 Apr 03, 2014 12:15 PM
Question R/C Gyro / flight stabilization on Fullsize camera ? pittsartist Aerial Photography 0 Nov 27, 2013 10:17 AM
Discussion Conversion of PC PSU to R/C battery charger PS - combine 12v rails razzda Batteries and Chargers 4 Nov 21, 2011 10:24 AM
