This thread is privately moderated by Spadplanter, who may elect to delete unwanted replies.
Old Jun 28, 2013, 04:01 AM
Spaderman's Avatar
France, PCh, Puy-du-Lac
Joined Mar 2010
Hello
Plans are here Baby Blender Original Dépron
Spaderman is offline Find More Posts by Spaderman
Old Jun 28, 2013, 04:26 AM
N00b Sloper Addict
Parkflyer81's Avatar
Australia, TAS, Brighton
Joined Dec 2005
Thanks mate
Parkflyer81 is offline Find More Posts by Parkflyer81
Old Jul 09, 2013, 03:47 PM
Extreme Sports's Avatar
South Africa, GP, Johannesburg
Joined May 2012
Lightweight corro cub
Here is the lastest addition to my lightweight correx park flying collection.
Span: 1m (~40")
AUW: 450g
Power: E-max 2812 with 7x6 prop and 800mAh 3S Lipo
Construction: 2mm correx with foam fuselage formers, balsa wing ribs and CF spar. Plus some other odd bits and pieces found in my garage. I've tried to keep it as close to scale as possible without losing the simplicity of SPAD.
Would be 20g lighter if we could get yellow 2mm correx here.
Flight is stable and slow, just as a Piper Cub should be - perfect for the local park. Takes off from grass on not much more than 50% throttle and cruises happily on 25%.
Extreme Sports is offline Find More Posts by Extreme Sports
Old Jul 10, 2013, 06:11 AM
Glow? What is that?
South Africa, FS, Bloemfontein
Joined Apr 2009
Span: 1m (~40")
AUW: 450g
Mate congrats!!!
That is just awesome!!
Any chance u can share plans??
Pretty please?
Blizards316 is offline Find More Posts by Blizards316
Old Jul 10, 2013, 02:31 PM
Spaderman's Avatar
Joined Mar 2010
Nice work !
and congratulations for 450gr !.....
Old Jul 24, 2013, 02:52 PM
Spaderman's Avatar
Joined Mar 2010
Hello all
The youngest to the banner
Construction with sandwich method Coro Foam
Env : 1100mm
Engine : .32
Propeler : Master 9.5x6
Weight : 1100grs
Soon
Old Aug 03, 2013, 07:21 AM
Joined May 2012
Twin corro parkflyer
Here's the latest experiment. Its basically a Partenavia P68 with a Twin Otter front end (the P68 front does not do it for me and the Twin Otter has struts and complex engine nacelles, so took the simplest elements from both!).
Used to test a few concepts that have been at the back of my mind for a while:
  • Folded wing trailing edge for neater ailerons (big improvement on the conventional method)
  • Large flaps to improve landing performance (works very well)
  • Castoring nosewheel and differential motor thrust for ground handling (works like a charm)
  • Complex curves on fuselage (still needs some refinement)
All 2mm correx but with 3mm foamboard empennage and scrap foam formers.
Maiden this am went very well - very stable and able to fly far slower than my similar sized Mig7 and Spitfire. Power to spare.
Specs for maiden flight:
  • Span: 1.25m
  • AUW: 875g
  • Power: 2x Emax2812 with 8x4 counter-rotating props and 1300mAh Lipo
  • Wing loading: 10.4oz/sqft
  • CWL: 6.0.
Old Aug 03, 2013, 09:12 AM
Envies his own avatar
rockyabq's Avatar
Albuquerque, NM
Joined May 2008
It's so sleek it looks like it came from an ARF kit!
rockyabq is online now Find More Posts by rockyabq
Old Aug 03, 2013, 09:26 AM
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
Very nice! Can you explain more about your aileron build method?
Flying Beagle is offline Find More Posts by Flying Beagle
Old Aug 04, 2013, 05:20 PM
Joined May 2012
Thanks. See http://www.rcgroups.com/forums/showt...8#post25755955 for details
Old Aug 07, 2013, 10:24 PM
Joined Mar 2013
Electric V-tail Gnat
This is my first attempt at any kind scratch build or spad. I based the design off a Gnat. Built from extra parts I had laying around. Fuse is 26" 1/2x1/2x1/16 aluminum angle, motor mount is 1 1/2 angle, and landing gear wire from a PZ Extra 300. Powered by 3536 Turingy POS electric motor...lol. Come Saturday we'll see if it flys or dies! I predict it will fly about as good as a boat anchor. Whatever? It's cool!
TX_FLYER is offline Find More Posts by TX_FLYER
Old Aug 08, 2013, 12:00 AM
rockyabq's Avatar
Albuquerque, NM
Joined May 2008
It may surprise you, good luck!
Old Aug 08, 2013, 10:10 AM
Canada, ON, Cottam
Joined Jan 2012
CNC milled motor mount??
aspeed is offline Find More Posts by aspeed
Old Aug 08, 2013, 10:12 AM
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Looks like pretty high incidence on the wing. Be careful for ballooning when you take off.
JohnsPop is offline Find More Posts by JohnsPop
Old Aug 11, 2013, 08:13 PM
Joined Mar 2013
It is a 1.5" length piece of 1.5"x1.5"x.125" aluminum angle. First I mapped and drilled hole pattern to match the motor, also counter sunk the holes. Then cut off the excess material on one end and rounded the other end on a belt sander.
Gallery Let's see your boats flailing Scale Boats 257 Mar 08, 2012 02:38 PM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 06:44 PM
Let's see your pilots! DennisG Electric Plane Talk 39 Jun 09, 2003 07:05 AM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 08, 2002 12:00 AM
Hey Doug! Let's see a T-6 Texan!!! CheeseWing Parkflyers 9 Oct 13, 2002 02:51 PM
