Old Oct 29, 2014, 02:51 PM
Expat
Japan
Joined Apr 2010
I just wanted to confirm I was able to get in touch with Wayne from Aloft Hobbies, and he went way out of his way to try and help me, which was great.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Oct 29, 2014, 03:08 PM
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Originally Posted by TheNiceGuy View Post
............ I sent 2 dfts and 2 d8rxps back 3 months ago to be checked. ..................
Why did they all have to be checked? What was wrong with them?
Jim.Thompson is online now Find More Posts by Jim.Thompson
Latest blog entry: Regulated vacuum system.
Old Nov 20, 2014, 04:46 PM
United Kingdom, Devon
Joined Jul 2012
GPS V2 Sensor
I have a FrSky GPS V2 Sensor with S.Port . I know it works with XR receivers but can I connect it to D4R-II 4 ?
Turbiner is offline Find More Posts by Turbiner
Old Nov 20, 2014, 06:16 PM
yorkshire UK
Joined Oct 2007
I think its possible with the hub and some soldering , instructions are on frsky forum some where.
nigelsheffield is online now Find More Posts by nigelsheffield
Old Nov 21, 2014, 02:14 AM
Bulgaria, Sofia-city, Sofia
Joined Oct 2013
Here you go..
angel4o is offline Find More Posts by angel4o
Old Yesterday, 02:42 PM
Fedor48's Avatar
The Netherlands, NH, IJmuiden
Joined Jun 2014
Telemetry through sbus not showing on my display
I am lost, so in need of some help. I'm getting very frustrated here and have to stop searching and ask for some help before I throw ALLLL my Frsky crap in the bin.
I'm trying to get my Frsky telemetry to work. This is my setup:
9XR with DJT module (both switches to off)
X8R
FLVSS smart lipo sensor
S.port GPS sensor V2
FLD-02 display (rev 2.1)
The X8R is bound to the DJT and the only thing that I can read on the display is the RSSI and the voltage that powers the X8R.
Both the FLVSS and the GPS don't show up on the display.
What am I doing wrong or overlooking?? Thanks in advance!
Name: 2014-11-22 19.07.12.jpg
Description:
Name: 2014-11-22 19.07.35.jpg
Description:
Name: 2014-11-22 19.08.14.jpg
Description:
Fedor48 is offline Find More Posts by Fedor48
Old Yesterday, 03:45 PM
Romania, Dolj, Craiova
Joined Sep 2007
Should be expected that FLD-02 don't display telemetry over s-port (not s-bus ) being a generation before s-port advent.
renatoa is online now Find More Posts by renatoa
Old Yesterday, 04:16 PM
showmaster's Avatar
Joined Aug 2006
FrSky 2.4ghz - looking good so far!
A 9xr pro and a XJT module would do it all with your X receiver. No external display and you're getting voice, haptic, sd card and more memory and model memories. Probably not the answer your looking for but if you spend $28 for a D receiver and also buy the hub, you're on your way to a pro. I'm not sure the newer GPS works with the hub, I'm using the original one that's been discontinued. The HK pro fully supports the XJT and X and D receivers, s-port and hub sensors. No more beeps or looking at the display, you'll actually hear the value spoken.
Either way you're in a fix, for a fix. You'll have to throw some $ at it to solve you're dilemma.
My suggestion is a 9xr pro if you're used to the 9XRs setup/feel, or a Taranis and really enjoy the RC experience they both have to offer if it's in your budget.
Been there, done that!
showmaster is online now Find More Posts by showmaster
Old Today, 08:26 AM
Joined Jul 2011
We all wait for the SmartDisplay...
michel49 is offline Find More Posts by michel49
Old Today, 12:11 PM
Joined Sep 2007
Better lobby Frsky to make public the FLD-02 innards, will see better open source software giving a new life to this little box.
Old Today, 02:27 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Has anyone had any issues with the new X4R receiver?
I've got one on a slope plane that worked fine for a half dozen flights as far as 1800ft away,
and then suddenly it started complaining about low RSSI as little as 70ft away.
Rebound with no improvement. No crashes. Antenna connectors are seated correctly.
Replaced with an old D8R-II and full range is back.
Daemon is online now Find More Posts by Daemon
Old Today, 04:31 PM
Australia, VIC, Melbourne
Joined Nov 2006
Log your TX data - to see the RSSI data it received back.
Check over that log/chart for a start, to get some more detailed info on what is exactly happening. That may, or may not, help a lot.... but at least do that for a start.
You could possibly just do it with the RX out of a plane, seeing you changed it out. just make a simple setup to place some across a park so you can move away and check distances.
PeterVRC is online now Find More Posts by PeterVRC
Latest blog entry: Skyzone Goggles - Button Shield
Old Today, 05:16 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I don't have to log it, to see that the RSSI value is extremely low now. Only
have to walk away from the plane a few yards and it starts to drop dramatically.
Have already tested it out of the plane. Guess it's just a defective Rx.
I was just wondering if anyone else has run into this with this specific model,
as I don't want to replace it and run into the same thing.
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 02:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 07:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 01:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 08:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 02:25 AM
