Old Mar 06, 2012, 06:04 PM
tenrozzero is offline
Find More Posts by tenrozzero
Joined Oct 2011
I am about 90 percent done building my Multiplex Fun Cub. My manual says the CG should be at 3.1" or 80mm not 60mm from what I am reading from the room forum......is this a misprint or what should the CG actually be then?
tenrozzero is offline Find More Posts by tenrozzero
Old Mar 06, 2012, 06:10 PM
sc10pc is offline
Find More Posts by sc10pc
sc10pc's Avatar
Joined Mar 2012
ok i tested on the msc and it works fine it ends up sinking in and holding strong but thats on z-foam so still dont know bout elapor
sc10pc is offline Find More Posts by sc10pc
Old Mar 06, 2012, 06:12 PM
sc10pc is offline
sc10pc's Avatar
Joined Mar 2012
the cg from all the forums ive read says 60-70mm aft
Old Mar 06, 2012, 06:13 PM
Beancounter is online now
Find More Posts by Beancounter
Beancounter's Avatar
United States, MA, Sterling
Joined Sep 2009
Originally Posted by newTOpro View Post
I just received mine from Tower Hobbies last week. They have it, just search for "Fun Cub"
wholesaletrains.com seems to have them in stock all the time as well
Beancounter is online now Find More Posts by Beancounter
Old Mar 06, 2012, 06:45 PM
WalneyCol is offline
Find More Posts by WalneyCol
Seafax ROV
WalneyCol's Avatar
United Kingdom, Barrow-in-Furness
Joined Feb 2011
Todays funcub
I've been experimenting with a gyro on the funcub's ailerons today in an effort to get it stable enough in a stiff breeze to take a spot of onboard video.
Wind was about 15mph from the south the camera is an 808 #11 and this flight was without the giro.
Closed Cafe Funcub (4 min 3 sec)
There'll be another video to come in the morning (still uploading) with the giro in rate mode with gain set at 30%
Col.
WalneyCol is offline Find More Posts by WalneyCol
Old Mar 06, 2012, 08:16 PM
Woody_99 is offline
Find More Posts by Woody_99
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
Originally Posted by sc10pc View Post
ok ordered her today and can not wait so i went with all the electronics i listed earlier minus the esc and radio. i now have an 9ch fly sky that i can mix channels and has memeory and than as to the esc i went with a turnigy plush 60a esc. so i can not wait! hey on a side note i had my dad pick me up some glue called duco cement and i wanted to know if any of you guys have used it for anything reall and will it work on the elapor? thanks, Chris
Best advice is to use what is know to work well, and pick up a bottle of medium CA and some kicker for it.
It holds perfectly, and the medium cures slow enough without kicker to position the big parts together.
Woody_99 is offline Find More Posts by Woody_99
Old Mar 07, 2012, 01:08 AM
Bluey_65 is offline
Find More Posts by Bluey_65
Australia, VIC, Lara
Joined Jun 2011
Very nice paint job indeed! What paint did you use?
Bluey_65 is offline Find More Posts by Bluey_65
Old Mar 07, 2012, 03:24 AM
Seafax ROV
WalneyCol's Avatar
Joined Feb 2011
Trying out an aileron gyro in rate mode (with 30% gain) on a funcub in an attempt to increase the wind speed at which I can still produce usable video. I wasn't too happy with the result of this test. When flown very slowly and up to the funcub's natural cruising speed it really does help but as airspeed increases towards the plane's maximum speed pretty bad wing wobble sets in and you'd wind up producing better video with the gyro turned off. I need to play around with gain settings and aileron thows some more and I've still to try running the gyro in heading hold mode but I'm planning at flying it off water at the weekend so further experiments will have to wait.
Funcub rate mode aileron gyro test (8 min 57 sec)
Old Mar 07, 2012, 06:57 AM
Shepski is offline
Find More Posts by Shepski
Joined Jan 2010
I had 500 flights recorded on Funcub number one, i then sold it on Ebay for virtually what it cost me to build. Then yesterday i passed flight number 300 on Funcub number two.
What a fantastic general purpose and strong plane these Funcubs are, and what great flyers, without doubt my favourite plane of all time.
Shepski is offline Find More Posts by Shepski
Old Mar 07, 2012, 07:53 AM
OTTOFLYS is offline
Find More Posts by OTTOFLYS
Grand Rapids MI.
Joined Feb 2011
I cant take it any more.... I saw the FC about a year ago and have been reading this thread and watching all the videos ever since. I had and have several differant planes but none seem to be the right fit for me........I'M ORDERING ONE Today
OTTOFLYS is offline Find More Posts by OTTOFLYS
Old Mar 07, 2012, 08:23 AM
Joined Sep 2009
Just some rattle can stuff I found at the home center. This foam they use you paint them with just about anything.
Old Mar 07, 2012, 10:00 AM
adioperator is offline
Find More Posts by adioperator
adioperator's Avatar
Joined May 2010
A simple Funcub Flight.
FunCub RC from Multiplex (2 min 11 sec)
adioperator is offline Find More Posts by adioperator
Old Mar 07, 2012, 11:49 AM
.Steve is offline
Find More Posts by .Steve
Gravity Test in Progress
United States, WA, Tacoma
Joined Jul 2010
Originally Posted by RC everything View Post
Duco -For wood, metal, china, ceramics, glass and hard plastics
http://www.acehardware.com/product/i...ductId=1798298
Test it first on a spare piece of foam and see how it holds and all before building the plane with it.
there is a controversy going on about the "right" glue to use on Elapor.
Multiplex says in their instructions to use CA. it works great, though a bit too fast for me.
Multiplex states clearly "that while the glues/epoxies looks like they hold, they only give a "superficial bond" or something very similar to those words.
I am using a 90 minute epoxy on some areas of mine and so far it is working good.
You hear and see guys using 5 minute epoxy to repair parts broken during a crash and it works great.
I am thinking that the mold release agent is causing some problems in letting the glues and epoxies attach themselves to the Elapor.
CA's may be able to dissolve the release agents??? I'm no chemist by any means, just thinking out loud and from what I've seen. Why is it 5 min. epoxy works to repair a FC - is it because the sections being glued have broken off and there is no release agent where the parts have cracked? I haven't sanded any parts when I've used the CA, but do for the epoxy.
Do your test with the Ducco, but try it on a section not sanded and on a section where you have sanded it in preparation just to see if removing the mold release agent makes a difference.
Just my opinion.
.Steve is offline Find More Posts by .Steve
Old Mar 07, 2012, 11:53 AM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
i feel it depends on how you beat on the plane......which I don't. it's a lazy flyer, float in the wind sorta plane
JDMJim is offline Find More Posts by JDMJim
Old Mar 07, 2012, 04:07 PM
RC everything is offline
Find More Posts by RC everything
Jedi Knight
RC everything's Avatar
Ireland
Joined Jun 2009
Yes as .Steve has stated in a much more informative manner....test first
Just my opinion.
RC everything is offline Find More Posts by RC everything
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
