Old Mar 15, 2015, 09:46 AM
Brian C is offline
Find More Posts by Brian C
Joined Nov 2004
Laminating Depron
Hi guys,
Need to laminate 3 pieces of depron to make a forward fuselage on a depron profile kit. I'd like some opinions on the best way to accomplish this task.
Thanks in advance for everyones input.
Brian C
Brian C is offline Find More Posts by Brian C
Old Mar 15, 2015, 10:16 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
There are a few threads below in the 'Similar Threads' list.
I generally use UHU Por thinly spread on both surfaces, keeping away from the edges if they are to be sanded.
You could use epoxy if greater strength is required.
eflightray is offline Find More Posts by eflightray
Old Mar 15, 2015, 03:58 PM
Mikeofthenorth is offline
Find More Posts by Mikeofthenorth
Mikeofthenorth's Avatar
United States, MI, Oxford Charter Township
Joined Dec 2012
I have used white Gorilla Glue to laminate, I run a Top Flight Woodpecker http://www.rcplanet.com/ProductDetai...FdgNgQodQAkANA over the surface first, then wet one side and spread the GG on the other side, getting the GG thin so there is not too much is key, it is best to weight down the parts while thy dry, painters tape around the edges will help control the foaming.
Mikeofthenorth is offline Find More Posts by Mikeofthenorth
Old Mar 15, 2015, 04:26 PM
slow and low is online now
Find More Posts by slow and low
Larry........... parkflyer
United States, IL, Eureka
Joined Dec 2014
Is white gorilla glue wood glue? That is all that I see around here. I use regular GG for laminating following the same recommendations as Mike, except the woodpecker, but that is a great idea.
I have heard of some using Scott77 but that is real tricky when you get just a little too much in one spot..... it DOES eat Depron if too much is used.
slow and low is online now Find More Posts by slow and low
Old Mar 15, 2015, 06:13 PM
Joined Dec 2012
White Gorilla Glue is a wood glue it does not foam up as much as the brown, and it dries faster.
Old Mar 16, 2015, 07:47 AM
flypaper 2 is online now
Find More Posts by flypaper 2
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I use this Lepages Green contact cement. It's water based so won't hurt any foam. Spread thin on both sides, let sit for 15 mins. and carefully line up, as once they touch, it's there to stay.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Mar 16, 2015, 08:19 AM
Model Aero is online now
Find More Posts by Model Aero
Northwest Ohio
Joined Jan 2002
3M 45 spray adhesive works well.
Model Aero is online now Find More Posts by Model Aero
Old Mar 19, 2015, 03:36 PM
RNAF is online now
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Check out the grain too. Depron has a grain, similar to wood. Swap this grain 90 degrees to have equal strength in both directions.
RNAF is online now Find More Posts by RNAF
Old Mar 19, 2015, 08:51 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Glidden 'Gripper' Latex primer.
Very few products perform better.
Bare is offline Find More Posts by Bare
Old Mar 20, 2015, 07:29 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Agreed !!! Yes, the Gripper works Great , especially given a proper drying time ... We’ve recently laminated two Blucor (old stock) Profile F-14’s , two A-12’s , and a Foam EZ canard made from real (actually used ) meat trays from the grocer. We clamp for overnight.
gpw is offline Find More Posts by gpw
Old Mar 20, 2015, 09:05 AM
Ralph A. D'Amelio is offline
Find More Posts by Ralph A. D'Amelio
Ralph A. D'Amelio's Avatar
United States, MA, Chelmsford
Joined Jul 2000
Have always used 3M77 , not hard to spray lightly don't understand why everyone makes a big deal about using it. Excellent bonding and quick!
Ralph A. D'Amelio is offline Find More Posts by Ralph A. D'Amelio
Old Mar 20, 2015, 11:19 AM
mmattock is online now
Find More Posts by mmattock
Canada, AB, Airdrie
Joined Oct 2014
I just did a test lamination of some scrap 3mm depron with 3M77. Worked fine, the bond is impossible to separate and didn't eat the foam. Seems OK to me.
Mark
mmattock is online now Find More Posts by mmattock
Old Mar 20, 2015, 04:30 PM
randall_l is offline
Find More Posts by randall_l
Just here for the pie.
Canada, BC, Ashcroft
Joined Jun 2011
I've used 3M77 spray adhesive for the past 4 years to build Depron planes. The one's I haven't crashed to destruction are still bonded strongly and I've never had it eat the foam.
Cheers!
Randall
randall_l is offline Find More Posts by randall_l
Old Mar 21, 2015, 08:11 AM
birdofplay is online now
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
The folks who grew up with Light Socket protectors and Child seats are mostly
worried about the 3M77 Fumes.
And I suppose that Folks who ARE sensitive DO have a point.
I've used 3M77 for years in well ventilated conditions.
Careful choosing Gorilla White as there are TWO types.
One is water based like alphatic resins and NOT good for laminating.
The other is Clear, 2oz for $5, that is essentially a PU type and it SELF CURES but foams.
I think it's called fast set.
Bob
birdofplay is online now Find More Posts by birdofplay
Old Mar 21, 2015, 12:35 PM
wwmoggy is online now
Find More Posts by wwmoggy
Canada, ON, Peterborough
Joined Dec 2014
I have never used depron but Elmers adhesive spray works on Dollar tree foam board. I removed the paper first to test it
wwmoggy is online now Find More Posts by wwmoggy
Discussion laminated DTF = 6mm Depron? wood_butcher Foamies (Scratchbuilt) 19 Feb 20, 2014 07:27 AM
Discussion Depron - Laminated or Plain? cometravi Foamies (Kits) 5 Mar 27, 2006 01:06 PM
Laminated Depron Wings? rutat Foamies (Kits) 2 Nov 07, 2005 11:56 PM
Can't sand 3M77 Contour lines (Depron laminate) albireo Pusher Prop Jet Models 28 Nov 05, 2005 01:01 PM
Question Balsa-Depron laminate for open structure-like building, a feasible idea? Iso Octane The Builders Workshop 23 May 15, 2005 07:47 PM
