Old May 21, 2013, 04:29 PM
Wamp's Avatar
Joined Mar 2012
Originally Posted by xsputnikx View Post
But the kit will continue to be available right ?
I hope so.
The covering job on my ARF is far better than I can pull off.
But the colours do not help me in orientation.
I did build a kit into an ARF
But have no guts for it.
No prop saver this time!
I considered the ARF a compliet bargain, Thanks Chris
Wamp is offline Find More Posts by Wamp
Old May 21, 2013, 04:50 PM
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Yes
jkarpy is offline Find More Posts by jkarpy
Old Jul 06, 2013, 02:51 PM
Joined Jul 2012
I finally finished up my micro ssx and wanted to share. I still have to save up for a tx and rx but I built mine trainer style to be a lil more user friendly
Description:
xsputnikx is offline Find More Posts by xsputnikx
Old Nov 17, 2013, 10:56 PM
ids911
ids911's Avatar
GA
Joined Jan 2009
Got my second kit from James in Thursdays mail, built by late Friday evening and maiden'ed 4 flights on Saturday morning. My first one had lasted a couple of years before a mishap (operator error!) This second flew without needing any trim adjustments!. The second and subsequent flights were launches off the back of the truck bed into an immediate corkscrew, everyone was in awe of that!. Enjoyed every minute of flying low, slow and crazy! She's a beaut! Will try to get video next time out.
James, thanks for a great design & kit
Ian
ids911 is offline Find More Posts by ids911
Old Nov 21, 2013, 05:28 PM
Wamp's Avatar
Joined Mar 2012
Ian
SSX got so much attention at my new club, I printed out the particulars.
We fly off grass. I keep hearing , that does not waste any runway!, what us it?
Old Dec 20, 2013, 12:22 AM
Soaring Fanatic!
Joined Dec 2008
Great thread!
I'm 50% on my ARF MSSX and need a little help w/ assembling all the pieces to the fuse with the Incidence adjustment. Does anyone have a photo of all the components attached to the carbon tube?
Or is this adjustment only for the SSX Bipe?
Looks like the landing gear should be fixed to the battery tray/firewall to allow the incidence adjustment to move freely on the fuse.
Lastly, I've noticed that the rod in my kit is pultruded; whereas many of the photos on this thread appear to have "wrapped" fishing rod style booms. Where can I get those and will they save weight?
8thelephant is offline Find More Posts by 8thelephant
Old Dec 20, 2013, 02:53 PM
Wamp's Avatar
Joined Mar 2012
Originally Posted by 8thelephant View Post
Great thread!
Hey SSX is a blast!
The angle of incidence was set in the kit and ARF units I have.
I used servo horns as control rod guides, which got things running
smoothly.
I used thick rubberized ca liberally around the motor mount and gear.
SSX almost does a vertical take off and harrier lands.
Yup I keep hearing that does not waste any runway at the field!
Old Dec 20, 2013, 03:19 PM
Wamp's Avatar
Joined Mar 2012
Here is what the guides look like.
They took a few trys for length and placement.
Cut the hubs and file to fit.
Old Dec 20, 2013, 05:07 PM
Soaring Fanatic!
Joined Dec 2008
Thanks Wamp!
Your Servo Arms are a great solution. Looks like the incidence adjustment is really for the Bipe only (which I'll start building later too) so this really clears things up for me. Can't wait to get this one in the air since the sun's out in my neck of the woods
Old Dec 20, 2013, 05:55 PM
Wamp's Avatar
Joined Mar 2012
Thanks Wamp!
Good news!
The bipe! Cool.
Make sure the battery in on tight, or you may be tea bagging!
I did break the rear wing mount in a high G maneuver.
SSX got back tea bagging with wings rocking, full up E, no other real damage!
No sun here lately
Old Dec 23, 2013, 09:49 AM
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Thanks Wamp!
The incidence adjustment was added to the MSSX Kit and ARF. It just there to help insure the final adjustment is set to 0. If you want to fly slower and do not care about inverted performance, you can add some positive incidence.
I used to provide the spiral wrapped fuselage but my source raised the price too much.
James
Old Dec 23, 2013, 09:54 AM
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
wrapped fuselage
You can but the spiral wrapped fuselage material at Goodwinds kites. It is the .198 XL breeze. one piece makes 2 fuselages. Yes it is a little lighter.
https://goodwinds.com/carbon/wrapped/g-force/20204.html
Old Dec 25, 2013, 03:15 PM
Soaring Fanatic!
Joined Dec 2008
James
Thanks James!
So an incidence of "0" would be right in the center?
I'll go order the tube and use it for the MSSX & MBipe
Old Dec 26, 2013, 11:16 AM
Wamp's Avatar
Joined Mar 2012
James
Interesting, been thinking of tinkering with the angle of my incidence on another build.
Thanks for keeping your ear to the ground here.
Thinking about your 3D unit come spring.
SSX is a hit! Chris
Old Dec 26, 2013, 05:41 PM
Soaring Fanatic!
Joined Dec 2008
Wrapped Carbon Tubes!
Ok, it looks like each tube is $11.50 ea. + $7 shipping which makes 2 fuselages for the MSSX.
I'm wondering anyone interested in a group buy since there are qty discounts?
Price drops to about $10 ea. with 12 or more tubes, and shipping is still ard $7. So I figure if cut them down to size and ship them, shipping might be less per unit.
Micro Hydroplane Build Attemp thailandboy2 Racing Boats - Electric 28 Apr 17, 2010 08:23 PM
Micro speedwing build schoey Foamies (Kits) 46 Aug 08, 2005 11:22 AM
another Micro IFO build richw286 Parkflyers 19 Feb 24, 2005 12:05 PM
House of Balsa Micro Cub Build OCModels Parkflyers 52 Aug 29, 2003 11:47 PM
Micro-light Build Questiions DLC Parkflyers 5 Jun 22, 2001 03:17 PM
