DW
I liked the color - looks like it was anodized. It is a Kryoln X Metals brand rattle can. Blue Anodized 2301 No special prep - just cleaned all the surfaces with a pro-level prep paint cleaner. Spray very light coats, until the desired color and coverage is archived. Believe it or not, the hatch cover in the previous picture is the same paint but over a white base color and many more coats. The mast and booms are of course aluminum and will yield a different result. I was amazed at how well it turned out! I got it at Wally World (Wal-mart) Boomer |
David
I know of a person on the forum that makes custom decals - here is her contact info. http://www.callie-graphics.com/ allie has done a lot of the cool graphics seen on many of the boats on the forum. Rick |
If you use a light coat of silver as the primer on the plastic parts they will look closer to what the boom looks like. FC |
Well, Not much accomplished on the Seawind build this weekend. I was able to apply a few more coats of base white to the top and bottom of the hull since installing the keel insert, sanding the epoxy and priming it.
Back to gloss white. I did get the rudder and steering wheel shafts painted, main threaded on the mast and rigged at the top. I am traveling this week so the base white will have time to cure before the color is applied later in the week. I will be printing a stencil on frisket and using an xacto to cut everything out. I am also going to try to add some fine adjustments to my main boom and jib boom later in the week. Will post photos next week. DW |
I got both of my mast's built and sails installed. The Stockmaritime custom sails are larger than the stock Seawind sails. Tough getting the chord threaded but after some manipulation, I threaded the main. The jib is wider so I purchased an aluminum tube that i will cut, drill and install extra rigging hardware I had.
Will install class letter and numbers next and drill new holes for rigging adjustments. DW |
Well, finally got the plexi cut, holes drilled and srew inserts for my waterproof hatch installed in the hull. I will need to order some closed cell foam from McMaster Carr this week and that will be completed. I am planning on airbrushing the underneath of the plexi in a faux carbon fiber pattern.
Waiting on my stencils to be cut from a local sign company so I can complete the paint job. I touched up the white base coat and will wet sand it again to smooth it and prep for color. Slowly getting it done. DW |
| Thread Tools | |
| Build Log Seawind Build Thread… First RC Boat | orthobill13 | Sailboats | 30 | Feb 10, 2012 08:22 AM |
| Discussion Seawind with onboard camera video. | ROLO1963 | Sailboats | 14 | Sep 15, 2011 01:14 PM |
| Discussion HobbyKing Seawind 800mm | sapok | Waterplanes | 0 | Sep 06, 2011 10:50 AM |
| Build Log R2Hobbies Seawind build | Dakrat | Waterplanes | 19 | Jul 02, 2009 08:56 PM |
| Discussion Seawind - build drawing/scheme? | richardmrazek | Electric Plane Talk | 1 | Jan 16, 2009 01:38 PM |
