Old Sep 10, 2014, 04:26 PM
Joined Mar 2007
How to mount a tang to the mast
HOW TO MOUNT A TANG TO THE MAST
Do you mount it with one or two screws? Does it face down. Any pics on how this should look? What size screws? Thanks Ron
darticus is online now Find More Posts by darticus
Old Sep 11, 2014, 02:18 AM
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
I'm getting the impression you should be looking in the Sailing forum instead of the Scale Sailing forum. Are dealing with one of those racing class yachts?
JerryTodd is offline Find More Posts by JerryTodd
Old Sep 11, 2014, 01:49 PM
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
The tang itself should align with the load and the mounting screws should be as perpendicular to that as possible. Two screws would be better, but if the load is light, maybe one will be enough. How big should the screws be? Big enough to do the job.
And yes, if this is about a 'regular' rc sailboat, it probably will get more responses in the sailboat section.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Sep 12, 2014, 03:13 PM
United States, WA, Longview
Joined Sep 2012
Ron, is the mast aluminum or wood, if it's a hollow aluminum extruded mast slip a wood dowel and epoxy into mast in the areas you intend to use fasteners before you do though to help hold the screw.
skibo is offline Find More Posts by skibo
Old Sep 17, 2014, 02:08 PM
Big Boats Rule!
Wisconsin
Joined Jun 2007
Good call, Skibo. Also if mast is carbon.
Dave
Old Sep 17, 2014, 03:11 PM
Joined Mar 2007
Thanks all.
It is a wood mast and 72" in height. I did solve the problem but thanks for helping. Ron
Discussion How to take off Main mast on tamiya yamaha boat? chrisorbics Sailboats 2 Jul 20, 2012 01:40 PM
Discussion Mounting antenna on a mast to increase range SugarLandFlyer FPV Talk 14 Oct 11, 2009 01:30 AM
Question mounting a mast R DeMarco Sailboats 18 May 25, 2009 06:32 PM
Question How Do You Lace Mast Hoops? beneteau3 Sailboats 7 Jan 19, 2009 12:44 AM
Help! mast-how do you build yours stewmeat95 Sailboats 1 Dec 21, 2008 07:01 PM
