Old Apr 22, 2012, 03:33 PM
Balsa builder and balsa basher
RC Trainer plane's Avatar
Joined Apr 2012
Whoops!
Leading edge HELP! for 1.6m Trainer
Ok i need some help, i'm making a scratch built Rc Trainer as my first aircraft. I've completed the wings (both of them) But i noticed one of the leading edges is a little higher than the other . I was wondering if it would make too much of a difference to the way it flys. Here's a photo of the problem.
It's probably very hard to see but the one on the left is 1mm higher than the other will it make a difference
RC Trainer plane is offline Find More Posts by RC Trainer plane
Old Apr 22, 2012, 06:12 PM
benderfly's Avatar
Joined Sep 2007
Doubtful that this will have much of an impact on flight characteristics for this type of plane. I have flown many RC high wing flat bottom trainers, both gas and electric. I have flown high flat bottom wing trainers with wings I have repaired that had very little original leading edge material and questionable leading edges. Little to no difference.
benderfly is offline Find More Posts by benderfly
Old Apr 22, 2012, 06:19 PM
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
First aircraft? Scratch building help? This is the FPV forum....you're in the wrong place.
-Blues
Blueshy is offline Find More Posts by Blueshy
Old Apr 22, 2012, 06:45 PM
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
on a 1.6m wing, don't worry about it.
Toysrme is offline Find More Posts by Toysrme
Old Apr 23, 2012, 11:10 AM
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I'd say if you are a perfectionist fix it, otherwise who has to know?
dedStik is offline Find More Posts by dedStik
Latest blog entry: More Confessions of a Smoker
Old Apr 23, 2012, 11:25 AM
Joined Apr 2012
so you don't think one wing will generate a little more lift than the other and at full throught it'll roll ? Thanks for the help
Old Apr 23, 2012, 11:53 AM
dedStik's Avatar
Joined Feb 2012
Not with a flat bottom wing no, but if it worries you, some coarse grit sand paper will take out the 1mm in a few swipes.
Old Apr 23, 2012, 12:29 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
It looks to me more like one joint is simply futher back than the other. Depending on how the top sheet is glued to the leading edges this suggests to me more a case of you sanded down one leading edge more than the other. Alternately you may have slipped up and used a wider piece of wood on one side than the other.
Your pictures are a little too fuzzy and at the wrong angles to tell much more than this. Also without seeing the internal structures and how the rest of the center section joint is done I also can't tell more.
If the wing is flat bottomed and both the flat bottoms are lined up and if the upper side curves are close in shape then you're good to carry on. Like I say, it's impossible from here to see why the glue line of one is higher and further back than the other. But it's the shape of the wings that count. If the bottoms are both lined up and the upper side curves are lined up then don't worry about the joint being staggered back a little on one side.
BMatthews is online now Find More Posts by BMatthews
Old Apr 23, 2012, 02:58 PM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
If you have ailerons,it'll be easy to trim out....if it's rudder only,it will be a little more difficult to trim.
Here's a solution if you're too worried....when you cover the wings,make sure the bottom of the wing lies flat on a surface you know is flat,all around.
Measure up to the opposite wing tip,and be sure it is exactly the same distance to the bottom of the trailing edge,as the distance to the leading edge bottom.
You'll have to do this on the flattest part of the rib.at the tip.
If it's off,twist it a little more than that amount the other way,then heat it with your sealing iron...With practice,you'll end up with less 'twist' than you have now.
But in our opinion, forget that minor amount...And no,it won't roll over on you at full throttle ! Nice work-by the way.
epoxyearl is offline Find More Posts by epoxyearl
Old Apr 24, 2012, 01:01 AM
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
The most important thing to building a straight flying wing is getting the twist (or tack of twist) identical on both sides. It has far more effect that slight variations in airfoil shape. That's what epoxyearl is talking about.
That said, if its a little bit out (my wings are never perfect) a bit of aileron trim will have it flying OK.
Scaledown is offline Find More Posts by Scaledown
Old Apr 24, 2012, 02:27 AM
KE your cub.
Curare's Avatar
in the gutter, again....
Joined Jun 2005
Fixing a warped wing with aileron trim is a band-aid fix, and a poor one at best.
you'll find that as speed increases and decreases you'll be chasing the trim the whole time.
Like the guys say, make sure your join is as straight as you can make it. Pay special attention to the trailing edge, to ensure that they line up, and have similar flatness or washout at the tips. Take your time.
A square aeroplane that flies true is a joy. A wonky out-of-square plane is not.
Curare is online now Find More Posts by Curare
Discussion Fixed leading edge slats, examples RCB1 Fuel Plane Talk 27 Feb 17, 2014 03:13 PM
Help! Search: 1.6m/2.5m slope racer for light to middle conditions sky_surfer_fra Slope 1 Jan 04, 2012 09:25 AM
Wanted Wing Bag for Skymaster Viper 1.6M or 2M jetfan20 Aircraft - Fuel - Jets (FS/W) 0 Oct 23, 2011 02:05 PM
Discussion I need to shape a 3/16 wide x 1/4 high leading edge captainborg Scale Kit/Scratch Built 8 Oct 20, 2011 10:03 PM
Discussion which is better for leading edge? profilefan Scratchbuilt EDFs 9 Sep 11, 2011 02:00 PM
