Old Apr 06, 2014, 02:09 AM
leadpan's Avatar
United States, CA, Eastvale
Joined Sep 2007
Edge 540 at airshow
At airshow with my son and saw two planes that caught my eyes.
One was Edge 540 doing amazing maneuvers. So now I want one! Which brand/style is a good Edge 540 to get? Looking for large (44" or bigger).
Finally, what plane is the second photo?
leadpan is offline Find More Posts by leadpan
Old Apr 06, 2014, 02:27 AM
Build carefully, fly reckless!
United States, CA, Portola Valley
Joined Aug 2013
That's Patty Wagstaff's Edge 540!
Charlie Tilney is offline Find More Posts by Charlie Tilney
Old Apr 06, 2014, 02:55 AM
departure from controlled flt
airportdog's Avatar
SF Bay Area
Second picture is an Extra 300L.
airportdog is offline Find More Posts by airportdog
Old Apr 06, 2014, 02:58 AM
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
This one ain't bad:
http://www.rcgroups.com/forums/showthread.php?t=1343213
http://www.extremeflightrc.com/html/60Edge.html
Depronicus is offline Find More Posts by Depronicus
Old Apr 06, 2014, 03:11 AM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
??? ...unsure about that. has "PEMBERTON" (which happens to be the pilot's name) written on the left hand wing
Pic 1) Melissa Pemberton's recently-ish repainted Edge
Pic 2) Extra 300L as airportdog mentions. N512DW... I don't think it's Patty's. Looks to be the gent in the flight suit standing in front of it.
If you want one that looks like the Edge pictured (single place canopy at least), and performs in the upper regions of "awesome"...
http://www.3dhobbyshop.com/58-Edge-5...d_p_16081.html
Another view of Melissa's Edge:
theKM is offline Find More Posts by theKM
Old Apr 06, 2014, 04:00 AM
Joined Aug 2013
Oooooops yes, Melissa came to perform once at Tahoe…Now I remember! Sorry for false info guys
Old Apr 06, 2014, 04:02 AM
Joined Aug 2013
I like the 48" a little better because of transportation issues and not being pricy….Those 60" birds get super expensive
http://www.extremeflightrc.com/html/48edge.html
Old Apr 06, 2014, 07:45 AM
United States, NC, Smithfield
Joined Jul 2012
Out of curiosity is there a reason for the pinocchio type spinners on aerobatic aircraft?
Brush Hog is online now Find More Posts by Brush Hog
Old Apr 06, 2014, 09:18 AM
I fly. I'm pilot.
GravyRobber's Avatar
United States, TN, Memphis
Joined Oct 2012
They have to cover the prop governor.
GravyRobber is offline Find More Posts by GravyRobber
Old Apr 06, 2014, 09:28 AM
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
Well that just lead to an interesting few minutes googling and reading. From what I found it seems that the actual governor is back on the engine, and what's up in the hub/ spinner area is just the mechanism for feathering the blades?
AeroKen is online now Find More Posts by AeroKen
Old Apr 06, 2014, 10:46 AM
iumop ap!sdn w,I
G.P.'s Avatar
Joined May 2005
Correct. There is a piston inside the prop hub. Oil is ported through the crankshaft to move the piston in the hub one way or the other, which moves the blades.
The spinner does look unproportionally large though. I think it's that the airframe is small for such a large engine and prop.
G.P. is offline Find More Posts by G.P.
Old Apr 06, 2014, 11:21 AM
Komet ME163's Avatar
E TN
Joined Jan 2003
you also have to consider which type prop they are running affects spinner areas, wether McCauley, Hartzell, MT and that hartzell props have a counter weight arm on blade that has to move inside spinner as prop transtions. The propellers most single engine planes run is controllable but not full feathering, only high and low pitch. Unless it is a turbine engine, then full feathering and reversible.
Bill
Also prop governors are what control prop movement by controlling oil flow to prop, uses speeder spring set up in side housing for rpm control. All prop governors are engine mounted accessories either up front on crankcase or rear mounted on acessorie pad
Komet ME163 is offline Find More Posts by Komet ME163
Old Apr 06, 2014, 12:05 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
All these planes look naked without SFGs!
Doc Austin is offline Find More Posts by Doc Austin
Old Apr 06, 2014, 12:19 PM
The Best or Nothing
RustyT3FT's Avatar
United States, IN, Fort Wayne
Joined Feb 2008
3DHS 48" Edge. It introduced me into 3D and balsa
RustyT3FT is offline Find More Posts by RustyT3FT
Old Apr 06, 2014, 07:57 PM
Australia, QLD, Ipswich
Joined Sep 2008
Her old paint scheme was cooler I reckon.
http://jetphotos.net/showphotos.php?regsearch=N540SG
luke352 is offline Find More Posts by luke352
Video 1945 Airshow at Freeman Field, Seymour Indiana Dennis Sumner Scale Kit/Scratch Built 2 Jan 30, 2014 10:55 PM
Discussion Looking for a nice large scale P-38 model to display at an airshow in LA county Thomas B Scale Fuel Planes 4 Jan 10, 2014 09:11 AM
Video RC Jet Demonstration at the 2013 Alliance Airshow Fort Worth, TX FinalApproachRC Jet Turbines 2 Nov 30, 2013 02:59 AM
Sig Senior and Edge 540 for sale at Triad fly in Steve H. Aircraft - Electric - Airplanes (FS/W) 8 Apr 29, 2002 12:09 AM
