Old Jan 29, 2009, 09:38 PM
Joined Mar 2007
castle 80 esc w/BEC question
ok I just got my first castle speed controller to use with a reaper GR60 on my blue 55SHP..I have always used an airboss and you plug it in and go fly.now I am confused.Do I need a separate battery to go with my castle 80esc.I am was planning to use hitec 225mg's and a thunder power 4s 3850 battery.
I dont want this thing if I have to use a separate bec.an airboss 80 has it built in.can someone explain this to me ..
flapsdown is offline Find More Posts by flapsdown
Old Jan 29, 2009, 09:54 PM
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
How many servo's are using?
Some stuff here to read=
http://www.rcgroups.com/forums/showthread.php?t=991928
wellington53 is offline Find More Posts by wellington53
Old Jan 29, 2009, 10:08 PM
Joined Mar 2007
the plane has split elevator so I am using 5 hitec 225 mg's..
Old Jan 29, 2009, 10:10 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
If you are going to use more then 3s, regardless of how many servos you use you will need to use an external BEC. Some may get lucky and it may run for a small amount of time with the built in BEC at 14.8V, but its just a ticking time bomb. You should definately get something with a switching BEC or get an external one or a Rx battery pack
Thekid3418 is offline Find More Posts by Thekid3418
Old Jan 29, 2009, 11:05 PM
Joined Mar 2007
I guess I didnt understand the electronics of any plane beyond 47 inches.but learn I will if I intend to fly 55 inch planes.just something else to fuss with though the airboss 80 as far as I know doesnt need a switching bec for 4 s operations.
Old Jan 29, 2009, 11:55 PM
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
Now really, whats not to like?
Why do so many people fear seperate bec's? Presonally when I am cranking a ton of amps through an esc, the last thing I want to worry about is the internal heat shutting down power to my radio.
This issue is solved by the external bec! They used to solve this with a seperate battery but that was untill someone came up with the b.e.c. (battery elliminator circut).
It's just a better/safer way to fly!
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Wanted Castle Creations Phoenix-35 or 45+ ESC (w/bec) 3+ cells kctrading Aircraft - Electric - Power Systems (FS/W) 3 Apr 25, 2007 01:45 AM
Sold Castle Creation Phoenix 80 ESC/S-Bec Warren Aircraft - Electric - Airplanes (FS/W) 4 Jun 20, 2005 07:35 PM
FS New Aveox SL-48 ESC w BEC $150.00 mumblety-peg Aircraft - Electric - Airplanes (FS/W) 4 Jun 27, 2002 11:06 AM
servo esc w/motor question cjs Electric Plane Talk 1 Mar 04, 2002 02:46 AM
WTB: Inexpensive S400 ESC w/BEC falcon Aircraft - Electric - Airplanes (FS/W) 1 Oct 26, 2001 04:21 AM
