Old Jul 29, 2014, 12:08 AM
marmalade1 is online now
Find More Posts by marmalade1
United States, IL, Wheaton
Joined Sep 2013
Magnum .91 FS. Damaged?
My almost new Magnum .91 four stroke took a hit from a loss of control on the downline of a stall turn. It hit hard into the dirt, burying the spinner. The engine was quickly inspected by some guys at the field. They agreed it is making a ticking sound upon rotation of the prop and that this means the valves need adjusting. The crank seems straight and no dirt entered the rear intake. It is ostensibly clean and in good condition.
I'm concerned that my almost new (break-in plus 5 flights) engine is damaged. How can I know if that's all that is the problem? Would running it damage the engine?
I appreciate your advise.
PD.
marmalade1 is online now Find More Posts by marmalade1
Old Aug 01, 2014, 07:53 AM
Lumpy05 is offline
Find More Posts by Lumpy05
Lumpy05's Avatar
United States, IN, Bloomington
Joined Jan 2012
You should have an "engine guy" go over the engine before you run it. The valves could be knocked out of adjustment or just plain damaged in some way. The bearings could be damaged, etc.
Valve adjustment is fairly easy but if you have not done it have someone with experience show you how. You could take the valve covers off and turn it over by hand and see if you can find the source of the ticking.
Depending on what is wrong or not wrong with the engine you could have a serious backfire, cause further damage to damaged parts, poor or no running, or smooth running. There really isnt any way to know via the web.
Lumpy05 is offline Find More Posts by Lumpy05
Old Aug 01, 2014, 02:33 PM
Joined Sep 2013
Thanks for the reply. I'm wondering if the sound is just normal, but previously unnoticed clicking. I'll take your advice and bring it to the field for an inspection before running it.
PD
Old Aug 22, 2014, 03:41 PM
kimchiyuk is online now
Find More Posts by kimchiyuk
kimchiyuk's Avatar
United States, NY, Eldred
Joined Jun 2012
If the clicking wasn't noticed before, than I'd definately open it up to make sure everything is ok. Some four stroke valves make noise whe others are very quiet. Just as an example: O.S. And Saito four strokes you can barely hear the valve train movement, but on Thunder Tiger four strokes you'd swear something is broken.
kimchiyuk is online now Find More Posts by kimchiyuk
Old Aug 30, 2014, 11:20 AM
Joined Sep 2013
Update: I adjusted the valve clearances, and took it to the field. The clicking was similar to an OS 70 Surpass 2 that I have, so I thought I'd try it out. It runs perfectly. Smooth, long idle, crisp transition, strong top end. Thanks for your suggestions.
Sold Magnum XL .91 FS PRICE REDUCED!! KaP2011 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Nov 20, 2013 01:25 PM
Wanted Complete Muffler Assembly for Magnum 91 / FS 91 FS 4 Stroke LCS Aircraft - Fuel - Engines and Accessories (FS/W) 1 Nov 06, 2013 12:42 PM
Sold New Magnum fs 91 nh4clo4 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 01, 2013 03:00 PM
Sold Magnum .91 fs,Magnum .61,NIB radman615 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 14, 2012 05:19 PM
Discussion Magnum 91 RFS vs Thunder Tiger 91 FS snowwolf Engines 7 Apr 27, 2007 09:05 PM
