Old Nov 01, 2012, 02:02 PM
Question
Can't you just take a bigger motor?!
Hi there,
I am planning on getting a Flamewheel F550 and I was wondering, what would happen, if I decided to take way bigger motors, than the once that come with the kit?! Including higher rated esc's of course?! Wouldn't I be able to increase the payload that way?! Has anyone tried it?!
thanks,
G
neavissa is online now Find More Posts by neavissa
Old Nov 01, 2012, 02:07 PM
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Sure. But the increase in torque will twist the arms and that is not good. When you're at that point it's better to move on to a stiffer frame.
WiseDuck is offline Find More Posts by WiseDuck
Old Nov 01, 2012, 02:11 PM
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
1. Bigger motors mean heaver = decreased flight time
2. Compensate with bigger battery = diminishing returns
3. Bigger motor with bigger props might bring more efficiency..... but you may need to step up to a larger frame ( see #1 )
Bigger also brings with it more likely to do real damage to itself or what it hits when it crashes.
brontide is offline Find More Posts by brontide
Old Nov 01, 2012, 02:44 PM
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
+1
I have explained this to so many customers I lost count.
I feel the stock DJI motors are perfect for the F series frames but the much bigger Avroto motors are too big and powerfull.
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old Nov 16, 2012, 09:58 PM
Makes sense...
thanks, G
Old Nov 16, 2012, 10:02 PM
Interesting. Everything you said, does not apply to any of my helis or cars?!
thanks,
G
Old Nov 16, 2012, 10:03 PM
Originally Posted by Z06 Tony View Post
...but the much bigger Avroto motors are too big and powerfull.
... and that is a problem because...?!
thanks,
G
Old Nov 17, 2012, 11:40 AM
United States, NJ, Manville
Joined May 2006
you are going to need larger props to use larger motors and a large payload...The size of the DJI 550 fram is limited so you will need a larger frame...You must match your thrust to the amount of payload you want to carry and that would mean taking the prop size thrust and multiply that by how many motors you are using...you must also match the motor to your prop size...
skizziks is offline Find More Posts by skizziks
Old Nov 18, 2012, 02:14 PM
Support yer local CharlieSheen
Joined May 2011
I have a DJI f550 with Avrotos and 12x3.8 apc props lifting an AG5650 and NEX5n. I have the arm extension kit on it to allow for the bigger props. It has no problem lifting the weight and I have had 8 min. hover time with 2ea. 4s 4000mah batteries running parallel. It weighs around 4kg AUW. For slow, smooth video it will work fine, but as I have heard, flying it too fast will most likely result in flexing of the arms and unpredictable behavior. Eventually I will probably get a stiffer bigger frame but for now it'll be gentle flying.
isaacintheclouds is online now Find More Posts by isaacintheclouds
Old Nov 18, 2012, 02:21 PM
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
+1
Indeed. I actually tested a bunch of fairly powerful (310w) NTM motors on my TBS frame. In a hover it works fine, but as soon as you punch it or go over 70% throttle or so it loses control completely. I think this is because of the not so stiff arms.
So yeah, stick to the DJI motors or something in the same ballpark. They're good frames for bashing and for getting a feel for hexacopters and whatnot, but I wouldn't use them for any serious work.
Old Nov 18, 2012, 02:48 PM
That I understand. What limits the size of the props?! Could you theoretically make the props so big that they overlap, meaning one prop sits on a longer shaft?!
thanks,
G
Old Nov 18, 2012, 02:49 PM
Good info, thanks. Not sure what a AG5650 is though?!
thanks,
G
Old Nov 18, 2012, 02:51 PM
Interesting. So it is more the F550 that limits the use of more powerful motors, rather than the size of the F550 itself.
thanks,
G
Old Nov 18, 2012, 02:55 PM
Actually, I do have one more question about what you said... Are you saying that if I use a bigger motor, I have to use bigger props?! I was under the impression that you can use the same props, but just amp up the motor?!
thanks,
G
Old Nov 18, 2012, 03:06 PM
Joined Sep 2012
thanks,
G
Do you mean up the voltage, since the only way to get more out of the motor is by putting bigger props or running them at higher voltage. Most motors have a watt limit after which they will start to overheat and eventually fail. Upping the voltage does make the motor less efficient in terms of grams/watt.
You don't just up the amps and upping the voltage can result in lower amp readings during non-peak operation.
Discussion Just when you think watches can't be improved dll932 Life, The Universe, and Politics 23 Apr 17, 2013 01:16 AM
Discussion Ted Turner .... Just another example that a billion dollars can't buy you class logan5 Life, The Universe, and Politics 2 Oct 26, 2012 10:51 AM
Discussion Just when you think you can't get caught out doing something dumb ... bogbeagle Fuel Plane Talk 5 May 30, 2012 01:08 PM
Discussion What have you recently maidened just so you can fly it at SEFF? djmoose SEFF 2012 30 Mar 26, 2012 08:28 PM
Discussion Plantraco micro servos, you just can't fix them can you? shah269 Scratchbuilt Indoor and Micro Models 6 Oct 31, 2008 10:04 AM
