Old Nov 26, 2013, 11:19 PM
JohnM is offline
Find More Posts by JohnM
Lifetime Member
JohnM's Avatar
Providence, RI, USA
Joined Dec 1996
The future of the 1 cell Lipo planes
I was thrilled with the introduction of all the RTF 1 cell lipo airplanes as I could not have imagined this when I struggled and failed to complete the build of my Wespe kit many years ago.
I am amazed by the performance and simplicity of both my Champ and Night Vapor but have been getting less impressed with the performance of my SU-26 and SU-26xp airplanes. I am wondering if the single cell performance aircraft have reached their potential and cannot ever compete with the 2 cell lipo planes and the new standard has become 2 lipo cells.
I am curious to hear feedback on if there will be an increase in performance with 1 lipo cell or the new standard will be 2 lipo cells.
JohnM is offline Find More Posts by JohnM
Old Nov 27, 2013, 06:08 AM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
If a 1-cell brushless gearbox is ever mass produced we'll see a real increase in performance. As of now it's up to us.
I R Irv is offline Find More Posts by I R Irv
Old Nov 27, 2013, 06:20 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
2 cell just makes it easier to get the power out of the battery pack. To get more power would mean heavier packs.
GregG is offline Find More Posts by GregG
Old Nov 27, 2013, 07:02 AM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
There are even some 3 cell planes sneaking in to take part of the um market. The extra voltage just makes everything better. You just don't have much headroom with single cell voltage. It's so easy to drag it down to nothing.
bobly is offline Find More Posts by bobly
Old Nov 27, 2013, 08:59 AM
nopistn is offline
Find More Posts by nopistn
Joined Apr 2008
the 1s planes will probably always be for indoor use, vapors, as3xtras, ect.
nopistn is offline Find More Posts by nopistn
Old Nov 27, 2013, 11:46 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
1S is 'Fine' imo. A switchover to BL power will substantially increase performance sans the PITA and noises of a gearbox.
Only the RX board electronics need updating.. some already are now... like the later Flyzone ones :-)
Bare is offline Find More Posts by Bare
Old Nov 27, 2013, 12:29 PM
bobly is offline
Joined Sep 2010
I'm no expert for sure, but not sure about this - seems as though those in the know have pretty well settled on that there are currently no 1 cell brushless no gearbox setups out there that match the brushed/gearbox setups we currently have. It might happen down the line, but there are physical and electrical limitations that might prevent it from ever being practical. Just so much you can do with 3.7v.
Old Nov 27, 2013, 12:30 PM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
Ultra Micro Brushed Motor 8.5mm x 23mm by E-flite
lots of life left in 1s
Edit: just posted couple 1s beauties in ask21 flying far into the future
elvill is offline Find More Posts by elvill
Old Nov 27, 2013, 12:32 PM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
With present day technology it is very difficult to build a brushless motor with low enough Kv and adequate power output on a 1S system to drive a prop compatible with the Um aircraft..
There is just too much resistance in the motor windings.
This means that to go brushless on 1S, a gearbox will still be necessary for adequate performance.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Nov 27, 2013, 12:43 PM
Bare is offline
Canada
Joined Nov 2000
Perhaps.. But typical micro props are often wayyy overscale as well.
A few have found the HK 5 grammer to be a powerhouse on the late Cox warbirds
Here are a few candidates
http://www.hobbyking.com/hobbyking/s...tor_3_1g_.html
http://www.hobbyking.com/hobbyking/s...er_2000kv.html
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
The Hex 5 grammer can do a 5x3 handily likely bigger. But is it too heavy?
Certainly one could try to hunt up more that may be more model specific/suitable
Or then, as you say: fit a 10 or 12 mm Inrunner to a 'decent' gearbox.
Point being that IS ain't dying Just brushed versions may be at an end
1S ESC's:
http://www.hobbyking.com/hobbyking/s..._Version_.html
http://www.hobbyking.com/hobbyking/s..._3A_Mi_3A.html
Old Nov 27, 2013, 09:59 PM
Audioguru is offline
Find More Posts by Audioguru
Canada, ON, Mississauga
Joined Oct 2011
The tiny 1 cell brushed motors did not last long. The tiny 1 cell batteries the same.
2 cell brushless airplanes are wonderful.
Audioguru is offline Find More Posts by Audioguru
Old Nov 29, 2013, 05:59 PM
airfoil'd is online now
Find More Posts by airfoil'd
Joined Feb 2008
Looked at the Duet today. Those familiar already know its 1cell,direct drive, twin prop, differential thrust, elevator. If I wasn't "Brushophobic", it would have got my $60.
Apparently, its a great flyer. Haven't read about motor burnout on them, but assuming the eventuality, its innards would be harvested for a pusher install or build. The motors would be surface mounted for easy swaps, perhaps this 23mm variant? Basically, an old school AH/ITC format, with an elevator. Or maybe a delta with motors on the elevator, diff-thrust vectoring ? Or a canard, or both?
Sounds like fun experimenting, but also quite an involved process. And even after all that, it still wouldn't have the elevon control I would want.
Long story somewhat shortened: When the full-house 1cell DeltaRay is released, my Brushophobia will be overcome, and it can take my $100. Meantime, I avoided the whole 1cell gearbox thing because burnout complaints seemed to be more frequent in them than in their AH/ITC precursors, which were already frequent enough.
When the UM DeltaRay, and the pushers, do come out, if they're as small as , say, the AH F-18, I'd pay $120.
Incidentally, today my $60 went to an Aircore airframe for a 2cell brushless system, that will cost another $60, again $120.
I hope the future of 1cell lipo planes includes me putting my $ where my words are.
airfoil'd is online now Find More Posts by airfoil'd
Old Nov 29, 2013, 06:36 PM
OldRCNut is offline
Find More Posts by OldRCNut
Still Flying
OldRCNut's Avatar
United States, WI, Fond du Lac
Joined Mar 2013
1S is alive and we'll
I love my 1S um war birds from HH. The performance with an upgrade to the MSRX motor is great. The planes are small and light and will tolerate some rough landings.
Brushed motors require lubrication. If they are lubricated periodically they perform for several flying seasons. It then takes $10 to replace the motor. For people who are hobbyists that can work on their planes the combination of performance and cost is exceptional.
For others that are not as capable of repowering planes I agree that 2S brushless May be the way to go.
OldRCNut is offline Find More Posts by OldRCNut
Old Nov 29, 2013, 06:58 PM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Originally Posted by airfoil'd View Post
......When the UM DeltaRay, and the pushers, do come out, if they're as small as , say, the AH F-18, I'd pay $120.........
What size is the AH F-18?
Old Nov 29, 2013, 09:34 PM
Joined Feb 2008
...."challenging"..
AH: AirHogs. A search should easily yeild the size . I will post measurements later, my AH F-18 is in another building here. For now, its a little bigger than the earlier AH planes, if that helps.
Basically, as good as the current Hobby grade 1cell planes are, they are bigger than the Toy grade 1cell planes were that "Micro" used to refer to. And the planes on that slippery slope are getting bigger, like these Aircore planes. It would just be nice to see "Micro" pushed to stay small, or get smaller, instead of becoming a watered down term. Even if that means brushed motors.
edit:AH F-18 (approx)wingspan:11,3/8" length 14,1/2")
Question 1 bad cell in a 3 cell Lipo Mad Hungarian Batteries and Chargers 13 Sep 01, 2013 02:43 AM
For Sale Quattro plus 1-4 cell lipo charger $20 SHIPPED FlyJumper Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 08, 2013 12:29 AM
Wanted wanted 1 cell 70mah lipos Flyboy70 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 06, 2013 12:13 PM
Question NEU 1110/1y/6.7:1 on 4 cell lipo xrx1113 Power Systems 12 Jan 05, 2013 04:09 PM
For Sale Tiny 1 cell LiPo 170mAh and 340 mAh cells for micro/indoor planes shschon Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 19, 2008 10:47 PM
