Old Aug 18, 2011, 08:27 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
ESC RPM Senor
Hello everyone,
I would like to ask if someone knows of a good way to creating an senor that would connect to one or two wires coming from an ESC? The output from this sensor then would connected to an Arduino and the RPM calculated.
Thank you in advance.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Aug 20, 2011, 06:03 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Here's the rpm sensing circuit I used for my DIY Wattmeter.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Aug 20, 2011, 08:19 AM
Joined Aug 2009
Thank you so very Much.
Old Aug 27, 2011, 03:46 PM
pitlab is offline
Find More Posts by pitlab
pitlab's Avatar
Warsaw, Poland
Some time ago I tried to build something similar, but had problems with counting PWM impulses instead phase turn on.
Maybe few pictures describe better the nature of the signal:
On the picture is one phase of the ESC. We can see current ramp up, turn on for about 4ms and next ramp down.
On closer look we can see series of impulses. Most probably the circuit described above will count the short PWM impuses instead total phast on.
I tried to filter the impulses, but the signal has wide range of frequency changes, so filter not worked well in all conditions.
More close view of the PWM impulse. Im my ESC it had frequency 7.8kHz.
Finally I builded optical RPM sensor. It works well in all conditions. Actually I use 2 sensors on my quadrocopter. It "looks" on the engines with glued black stickers on the half of circumference. Second half can be with white sticker, or like in my case is reflective metalic body of the engine.
Actually I use the sensors to compare parameters of the drives. For example test run with empty engine and engine with 10x4.5 propeller
Upper graph shows current (red) and voltage (blue), middle graph shows servo signal going to the both ESC. It is scaled in microseconds. Bottom graph shows RPM of the both engines measured with my sensors.
pitlab is offline Find More Posts by pitlab
Old Aug 27, 2011, 05:13 PM
Joined Aug 2009
Thank you, the IR senor may just be the better Mouse Trap.
Old Aug 28, 2011, 03:37 AM
Zen09 is offline
Find More Posts by Zen09
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
Have a look in this thread for a simple IR solution http://www.rcgroups.com/forums/showthread.php?t=1450032
Zen09 is offline Find More Posts by Zen09
Old Aug 28, 2011, 08:10 AM
Joined Aug 2009
Thank you.
Old Dec 13, 2012, 07:58 PM
owlhh is offline
Find More Posts by owlhh
United States, GA, Fort Valley
Joined Aug 2007
Hi do you know of any senored input ESC 's 25A to 40A using hall effect sensors on outrunner motor?
owlhh is offline Find More Posts by owlhh
Help! Blade spins higher at med RPM, lower at high RPM Arctauras Electric Heli Talk 4 Aug 05, 2011 03:49 PM
Discussion ESC Max RPM Atx_Heli Power Systems 3 Jul 18, 2011 05:31 PM
