Old Jun 10, 2014, 02:35 PM
subpixel's Avatar
United Kingdom, England, Nottingham
Joined Dec 2007
New Product
FX071C v912 size FLYBARLESS 4-channel fixed pitch heli
looks interesting, 1st budget flybarless one of this size I've seen and @ $69.99 it is rather cheap for an RTF and Is 6 axis.
Currently no idea what protocol it is using and if it is deviation compatible, manufacturer is feilun i.e. makers of the ft007 & ft009 boats.
FX071C 4CH Single Propeller without Balance Bar RC Helicopter- currently at $75.69 $71.15 with code 615615
Spare parts - use code 615615 for 6% off
Spare parts also at tmart
Specs
Dia. of main blade:397mm
Product size:408.514cm
Transmitter battery: 6 pcs * 1.5 AA (not included)
1000mAh/7.4V Li-Po battery
370 main motor
People have started to receive theirs so here's some info and links from what they have found:
thxkid's Unbox and Review Courtesy Banggood
No complaints about its flying capabilities which is a good thing
No spare blades at all in the box
Comes in original packaging from banggood
Works with the Turnigy 7.4v 950mah 25c-50c batteries
Flight time between 8-9 minutes
V912 canopy fits
V912 main blades do not fit (should do if you thin the root but no one has tested as of yet)
V912 tail blade fits but is a bit larger
4mm main shaft
Weight 280g with battery (225g without)
54.6g battery weight
12.54g canopy
8 tooth main motor pinion
Video of how to bind
Twitchy servo issue due to shorted pins on fcb, vid of issue, source of issue
found a few vids on youku such as this one http://v.youku.com/v_show/id_XNzIxMTM4NDA4.html looks ok but hard to tell from the low quality vid
1 new vid from banggood
FX071C 2.4G 4CH 6-Axis Gyro Flybarless RC Helicopter - Banggood.com (3 min 5 sec)
also found a pic which shows 2 empty 3 pin ports which might be for brushless conversion
can hardly tell they styled this on the devo tx can you
There is also these 2 other helis from feilun
a smaller 100 size FX076C discussion thread / banggood listing
Specifications: 22 5 8.5cm / 3.7V lithium battery (350mAh)
and bigger scale bird the FX070C now available at banggood
discussion thread
Specifications: 61.4 26.6 24.5cm / 11.1V lithium battery (1100mAh)
subpixel is online now Find More Posts by subpixel
Old Jun 10, 2014, 02:49 PM
welder I have also now, hehe
Spain, Principality of Asturias, Ribadesella
Joined May 2013
hehe. I have already ordered one.
goodbye to the stabilizer bar.
This competition will be 200 srx.
have to make changes. hehe.
to play. to play. hehehe
vicio911 is offline Find More Posts by vicio911
Old Jun 10, 2014, 03:02 PM
subpixel's Avatar
Joined Dec 2007
must admit I'm tempted to order one myself, got a spare brushless motor and ESC that was going in a v912 that I could put in it as well.
Just the issue of what protocol it is using that's stopping me.
I wonder if banggood will also list the FX070C
Old Jun 10, 2014, 03:24 PM
Joined May 2013
waho! that handsome.
Old Jun 10, 2014, 04:35 PM
United States, OH, Miamisburg
Joined Oct 2013
I like that one
Tom W. is offline Find More Posts by Tom W.
Old Jun 10, 2014, 04:38 PM
Joined May 2013
here is that there are 2 more connections.
for brushless.
regards
http://item.taobao.com/item.htm?id=39039046758
Old Jun 10, 2014, 08:07 PM
Joined Oct 2013
Ok..NOW I want one...
Old Jun 10, 2014, 10:38 PM
You can call me Pat
United States, FL, Tampa
Joined Dec 2013
who makes this thing?
i figured MJX based on the model name, but it looks to have a Walkera style Tx.
pdooley is online now Find More Posts by pdooley
Old Jun 10, 2014, 11:15 PM
subpixel's Avatar
Joined Dec 2007
going by the logo on the box it is feilun
http://www.feiluntoys.com/EN/feilun/...2_ID=&keyWord=
looks like there is/will also be a mini version the FX076C which is on that link ^
Old Jun 10, 2014, 11:34 PM
Keep em' high and let it fly
vincent713's Avatar
United States, TX, Dallas
Joined Aug 2013
Same company that makes the FX059 & FX052, not the same as MJX.
vincent713 is offline Find More Posts by vincent713
Old Jun 11, 2014, 04:53 AM
Slideways at warp speed.......
kiwi_craig's Avatar
New Zealand, Auckland
Joined Mar 2014
check out the FX076c, even bigger - V913 size ??
kiwi_craig is online now Find More Posts by kiwi_craig
Latest blog entry: Servo testing
Old Jun 11, 2014, 12:26 PM
subpixel's Avatar
Joined Dec 2007
nope, it's a smaller 100 size bird
Old Jun 11, 2014, 05:01 PM
kiwi_craig's Avatar
Joined Mar 2014
tech spec said 11.1v / 1100mah battery and overall length of 630mm ??? agree the photo is 100 size machine though, maybe they have something else coming ?
Old Jun 11, 2014, 05:59 PM
subpixel's Avatar
Joined Dec 2007
the specs on the english site are a mess and they have the specs from the fx070c on the fx076c page, correct specs are on the Chinese site
http://www.feiluntoys.com/feilun/pro...2_ID=&keyWord=
Old Jun 11, 2014, 06:05 PM
Blue Skies
hifinsword's Avatar
United States, VA, Williamsburg
Joined May 2012
Feilun FX070C
It's not on BG yet. The FX070C is almost as big as the V913 at 614mm long. Here's the English version link. http://www.feiluntoys.com/EN/feilun/...ail.asp?id=925
EDIT: New link. Old one doesn't work anymore as of 6/19/14. This one shows the helo but it's a wholesaler.
http://www.irctoy.com/RC-toys/RC-hel...with-Gyro.html
And there's no flybar, a scale fuselage. Looks like maybe a camera in the cockpit too? It uses a 11.1 volt 1100mAh 3S battery. I don't see anyway to order from them.
Who will be 1st to come out with something like this with total BL? Will it be Feilun, MJX or WL Toys? Who's gonna start the thread on it? Subpixel, maybe your thread here can be retitled the Feilun FX07x series helos?
Don
hifinsword is offline Find More Posts by hifinsword
