Old Sep 17, 2013, 09:44 PM
Getuptogetdown is offline
Find More Posts by Getuptogetdown
T.S.P.S.
United States, TN, Lebanon
Joined Mar 2011
Motors for Gaui 330x?
I bought a used Gaui 330x from the RCGroups classifieds about a year ago, and its time to replace the motors.
Curious to what kind of motors i should go with..
I know Scorpion motors are used on the 330XS but i was looking for something a little lower in price without sacrificing too much quality. My 330x has 10amp ESC's and does have the frame extension set installed (longer arms) but i dont know if that would even matter. Flying with 3s 2200 lipos also.
Any suggestions?
Getuptogetdown is offline Find More Posts by Getuptogetdown
Old Sep 17, 2013, 10:15 PM
T.S.P.S.
Joined Mar 2011
For example, would these motors be suitable for my needs?
http://www.multirotorsuperstore.com/...sx2212-980.htm
I dont quite understand the KV rating, and what it means
Old Sep 18, 2013, 07:57 AM
epktoms is offline
Find More Posts by epktoms
epktoms's Avatar
Sweden
Joined Jun 2006
I would say that the sunnysky in the link are a bit much for your ESCs.
Go with a motor similar to the original if you don't want to change the ESCs.
About kv:
http://www.rcgroups.com/forums/showthread.php?t=1999273
http://www.rcgroups.com/forums/showthread.php?t=1984692
epktoms is offline Find More Posts by epktoms
Old Sep 18, 2013, 11:31 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
the SunnySky X2212's are nice motors, but as epktoms says, will be too much for the ESC's
The obvious choice would be T-Motor MT2208 1100KV (max 10Amps) but is probably out of your price range
cheaper is NTM 28-26 1100Kv which will draw 9Amps when using an 8" prop
never had a Gaui 330, so no idea how these compare ....
Mike Barton is offline Find More Posts by Mike Barton
Old Sep 18, 2013, 01:40 PM
T.S.P.S.
Joined Mar 2011
Thank you for your replies guys. i also found these motors. anyone used them or think they will be sufficient for the 330X?
http://www.banggood.com/Sunnysky-X22...Fctr7AodVSQAvg
Old Sep 18, 2013, 04:35 PM
United Kingdom
Joined Nov 2008
I didn't link those motors as they appear to draw too much current ...
Wanted gaui 330x scorpion motor/s wanted rellik demanon Aircraft - Electric - Multirotor (FS/W) 0 Jun 27, 2013 07:09 AM
Sold 75.00 Gaui GU-344, Scorpion Motors & Gaui ESC's from 330X knichefilms Aircraft - Electric - Multirotor (FS/W) 7 Mar 14, 2013 02:46 PM
Sold NIB GAUI 330X w/ scorpion motors + extras $375 simages Aircraft - Electric - Multirotor (FS/W) 3 Jan 24, 2013 10:24 PM
Found Scorpion GM410 motor for Gaui 330XS ppridday Aircraft - Electric - Multirotor (FS/W) 1 Nov 07, 2011 11:03 PM
Discussion need motor replacement for gaui 330x windfou Multirotor Talk 2 Jul 01, 2011 08:28 AM
