Old Oct 01, 2014, 01:11 PM
shimsham's Avatar
Joined Nov 2009
Spektrum Dx7s
Having trouble with my DX7S I cannot get it to bind with my Rxs, I have tried it with Ar 6200. AR 500 AR 600, sent it to H.H. here in the UK they had some tests run but they could find nothing wrong with it,but to be on the safe side they put another RF board in,came back yesterday tried the same Rxs again it would not bind,but I tried a Orange Rx and it bound,but the rudder,elevator,were the only two control services that would work,so I changed the esc for another one but this one wouldn't work,any of you guys had this happen to you ?
The Tx is now on its way back to H.H.
shimsham is offline Find More Posts by shimsham
Old Oct 01, 2014, 01:17 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Usually ESC arming problems are due to not adjusting the throttle trim all the way down.
You should have 2m between tx and rx when binding.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Oct 01, 2014, 01:51 PM
shimsham's Avatar
Joined Nov 2009
Hi Andy thanks for reply, I always stand about 6ft-10ft when binding
Old Oct 01, 2014, 01:53 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Send in the receivers you have trouble with.
Better idea might be to make a video of what you're doing so that Customer Support/Service can see it and understand what you're doing. Lots of guys here would be happy to help if you did that too.
Andy
Site Sponsor
Old Oct 01, 2014, 02:13 PM
shimsham's Avatar
Joined Nov 2009
Andy thanks again for replying,but I don't have any gear to make videos,the old pension won't run to things like that.
Old Oct 01, 2014, 02:16 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Got a friend with a digital camera or smart phone? Usually those will make videos.
Site Sponsor
shimsham's Avatar
Joined Nov 2009
Andy. Forgot to mention I have had this Dx7 from new, I would think I would have a rough idea how to bind it by now.
Regards
Old Oct 01, 2014, 02:18 PM
shimsham's Avatar
Joined Nov 2009
Andy. I will wait to see what HH come back with, I do have a digital camera.
Old Oct 01, 2014, 02:36 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
A couple ideas, but you probably already checked them:
1) Bad bind plug? If it's not making good contact that would be a problem.
2) Battery plugged in backwards? Sometimes this will get the LED blinking but it won't be able to complete the bind.
3) Bind plug in the wrong hole? (Usually this only happens with 2-row receivers).
Oh, that makes me wonder. Are the receivers blinking properly in bind mode?
Andy
Site Sponsor
Old Oct 01, 2014, 02:40 PM
I just want to fly
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
Does the ESC ever make the beeps indicating the cell count of the batteries?
If not calibrate the ESC or run the throttle trim down to see if that does it.
What beeps do you here when the flight battery is connected?
Rhea is offline Find More Posts by Rhea
Old Oct 01, 2014, 03:05 PM
shimsham's Avatar
Joined Nov 2009
[QUOTE=Rhea;29579472]Does the ESC ever make the beeps indicating the cell count of the batteries?
What beeps do you here when the flight battery is connected?[/QUOT
Normally it's 3 beeps, but I have noticed on one of the rcs that when it's binding the flashing light does not seem very bright,don't know whether as any bearing on the problem.
Old Oct 01, 2014, 03:10 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Yes, that would be a good indication that it is not powered properly.
Andy
Site Sponsor
Old Oct 02, 2014, 05:06 PM
shimsham's Avatar
Joined Nov 2009
Andy,Took delivery of the DX 9 today,was getting on with it pretty well tonight,but have you any idea how to register it,I have spent the best of 3 hours trying to figure out you do it,which is the serial number the one on the top,or is it the whole lot of them in the radio under serial number.
Colin
Old Oct 02, 2014, 05:10 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Go to the Serial Number screen. You can get there by select System Settings. Click NEXT several times.
Put an SD card in the radio. Highlight the word EXPORT and click.
That writes a file to the card. Pull the card out, put it in your PC. Open the file My_DX9.xml using Notepad. Highlight and Copy (Ctrl C) the section that matches the serial number on the display.
On your Community page, paste that serial into the web.
Andy
Site Sponsor
Old Oct 02, 2014, 05:31 PM
shimsham's Avatar
Joined Nov 2009
Andy. The dx7 is on its way back to HH at their request,when the Dx 9 arrived today I put the three Rxs with the same battery,and everything worked no problem binding.
Sold Spektrum DX7s with Spektrum 4000 lipo M Carr Aircraft - General - Radio Equipment (FS/W) 1 Nov 02, 2013 12:32 AM
Sold Spektrum DX7S, Spektrum AR7010 w/Sat jprochnow Aircraft - General - Radio Equipment (FS/W) 1 Oct 18, 2013 11:06 PM
Sold dx8 dx9 dx6 dx7s dx7 Spektrum transmitter case 1flyguy Aircraft - General - Radio Equipment (FS/W) 0 Oct 01, 2013 10:44 PM
For Sale Spektrum DX7s with Spektrum 4000 lipo M Carr Aircraft - General - Radio Equipment (FS/W) 0 Sep 28, 2013 04:45 PM
Sold Spektrum DX7s and Spektrum Receivers apiazza2010 Aircraft - General - Radio Equipment (FS/W) 1 Sep 24, 2013 08:19 PM
