Old Oct 16, 2012, 02:51 PM
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Powering More Than One CellPro
I love my CellPor chargers and was wondering if I could make a "Y" cord and power two CellPro chargers off this single power supply?
http://www.usastore.revolectrix.com/...Power-Supply_2
The biggest battery I have is a 3s 2200 mAh battery and I always charge at 1C. Right now I am charging a 3S 800 mAh battery and it is showing .6 amps charging rate.
Will that work and not over amp the power supply? I've seen guys doing this with a car battery, but not sure about this power supply.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Oct 16, 2012, 03:58 PM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
That is a 12V ,5A PS which is 60 watts.
Volts X Amps. = watts.
It is best to leave a 20% cushion so figure 48 watts available.
A 3S 2200 mAh (2.2Ah ) charged at 1c (2.2A) is 2.2 A X 12.6V =27.72A
You could get by charging two at once if you stargered the charges. That is start one and let it get to the CV stage where it starts to reduce the charge rate and then start the other charger. By doing this botth chargers will not be pulling max. current at the same time . You could also charge each at 1.8A versus 2.2A and the charge time would likely not be more than 10 minutes longer.
Right now I am charging a 3S 88 mAh battery and it is showing .6 amps charging rate.
.6A (600 mA) / 88 mAh =6.81 C charge rate so I hope you made a typo.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Oct 16, 2012, 05:44 PM
Murocflyer's Avatar
Joined Nov 2005
Got it Charles, thanks! And I fixed the typo.
Good to know I can use two chargers on my power supply. I will probably only need to charge my 800 mAh batteries two at a time. The 2200 mAh batts are on my MM Switchback Sr that I will be selling so the batteries will be going with the plane and leave me just the little batts.
So based on your note above, 800 mAh at 1C = .8A x 12 = 9.6V (then times 2) = 19.2V. That's real good. I could even get away with 3 batts at one time. Did I do that correctly?
Thanks again,
Frank
Old Oct 16, 2012, 08:27 PM
Southern Pride
Correct but watts not volts.
.8A X 12 Volts = 9.6 watts but then it is really .8 A X 12.6V ( 3s) =10.08 watts .so you could in fact do four of these at a time.
The PS is 12V at 5A so 60 watts but it is nivce to leave the 20% cushion I mentioned before which leave 48 useable watts.
Charles
Old Oct 17, 2012, 02:27 AM
Murocflyer's Avatar
Joined Nov 2005
Very good. Thanks Charles!
Frank
Discussion Dell server power supply won't provide more than 16amps? davekra Batteries and Chargers 11 Nov 13, 2013 12:11 PM
Discussion Autogyro (in more ways than one...) Zaurak3 General Aviation 1 Jul 19, 2012 09:45 AM
Help! One motor spinning more slowly than the others. mcashatt Multirotor Talk 7 Jul 05, 2012 02:57 PM
Discussion Motors with more power than Omega 103g and 130g?? Slinger1 Power Systems 5 Jun 20, 2012 04:05 AM
Discussion Using a single wire pair to power more than one servo AleG Radios 5 Mar 29, 2008 01:49 PM
