Closed Thread
Old Oct 05, 2014, 10:33 PM
Carlsbad, CA
Joined Sep 2004
Electric Airboat in Salt Water
Hi all,
How do you protect an outrunner and ESC from saltwater damage in an airboat configuration? I have a set of Multiplex Mentor floats and will either sell them or make them into an airboat like RC boat similar to this craft on Youtube. I plan to run this b oat at the RC boat basin in Mission bay (San Diego); salt water.
I did a search and could not find a definite answer. Most posts are for float planes over fresh water, or else boats with the engine inside the hull running on salt and fresh water. Some posts talk about WD-40 or Corrosion X; some posts say flatly, don't run electronics in salt water.
My concern is protecting the bearing, winding (magnet wire) and magnets/adhesive from saltwater corrosion as well as the ESC since it would have to be exposed to the airflow for cooling.
Sprengboot Tornado 1:13 (5 min 11 sec)
rockbus is offline Find More Posts by rockbus
Old Oct 05, 2014, 11:45 PM
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
That is cool.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Oct 06, 2014, 05:03 AM
Blackpool, Lancs
Joined Feb 2006
The answer is basic regular servicing, ie after each session. Oil bearings, check protective surfaces.
The coils themselves are insulated with a layer of enamel, so worries there. The ends, however are likely bare solder, this will benefit from protection.
Other electronics are best kept in a waterproof container. Whether it is a compartment designed into the boat or an added box is unimportant. Salt water corrodes metal, it does nothing whatever to plastic
mfr02 is offline Find More Posts by mfr02
Old Oct 06, 2014, 07:14 AM
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
A fresh water rinse after every run as well. Electronics need to be kept in a watertight enclosure, the motor will handle a dunking as long as its rinsed off and the bearings get a drop of oil, Buy cheap motors and replace them as nessesary, I think the fun will wear off before the motor fails though
nick_75au is offline Find More Posts by nick_75au
Old Oct 06, 2014, 12:12 PM
Carlsbad, CA
Joined Sep 2004
Thank you for the replies.
If I place the ESC in a plastic box how well will it work w.r.t. cooling? I expect to run 400 watts.
Old Oct 07, 2014, 03:02 AM
nick_75au's Avatar
Joined Mar 2007
Get a bigger ESC than what you need, weight is less of an issue in surface craft I've run 30 Amp escs with the motor drawing about 15 fully enclosed with no ill effects
Old Oct 08, 2014, 01:17 PM
Carlsbad, CA
Joined Sep 2004
Thanks for the suggestion about running a large ESC.
I'll have to do a test.
Closed Thread
Question RTR Southampton Tug Boat - ok to run in salt water? steven.mcmeechan Scale Boats 8 Sep 16, 2014 05:46 AM
Discussion RC boat in salt water? pricelessppp Dock Talk 5 Aug 23, 2014 12:00 AM
Discussion Salt Water pool reception???? JIMJAM Submarines 4 Jan 04, 2014 01:26 PM
Discussion Do you run in salt water? Who is in there with you. Prins Willem Dock Talk 29 Nov 14, 2009 01:46 PM
How should I poke a hole in the lipo cell when I want to drain it in salt water? Lynxman Batteries and Chargers 32 Nov 05, 2004 03:01 PM
