Old Jun 08, 2003, 09:24 PM
ZippoGeek
zippogeek's Avatar
United States, NY, Buffalo
Joined Dec 2002
Brand-new Jeti ESC problem
I have a brushless Jeti 30-3P ESC that I put 3 flights on today for the first time. I'm running a Mega 16/15/5 with a 8 x 1650 AA NiMh Sanyo pack; Unicorn EPP wing.
I had a VERY minor nose-in on my third flight from about 10 feet up at slow speed. After this, the motor started acting very weird, sort of sputtering slowly when throttle is applied then cutting off almost immediately. It no longer beeps as it should when I plug the pack in.
What could I have possibly done to it? It was almost a complete non-crash and I don't see how I could have damaged the thing.
Any suggestions before I start ripping it out my new Unicorn?
Man, this hobby is a lot of work sometimes...
Jason
zippogeek is offline Find More Posts by zippogeek
Old Jun 08, 2003, 10:09 PM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
I would bet that you bent the shaft or caused some other damage to the motor and it it binding and drawing too much amperage.
Do you have another motor to check the esc on? I would check the motor very carefully. Even "minor" crashes (10 feet is pretty high) can cause significant damage.
Old Jun 08, 2003, 11:16 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
If it uses a prop adaptor, make sure that it hasn't been pushed hard against the motor.
hoppy
hoppy is offline Find More Posts by hoppy
Old Jun 08, 2003, 11:37 PM
San Diego, Ca
Joined Jul 2001
check connections
Sometimes a brushless controller will act like this if the connections between motor and esc are loose
jared salbato is online now Find More Posts by jared salbato
For Sale Brand New Jeti Jes 180 ESC freddb3 Aircraft - Electric - Power Systems (FS/W) 0 Jan 17, 2007 12:52 PM
New Jeti esc's 040- $15, 180- $25, 350- $35 braxx Aircraft - Electric - Airplanes (FS/W) 0 Jan 21, 2004 09:02 PM
Brand New Jeti 5 amp speed controller thomer Aircraft - Electric - Airplanes (FS/W) 2 Nov 27, 2003 02:32 AM
Brand new Jeti JES 60 esc tripster Aircraft - Electric - Airplanes (FS/W) 2 Apr 11, 2002 07:14 AM
BRAND NEW GWS ESC/NICAD PACK for TIGERMOTH, etc. tigerstrike Aircraft - Electric - Airplanes (FS/W) 1 Mar 09, 2002 10:33 PM
