Old Jun 11, 2008, 06:34 PM
Thermal seeker
Bohh33's Avatar
Brunswick, Ohio
Joined Jul 2005
Bob About Plan question
Hi all,
I'm looking to build a "Bob About" with the plans below and it says to scale the hull when printing it out to 12".
Which part of the hull is being referenced? The deck? The Bottom or the Hull sides?
If the sides - from what points do you measure as the edges are tapered?
Thank you,
-Mike
Bohh33 is offline Find More Posts by Bohh33
Old Jun 11, 2008, 07:21 PM
Joined Apr 2006
Unless someone answers back to you, try this:
Meaure the deck from bow to transom and scale it back to 11 7/8" or maybe a bit less. That should give you a finished hull of 12" or a bit less.
To double check, rescale, then cut out the patterns out of some cardboard, tape them together and you should get a rough idea if it will measure out correctly.
ROADTOAD is offline Find More Posts by ROADTOAD
Old Jun 12, 2008, 04:22 AM
micro yacht nut.....
micro sailor's Avatar
Joined Dec 2004
Hi there,
Thanks for considering my design
The length of the bottom panel is 311.5mm or 12.264 inches.
I can email cad files if that helps you out.
good luck with the building and sailing.
Brett
micro sailor is offline Find More Posts by micro sailor
Old Jun 12, 2008, 07:04 AM
Thermal seeker
Bohh33's Avatar
Brunswick, Ohio
Joined Jul 2005
Micro sailer, thank you very much for the reply! Cad files would be excellent as I have access to a plotter.
I will PM you with my email address.
Thank you very much guys!
-Mike
Old Jun 13, 2008, 04:17 AM
Joined Dec 2004
CAD files sent Mike! enjoy the build.
Brett
Discussion Plan Question Fliegenmong Scale Fuel Planes 4 Aug 03, 2006 05:22 PM
Question Power Plan Question devestator142 Flying Wings 2 Feb 14, 2006 07:02 PM
Siemens-Schuckert plan question Kuni Scale Kit/Scratch Built 7 Jul 16, 2005 10:36 AM
P-38 Plan question denverone Scale Kit/Scratch Built 5 Aug 27, 2003 08:20 PM
Question about Rittinger MM P-51 plan (not python) jet_jer Scale Kit/Scratch Built 8 Mar 25, 2003 07:54 AM
