Old Feb 01, 2013, 03:03 PM
Peejster is offline
Find More Posts by Peejster
United States, WA, Seattle
Joined Oct 2012
Engine failure so easily?
I have an Great Planes Rimfire 400 28-30-950 electric motor that I use on a Great Planes PT-19. The other day I landed with a bit too much speed and overshot my desired landing point. The plane landed ok but then hit a puddle in the field and nosed over. The plane wasn't sitting in the puddle but water definitely splashed water over the nose/cowl as far as the cockfit (my front seat pilot got a little muddy). I live in Seattle to the park fields get very soggy and often have puddles (the ducks love the fields this time of year) for months at a time.
Everything looked fine - controls worked, opened the battery hatch and the battery and receiver didn't have a drop of water on them - and I didn't see streams of water running down anywhere when I picked up the model.
Next day, went through pre-flight check and then applied throttle to arm the motor - everything was fine. Then ready for take-off and gave it some gas (so to speak). Motor didn't spin and light gray spoke came out of the nose and cockpit instead. I immediately lowered the throttle and opened the cockpit to get the battery out (my first thought was the battery). Battery looked fine so I packed everything up and headed home.
On the work bench, I saw black / burnt windings on the front of the motor. I decided to power up to see what would happen. Applied throttle - no spoke but still no spinning and a little noise from the motor.
Is it reasonable that a little water splashing on the engine would cause a mini-fire and smoke so easily?
Should I have proactively - i.e. using a hair dryer / heat gun - dried out the motor right away?
I also fly in a little bit of drizzle every day. If I waited for a sunny day, I'd only fly one a month between Oct and June. The drizzle / rain here is more of a constant mist rather than real water droplets. Should I not fly with so much moisture in the air?
Thanks all - still fairly new and trying to learn the constraints of the electronic equipment.
PJ
Peejster is offline Find More Posts by Peejster
Old Feb 01, 2013, 03:14 PM
cyclops2 is online now
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Tough call.
Water could have opened 1 of the 3 phases of the ESC.
Does the ESC have a stink or smell to it ? Did you wind up the motor during the day after pre-flight checkout ?
cyclops2 is online now Find More Posts by cyclops2
Old Feb 01, 2013, 03:16 PM
Joined Mar 2003
Water should not hurt the motor electrically. ESC ? yes.
Bearings can rust much later.
Old Feb 01, 2013, 03:32 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Maybe more of a dirt got in the motor problem causing it to bind and draw way too much current.
Water by itself should not hurt the motor with the exception of washing out the lubrication from the bearings.
hoppy is offline Find More Posts by hoppy
Old Feb 01, 2013, 03:35 PM
Peejster is offline
Joined Oct 2012
ESC seems fine. No stink / smell. No physical flaws. It's back in the plane now with a replacement engine (I had another one of the same engine in the parts bin) and everything is looking/working fine on the bench. I might take it out now to give it a fly.
The only indication of any issue - apart from the fact that the motor won't spin - is the blackness on some of the copper that I can see through the front of the motor.
Old Feb 01, 2013, 03:36 PM
Peejster is offline
Joined Oct 2012
Oh, and I also tried a different ESC with the original motor and the original motor still didn't spin with the other ESC.
Old Feb 01, 2013, 04:11 PM
Peejster is offline
Joined Oct 2012
Here is a pic of the motor.
Hoppy - that may be the case as the pilot had a quite a bit of dirt on him which I didn't really notice until the water dried.
Old Feb 01, 2013, 10:14 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Can you see scratches on the magnets and or stator segments? That's probably where the binding would occur.
Old Feb 02, 2013, 12:26 AM
Ron H is online now
Find More Posts by Ron H
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Was the throttle off during the nose over?
Ron H is online now Find More Posts by Ron H
Old Feb 02, 2013, 12:38 PM
Joined Mar 2003
I always have some throttle on during a landing into any wind.
So a blade stop is death to something or the parts are electrically over currented until I get to 0 power.
USE WET FUELS !!!!
Old Feb 02, 2013, 09:39 PM
Peejster is offline
Joined Oct 2012
There probably wasn't any throttle by the time it nosed over as it had a few feet of roll before that.
I'll see if I can get a better look at the motor to if there were any signs of debris or unusual resistance.
Last edited by Peejster; Feb 03, 2013 at 01:40 PM. Reason: changed wants -> wasn't
Old Feb 03, 2013, 04:48 AM
zeroback is offline
Find More Posts by zeroback
United States, FL, Pompano Beach
Joined Oct 2011
It's actually a motor. Big difference from an engine.
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
New Product SO MANY PLANES , so little money. hexonxonx Flying Wings 0 Jan 17, 2013 07:47 AM
Discussion Talon Failures RC Man Castle Creations 3 Jan 03, 2013 03:19 PM
Question NE Solo Pro V2: RX or TX failure? artvolk Micro Helis 0 Jan 02, 2013 02:26 PM
Discussion How Do I Simulate Single Engine Failure On Two Engine Plane? theleetbeagle Electric Plane Talk 14 Jun 09, 2011 07:05 AM
Discussion Wings break so easily...... Iranair Pusher Prop Jet Models 13 Feb 16, 2009 02:51 PM
