Old Sep 06, 2008, 12:00 PM
syncronized's Avatar
Canada EH?!?
Joined Sep 2007
Thrust Bearing for 5mm motor shaft??
Hey guys....
I found these on eBay...
Thrust Bearing 1
Thrust Bearing 2
Will these work with my 5mm brushless motor shaft?
And would you place the thrust bearing right up against the motor? In between the motor and the motor coupling?
Thanks in advance!
syncronized is offline Find More Posts by syncronized
Old Sep 06, 2008, 01:25 PM
Joined Nov 2005
possibly...I would want to know their rpm rating though before I installed them(wouldn't do to discover that they were rated less than what the motor was turning...)
2nd Q: yes, with approx 0.005" play(about the thickness of a piece of printer paper)
Rex R is offline Find More Posts by Rex R
Old Sep 06, 2008, 01:50 PM
When the time is right
Duke58's Avatar
Hayward, CA
Joined Apr 2001
#1 with the brass cage is the one to get , the brass one handles the speed better . If you find a small thrust bearing that is rated at the speeds we operate at let me know , 10-12K is about the practical limit but it does not mean they will not work for a while at 20K I just bought some from McMaster-Carr.
Earl
Duke58 is offline Find More Posts by Duke58
Old Sep 06, 2008, 06:31 PM
Joined Nov 2005
I've had no issues with these http://www.offshoreelectrics.com/pro...?prod=dh-53136 I'll grant that they may cost more...but then I usually need other stuff and that brings the per item shipping cost down .
Yippee! Mod:Add thrust bearing for main shaft of Trex. iceman33 Mini Helis 64 Jun 14, 2007 08:00 AM
Where to buy spinners for 3mm motor shaft? Danny Troy Power Systems 7 May 07, 2005 04:17 AM
Alert WTB: Corona 120 NHP Autorotation Main Gear with One Way Bearing 4 5mm titanium shaft HeliDave Aircraft - Electric - Helis (FS/W) 0 Apr 11, 2005 09:53 PM
11T pinion for 5mm motor shaft? GregoryJ Power Systems 4 Mar 04, 2004 08:38 AM
WTB: prop adapter for "Zagi" props for 2mm motor shaft JohnM Aircraft - Electric - Airplanes (FS/W) 4 Dec 18, 2003 08:52 PM
