Old Jan 21, 2011, 12:21 AM
When's the next fly-in?
dee-grose's Avatar
Tanner, Alabama
Joined Oct 2003
Problem with old Cosel power supply
How about a blast from the past???
Do you guys remember those Cosel power supplies that were so popular back in 2003-2004? Well, my brothers and I bought a few of them. They were cheap and worked well.
Anyway, one of them quit working and it was given to me to see if I could do anything to fix it. Well, it sat in a box for several years until I found it the other day and decided to figure out what was wrong with it. When it was plugged in, the little red LED would come on for a second or two and then fade out. Measuring the voltage across the pos/neg would give a reading for a brief moment and then go to zero.
So I turned to our friend the search function and searched this sub-forum for answers. Within a few minutes, I found this post that described my exact problem.
http://www.rcgroups.com/forums/showp...3&postcount=73
Hmm...lemme keep reading. In post 75, the idea of jumping the voltage sense terminals to the main terminals. Sounded like a good thing to try, so I grabbed some wire and made the jumpers. Sure enough, it powered up and gave me 11.xx volts. A little fiddling with the trim pot got the voltage up to 12.0 volts. Easy fix!
So if you've got one of these just laying around because you think it's dead, give this fix a try. Maybe this will help somebody out.
Andy
dee-grose is offline Find More Posts by dee-grose
Old Jan 21, 2011, 12:45 AM
Tomahawk's Avatar
Southern Ontario, Canada
Joined Nov 2001
Still have mine and still using it. I also have a spare one just in case the first one craps out. Certainly couldn't beat the price at the time. Good old Cosel power supplies.
Chris
Tomahawk is offline Find More Posts by Tomahawk
Old Jan 21, 2011, 09:28 AM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Me too. It still gives good service and stays in the truck for when I find 110 at a field to charge from. Good link!
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Jan 21, 2011, 07:14 PM
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Just so you know, ALL supplies with separate sense lines should have them connected to the outputs, one way or another. They are separate so you can connect them directly to the load, so the supply can compensate for voltage loss in the power carrying wires. If those wires are fat enough, or a few tenths of a volt don't matter, short them at the supply.
Wintr is online now Find More Posts by Wintr
Old Jan 22, 2011, 10:56 AM
Beaumont tx
My Lord, I thought Howard was dead!!~
howell
gwinhh is offline Find More Posts by gwinhh
Old Aug 09, 2011, 02:10 AM
Joined Aug 2011
Andy
i have the cosel power supply but it haven't sense terminal...The problem is same with above....can u help me?
decastenza is offline Find More Posts by decastenza
Old Aug 09, 2011, 09:50 PM
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
If they didn't build it with external sense terminals, the sense lines must be connected internally. Look at the circuit board, where the sense terminals would be, if they were installed, to see if there are jumpers soldered to the + and - terminals. It could be a poor solder joint that has given up, and just needs re-soldering.
Sold Cosel 13 amp Power Supply Bill Hawthorne Aircraft - Electric - Batteries & Chargers (FS/W) 1 Oct 25, 2010 11:09 AM
Sold Cosel Power Supply 12V 13A 156watts $30 shipped/PP Yen Aircraft - Electric - Batteries & Chargers (FS/W) 2 Oct 13, 2010 09:04 PM
Alert Power Supply with FREE Power Bus - *SPECIAL* CSRC Tech Crew Batteries and Chargers 0 Sep 28, 2010 11:08 AM
FS: Cosel Power Supply with all the extras to finish modding almies Aircraft - Electric - Airplanes (FS/W) 1 Jun 14, 2004 04:44 AM
Need some help with this power Supply, Cosel K150AU 12 Pilot44 Batteries and Chargers 2 Dec 16, 2003 01:28 PM
