Old Dec 31, 2011, 01:47 PM
Tcragun56's Avatar
Joined Mar 2011
Dx6i Battery Questions?
Alright so i recently bought a dx6i and i love it so far but i have been really worried about lots of things regarding the battery. I have honestly researched this topic a lot and have gotten so many different opinions that i just don't know which one to agree with so i am going to throw all my questions i have out there. ok so i have the original spektrum batteries and charger. How long do you need to charge those to get a full charge and how long is too long that will damage the battery? What is the safe voltage that you can fly down to? (this is my hardest question that i have been really trying to figure out for a long time)? how often do i need to fully discharge the batteries (and how much do you discharge them? like do i just keep the radio on till it dies or what?) and my last question is that i am going to get some sanyo eneloop batteries soon and i am wondering if i can use my original charger that came with my dx6i and how long do i have to charge them for?
sorry that i may sound frazzled but i just want to make sure i do the best thing for my dx6i to make it last as long as possible!
Tucker
Tcragun56 is offline Find More Posts by Tcragun56
Old Dec 31, 2011, 04:24 PM
flydiver's Avatar
Seattle, WA
Joined Jan 2007
1. With the wall wart charger leave it on as long as you want, no damage will occur. Overnight is generally fine and plenty. If the batteries are fully discharged (that does NOT mean DEAD!), it'll take ~15 hours.
When batteries become warm, they are charged.
2. You don't ever need to fully discharge the batteries, EVER, EVER. This is OLD and FALSE information.
http://www.dansdata.com/gz011.htm
3. Read the manual. It states clearly what low voltage alarm is.
4. You CAN absolutely use Eneloops, and I suggest them, just plain better batteries. My experience with Spektrum 1500mA was poor. More capacity with Eneloops, therefore takes longer to fill with the original wall wart IF you discharge the to low voltage. You'll also get more run time. Charging > leave on the wall wart if you want but overnight is generally all you need unless you have really discharged them (forgot the TX on over night or something).
Last-Do NOT expect the guage on the screen to EVER show them as full, even when freshly charged. The screen 'gas guage' is calibrated for alkaline so is not accurate at the top for NiMh.
Now, let the confusing/conflicting opinions begin.
Why do you think you'll get better answers this time?
flydiver is offline Find More Posts by flydiver
Old Dec 31, 2011, 04:34 PM
Tcragun56's Avatar
Joined Mar 2011
Honestly that was PERFECT! Thank you so much. Its just nice because i finally got to explain MY situation instead of looking at other peoples. So thanks again, you really did clear up my main questions that were worrying me!
Thanks Again,
Tucker
Old Dec 31, 2011, 05:14 PM
Tampa,Fl
United States, FL, Tampa
Joined Jan 2007
The Manual says it sounds an alarm when it reaches 4.1V I put mine on the charger the night before I fly. and I fly a lot !!! two or three different birds. and Mine starts out at 5.7V and I never see it below 5.4 No Worries.
And I am using the same spektrum re-chargable Batteries that came with it.
Dale 813 is offline Find More Posts by Dale 813
Old Mar 14, 2012, 10:25 PM
United States, FL, Miami
Joined Sep 2011
sorry to post on an old thread, but i was just wondering if you recommended getting the 2500 mah eneloops, or the 200mah ones?
http://www.amazon.com/Sanyo-eneloop-.../dp/B004UG41W8
mat3415 is offline Find More Posts by mat3415
Old Mar 15, 2012, 01:42 AM
flydiver's Avatar
Seattle, WA
Joined Jan 2007
I've only got experience with the original 2000mA ones.
Likely either one would be fine. This single opinion seems like it's a viable review. If you do some searching you can probably find more. Read the first review, or as many as you see fit.
http://picasaweb.google.com/10546238...T06OxBz7AdqChw
Old Mar 15, 2012, 02:11 AM
Melbourne
Joined Aug 2010
I recently did some testing in my DX6i
1500 cycle version (2000mah)
21.5 hours to hit alarm at 4.1v
500 cycle version XX (2500 mah)
26.5 hours to hit alarm at 4.1v
Cheers
crusey_aus is offline Find More Posts by crusey_aus
Old Mar 15, 2012, 02:18 AM
flydiver's Avatar
Seattle, WA
Joined Jan 2007
What's the (supposed) difference in discharge rate for those that may have long breaks between uses?
Old Mar 15, 2012, 06:31 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Do you mean the difference in long term self-discharge?
Originals 1000 cycle onbe rretain 80% for 2 years
New 1500 cycle ones retain 75% for 3 years.
Higher capacity (25000?) ones do not maintain charge as well long term ,mostly just better if yo use in real high drain electronic - camera flash ,high drain flashlights, kid's toys and such.
Charles
Old Mar 15, 2012, 08:35 AM
Joined Sep 2011
On amazon, it says that the 2500mah "Batteries maintain 75% of charge after 1 year of non-use"...
Old Mar 15, 2012, 08:48 AM
Left Coast DJ's Avatar
Joined Jan 2012
Can Eneloops be charged while in the DX6i using the plug-in charger that came with the DX6i?
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Mar 15, 2012, 10:59 AM
flydiver's Avatar
Seattle, WA
Joined Jan 2007
Yes, they are just NiMh and that's what the charging system was designed for.
Old Mar 15, 2012, 11:37 AM
Joined Sep 2011
how long would each type (2000 and 2500) have to charge for if using the plug in charger?
Old Mar 15, 2012, 11:57 AM
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
That would depend on the current state of charge, and the amp capability of the charger itself.
With the wall wart style a good over night charge cycle should be good.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Mar 15, 2012, 12:07 PM
seefest's Avatar
United States, MA, Bristol
Joined Sep 2009
Interesting reading about discharge rates.
http://www.stefanv.com/electronics/l...discharge.html
seefest is offline Find More Posts by seefest
Discussion Force RC and MSR X with DX6i Questions Wingbreaker Beginner Training Area (Heli-Electric) 0 Dec 27, 2011 07:41 PM
Discussion Spektrum DX6i questions desertmedic Radios 3 Oct 23, 2011 10:19 AM
Discussion Noob questions about the DX6i tendonut Electric Plane Talk 8 Oct 01, 2011 09:17 AM
Discussion DSMX / DX6i Questions Tcragun56 Beginner Training Area (Aircraft-Electric) 4 Apr 21, 2011 11:17 PM
Discussion DX6i Battery Voltage Questions F.Littleton Radios 12 Jun 06, 2008 03:02 PM
