Old Mar 26, 2010, 12:25 AM
kctrading is offline
Find More Posts by kctrading
Hemet, California
kctrading's Avatar
United States, CA, Hemet
Joined Mar 2005
Wild Wing with 204 Hobby King LED's
Anyone else running these lights? I am drawing just 1.2amps per my watts up meter...not sure the picoswitch can handle this as they rated it as 1amp at 24v but it should go up as the voltage goes down!?
Here is my build-up page, pg 70 which shows the lights, setup and video:
http://www.rcgroups.com/forums/showt...615239&page=70
Any suggestions on this? I already figured out I need to add eight red led's on the TE so I can see it better when flying away from me.
Ken
kctrading is offline Find More Posts by kctrading
Old Mar 29, 2010, 12:44 AM
VROOMSTER is offline
Find More Posts by VROOMSTER
AMA #953123
VROOMSTER's Avatar
Eugene, ORYGUN
Joined Mar 2009
I just ordered some white ones but still need some green/blue/red. The yellow ones are very bright on 3S. Cant wait to get enough lights to test them out in the sky.
VROOMSTER is offline Find More Posts by VROOMSTER
Old Mar 29, 2010, 11:15 PM
Hemet, California
kctrading's Avatar
Joined Mar 2005
Just found a cheaper outlet in China for the same exact LED's> Shipping is also a bit cheaper as well...
http://www.lowpricerc.com/advanced_s...ds=LED&x=0&y=0
Old Apr 03, 2010, 12:30 AM
Bilbobaker is offline
Find More Posts by Bilbobaker
Bilbobaker's Avatar
United States, UT, Salina
Joined Apr 2003
Sweet, love your flying wing setup.
I'm gonna do the same to one of mine.
Wish there was a quiet motor for the flying wing.
That's one big advantage of using a SS or IFO for night flying.
Very quiet motor and prop.
Bilbobaker is offline Find More Posts by Bilbobaker
Old Apr 03, 2010, 06:31 PM
Hemet, California
kctrading's Avatar
Joined Mar 2005
You could build a super lite WW that would allow for slower flight, smaller motor with a bigger prop along with a smaller lipo. I plan on taking off the 7x5 and going with a 8x4 so I can run my bigger 2200mah lipos....this will give more thrust with a little less speed...I usually run a 8x6e but it drains the lipos pretty fast but does give close to 100mph flight speed.
Old Apr 03, 2010, 10:01 PM
Bilbobaker's Avatar
Joined Apr 2003
Ever get disoriented night flying at those speeds?
I stuck my wing first time I tried night flying with it.
I only had key chain marker lights on it.
Old Apr 04, 2010, 10:13 AM
Hemet, California
kctrading's Avatar
Joined Mar 2005
I tried the finder lights on my Flash 3D plane...was very hard to see as the led are only single and not very bright....once you install the string leds there is no comparrison. My wing colors are dark on the bottom and lite on top, I also did the led's that way...so red, blue and green on bottom. All green on top...this helps a lot.
Old Apr 10, 2010, 11:55 PM
Bilbobaker's Avatar
Joined Apr 2003
One more question about those light strips.
Since each set of three is resistored for the voltage you should be able to mix up the colors on on feed right?
Like ten of each color soldered together in a strip.
Old Apr 11, 2010, 12:37 AM
Hemet, California
kctrading's Avatar
Joined Mar 2005
Yes!
Discussion Hobby King's F15 Foam EDF DonQ8401 Foamy EDFs 27 May 14, 2010 09:50 PM
Video Wild Wing Night Flight 204 Hobby King LED's!!! kctrading Electric Plane Talk 2 Mar 26, 2010 08:06 PM
Discussion Hobby King's DG-1000 Aros Electric Sailplanes 5 Mar 02, 2010 06:30 PM
Wanted Hobby People Wild Wing needed. himeros Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2009 05:45 PM
Hobby People's Wild Wing for $19.95 SteveO Flying Wings 5 Jun 03, 2005 02:44 PM
