Old Oct 18, 2014, 01:27 PM
The cycle is complete.
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
Originally Posted by vespa View Post
Setup your mechanics to be as optimized as possible (e.g. arms perpendicular to pushrods, L/R symmetry, maximized use of available servo travel range). Then setup your radio with whatever subtrim and endpoints it needs. It doesn't matter whether you do that in the servo or the radio, electronic adjustment is electronic adjustment and there's generally no drawback to using it. But keep in mind that electronic adjustment should be done to optimize the linkage angles, not the control surface angles -- that's important.
That's the idea. 90 degrees on the horn and 90 degrees to the surface. Learned that while setting up helis.
Sabin is online now Find More Posts by Sabin
Old Oct 20, 2014, 04:16 PM
Team WC2013 F3K
oakman7004's Avatar
Sweden
Joined Dec 2004
If you set up the servos as this vid shown then you'll have good opportunity to get a good setup. Regardless of what transmitter one is using its a good guideline.
/Jonas Ekman
Prepping flaps servos for installation with the F:
Prepping flaps servos for installation (15 min 1 sec)
oakman7004 is offline Find More Posts by oakman7004
Old Nov 04, 2014, 07:53 PM
Tulsa Jones, Oklahoma, United States
Joined May 2002
I just bought six of these servo on Amazon for $27.00/each. They were noted as new, not used and sold by Amazon themselves. Plugged them in and they all work.
Scary.
If your interested, you are limited to three. I used two different logins to get six.
Jeff
nxtdoor is offline Find More Posts by nxtdoor
Old Dec 11, 2014, 02:23 AM
Czech republic
Joined Jan 2010
3270SV bearings
Hello,
today I disassembled two pieces servo S3270SV, has only one bearing, Futaba writes two bearings
Can anyone confirm if servo S3270SVi also has one bearing?
Futaba deceive customers ??
ecop is offline Find More Posts by ecop
Old Dec 11, 2014, 02:50 AM
Czech republic
Joined Jan 2010
Originally Posted by ecop View Post
Hello,
Robbe.de also writes two bearings S3270SV / SVi...
http://www.robbe.de/servo-s3270sv.html
Old Jan 08, 2015, 04:11 AM
jackack's Avatar
Sweden
Joined Oct 2005
You guys who have tested Futaba 3173svi in F3B wings, are these servos doing the job? Centers well and strong enough for F3B flights ?
Price is attractive, but are they precise enough for F3B comp?
Same question goes for Futaba 3270svi, good enough for F3B tails?
Best reg// Jack
jackack is offline Find More Posts by jackack
Sold (5) Futaba S148 servos and (1) Futaba S133 Micro servo JimG_AZ Aircraft - General - Radio Equipment (FS/W) 1 Dec 04, 2013 11:25 PM
Sold (2) Futaba S3004 servos and (2) Futaba S3003 servos JimG_AZ Aircraft - General - Radio Equipment (FS/W) 1 Dec 04, 2013 11:24 PM
Sold 2 Futaba GY401, 1 NEW Eflite G210, 1 Futaba S9257 Servo bbrc77 Aircraft - Electric - Helis (FS/W) 2 Nov 30, 2013 08:46 PM
Sold New Futaba Replacement Servo Gear Sets & Other Parts pnman Aircraft - General - Radio Equipment (FS/W) 0 Nov 21, 2013 01:02 AM
Sold New Futaba S33 servos and one Futaba S32 with accessories uniquewon Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2013 04:57 PM
