Old Jul 22, 2013, 11:06 PM
bagedtaco is offline
Find More Posts by bagedtaco
Joined May 2006
bent prop
got a bent prop in the mail today from an order. is there a way to fix it? looks like it got stepped on or wedged against something. it was shipped in an a regular envelope with shipping tape rapped around it so no real padding.
bagedtaco is offline Find More Posts by bagedtaco
Old Jul 23, 2013, 06:04 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Return to sender, ask Whazzup with this insufficient packing?
patmat2350 is offline Find More Posts by patmat2350
Old Jul 23, 2013, 10:23 AM
charlie eaton is offline
Find More Posts by charlie eaton
charlie eaton's Avatar
N.E.Mass.
Joined Apr 2007
Originally Posted by patmat2350 View Post
return to sender, ask whazzup with this insufficient packing?
ditto!!!!!!!!!!
charlie eaton is offline Find More Posts by charlie eaton
Old Jul 30, 2013, 10:22 AM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
If you are stuck with it for whatever reason you can very carefully bend it back to a symmetrical shape, measure a lot and go slowly. Once it looks the way you want it to remember to also sharpen and balance it, these days it’s almost a lost art. Look for prop modification threads here and they will further explain how to do this.
Kcal is offline Find More Posts by Kcal
Old Jul 30, 2013, 12:04 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
If the blades are soldered on, inspect those joints very carefully. It's not high strength solder, so the joint could be broken.
If needed, the solder could be reflowed, but you'll want the prop blades already straightened, and sitting in a fixture to hold their position.
Discussion My prop adapter is bent eagle777 Beginner Training Area (Aircraft-Electric) 3 Apr 07, 2013 09:31 PM
Help! Ever so slightly bent prop shaft viperidae Racing Boats - Electric 4 Mar 03, 2013 08:08 AM
Discussion how can you actually tell if a prop shaft is bent? allisonmo2 Micro Ready-to-Fly 7 Feb 02, 2013 07:01 AM
I bent the prop shaft, how do i fix it? s_sanders Foamies (Kits) 5 Jul 10, 2001 11:43 AM
Bent prop shaft argh... 177ichael Electric Plane Talk 3 May 17, 2001 04:14 PM
