Old Apr 14, 2008, 06:09 PM
lurking above the clouds
Champaign, IL
Suggestions on 3-wire servos for SuperCub
Well, after discovering the frequency is bad for the stock radio gear at my rc club, I will "upgrade" with the old 72Mhz radio equipment (minus the gyro of course) from my HBCP2 until I hop on 2.4Ghz (the cp2 is grounded due to an ongoing BL upgrade anyway).
This not only gives me more channels to play with (maybe ailerons in the future) and a near drop in solution (switch prop for lower current draw), but the opportunity to switch to decent 3-wire servos.
Which servo's should I use? I don't need anything crazy expensive but something that I can count on.
nephewkp is offline Find More Posts by nephewkp
Old Apr 14, 2008, 06:31 PM
Wind blows
Laggard's Avatar
Minneapolis
Joined Jan 2007
http://64.33.154.92/blackdogrc/servos.jsp?c=9245392
Dynams. I use them with good success. There are lots of vendors out there selling similar servos at similar prices that will work well for you. You can also find HS55s for around $10 at times.
Laggard is offline Find More Posts by Laggard
Old Apr 14, 2008, 06:57 PM
WARNING: May contain spam
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
HS55 servos are some of the best 9 gram micros out there. Bite the bullet and buy a bunch of them. You will love them for any of your park flyers.
Xpress.. is online now Find More Posts by Xpress..
Old Apr 14, 2008, 09:14 PM
Livermore, CA
Joined Sep 2004
I use the GWS Picos and Naros, then the Hitec 55's in the 6-9g servo range. Then the UnitedHobbies HXT500 for my cheaper parkflyers and combat planes. Butch
Butch777 is online now Find More Posts by Butch777
Old Apr 14, 2008, 10:53 PM
Gunga-lunga, gunga-lunga
5280ducs's Avatar
Northglenn, CO
I put HS-55`s in mine. I just ordered some of these http://www.hobbycity.com/hobbycity/s...?idProduct=662 I dont know if they are junk yet but I couldnt pass up the price. The reviews on their website are comparing them to HS-55s. I guess I`ll find out
5280ducs is offline Find More Posts by 5280ducs
Old Apr 14, 2008, 11:09 PM
Wind blows
Laggard's Avatar
Minneapolis
Joined Jan 2007
I've heard complaints about the HS55s. Never heard a bad thing about the GWS pico and naros though.
Old Apr 15, 2008, 08:24 AM
Champaign, IL
well, it turns out my hbcp2 tx is the one without the dip switches to turn on ccpm...so I guess I will be getting a dx6i and a couple receivers this weekend (yay for the giveaway deal). must figure out which receivers I want to get though. I need one for the sc and one for my hbcp2 right away. I also plan on building a couple indoor foamies so I will want to get a receiver suitable for that too. if I pick the right two now, I will get two of the same for free.
Old Apr 15, 2008, 03:25 PM
BD Flyer's Avatar
United States, NJ, Monroe Township
Joined Aug 2006
I wouldn't go with HS-55's if I were you. I have heard WAY too many problems with them. Gears stripping while flying, noisy, twitchy, ect. I have and will always get the GWS Pico/Naros or Tower Pro SG90 servos for my parkflyers.
BD Flyer is offline Find More Posts by BD Flyer
Old Apr 15, 2008, 05:23 PM
yohoho and a keg of rum !
lebobbus's Avatar
try Eflite S75
that's how I upgraded my HZ planes
lebobbus is offline Find More Posts by lebobbus
Old Apr 15, 2008, 05:39 PM
ArsonDave's Avatar
Ventura County
Joined Jul 2007
Those are what I used in my SC. I have four in the plane. No issues at all, but I certainly am not stressing them too much with all of this blazing speed.
Dave
ArsonDave is offline Find More Posts by ArsonDave
Old Apr 15, 2008, 06:59 PM
Lexington SC
I used four of the 9g TowerPros from Jeff at HeadsupRc. Drop right in the slots in the fuse and fit nicely in the wing as well.
http://cgi.ebay.com/FOUR-SERVOS-TP-S...742.m153.l1262
$31 shipped for all 4.
NightTrain0128 is offline Find More Posts by NightTrain0128
Old Apr 16, 2008, 12:29 PM
Champaign, IL
Well, I picked up a dx7 off the sales forums for cheap so I now need to get a rx (probably an ar6200) , 20 amp brushed ESC (any recommendations?), and a set of servos maybe SG90's. On 3s lipo power, I assume I will need a bec (or one built into the esc) since the receiver max voltage is 9.6v and 3s is 11.1v. I guess the SC doesn't care about weight too much, so maybe using the receiver batt won't be an issue.
Old Apr 16, 2008, 01:12 PM
Lexington SC
You can usually snag a Pixie 20A ESC off the forums for around $15. It will come with a BEC that is advertised as capable of running 3 servos but I run 4 with mine and haven't had any problems. You don't need an external Rx battery.
Old Apr 16, 2008, 03:01 PM
BD Flyer's Avatar
Joined Aug 2006
Like said above, you can get a Castle Creations Pixie 20 for around $15-$20 on the forums here. Also, if you make a wanted thread asking for SG90 servos, people will usually sell 4 for $20-$23. And same with the receiver. People usually sell them on the forums here for less than retail price.
Old Apr 16, 2008, 04:42 PM
Champaign, IL
Thanks! I will see what I can dig up from the sale forums.
Discussion Advice on selection of Servos for Corona 120 johnhi30 Electric Heli Talk 7 Jan 16, 2007 04:22 PM
Advice on V-Tail servos for 2M molded. gomezdh Slope 6 Dec 01, 2005 05:57 PM
Anyone using the Hyperion 3.7g servos for 3D? surfimp 3D Flying 4 Oct 04, 2005 07:12 PM
Yippee! BlueArrow 3.6 servos for sale FHHOBBIES Aircraft - General - Radio Equipment (FS/W) 11 Feb 02, 2005 06:01 PM
Looking for suggestions on motor/gear setup for Kyosho Stratus 1600 PDX Slope Pilot Electric Sailplanes 3 Aug 21, 2002 09:50 PM
