Old Nov 16, 2005, 04:12 AM
Brian Courtice
Brian Courtice
Guest
n/a Posts
need futaba 9Z 4 servo wing programming help
I'm hoping someone might be able to send me their program setup for a
four servo wing sailplane using the 9Z. My radio is the older, pre-WC
version, and the plane I'm trying to set up is an Opus.
I'm pretty close but I have a couple of problems that are stumping me.
Aileron differential (ADF) only affects the ailerons and not the flaps
that work along with the ailerons. If I use ATV (adjustable travel
volume) to limit the range of the flap motion, I end up with limited
down flap available in butterfly mode.
I need full 140% down flap range with crow (butterfly) deployed for
maximum down flap on landing approach. However I don't need anywhere
near 140% down flap travel when the flaps are working as ailerons.
Unfortunately, limiting the flap range outside of crow programming seems
to have the effect of reducing the available flap range within crow.
Thanks in advance for any help!
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.362 / Virus Database: 267.13.2/170 - Release Date:
11/15/2005
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off. Email sent from web based email such as Hotmail and AOL are generally NOT in text format
Discussion Futaba T7CP and a 4 servo wing TerryS Radios 6 Jul 28, 2007 12:14 AM
Futaba 7c with 4-servo wing? sglade Slope 9 Nov 12, 2005 08:53 AM
Need Futaba 9Z Help Mauihiflyer Radios 0 Apr 30, 2005 10:23 PM
Help: Futaba Skysport 4, servo reverse switch won't switch back!?!? mike93 Parkflyers 0 Dec 17, 2002 04:40 PM
9Z and butterfly help on 4 servo wing. Giovanni Day Electric Sailplanes 0 Jul 28, 2002 12:44 AM
