Old Aug 26, 2013, 09:57 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
Backyard foamie
Hey guys-
just wanting some advice from the foamie guys as i am all balsa. I have a small backyard, and even smaller front yard, but would really like a really small foamy to fly when I dont have time to make it out to the flying field. Whats the best tiny 3D foamie out there? I am looking at the twisted hobbys crack pitts mini and the crack yak mini. any other choices in that size range or smaller that I should be looking at?
thanks!
rcbirk21 is offline Find More Posts by rcbirk21
Old Aug 26, 2013, 10:50 AM
RCstudent is offline
Find More Posts by RCstudent
RCstudent's Avatar
United States, WA, Bellevue
Joined Jan 2013
Well on this forum a lot of people are talking about griftworks... (I think thats what it's called) it looks just like twisted hobbies, but I believe price is a little cheaper. Not to sure on either companies as I own none of there products, but check em out. TH gets great reviews everywhere though.
RCstudent is offline Find More Posts by RCstudent
Old Aug 26, 2013, 11:44 AM
Azarr is offline
Find More Posts by Azarr
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Both Fancy Foam And West Michigan Parkflyers have mini 3D planes.
Azarr
Azarr is offline Find More Posts by Azarr
Old Aug 26, 2013, 02:15 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I scratch built a Mini 22" foamie plane a few years ago. It works really well in more confined spaces once you dial it in some and get used to it.
http://www.rcgroups.com/forums/showt...hlight=mini+3d
earlwb is online now Find More Posts by earlwb
Old Aug 26, 2013, 04:45 PM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Pick anything from Twisted Hobbys. Just choose a size and you can't go wrong, they are all good. :-)
For a small backyard flyer I might choose the Crack Yak or Laser.
KE Spin is offline Find More Posts by KE Spin
Old Aug 29, 2013, 08:04 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Would and ultra micro be any good for this?
I have a crack yak, but it needs a bal lfield space for me to fly it. No way would that work in my yard.
jtaylor996 is offline Find More Posts by jtaylor996
Old Aug 29, 2013, 08:33 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
The ultra micros have a heavier wing loading and need to fly faster as a result so they are not a good bet for a small yard. Other ultra micros are so light that they don't fly well outside.
What size is your yard and how much flying experience do you have? The Crack Yak can fly in rather confined spaces with appropriate skill and control surface throws. It sounds like you need something with low loading that flies rather slowly. For the most part this puts you in depron foam plane but these break somewhat easier than epp planes like the Crack Yak and other epp planes. For this reason, it sounds like you need to fly your Crack Yak in a space a little bigger than your yard until your skills progress to the point where you can fly in a more confined area.
Old Aug 29, 2013, 08:35 PM
Registered Crasher
Joined Feb 2011
My yard is small. I mean, I could do it, but it wouldn't be much fun.
Old Aug 29, 2013, 08:38 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
There must be an open area not that far away. Even a field perhaps. You really don't need short grass to land the most epp planes. You can just belly land them in taller grass with no problem.
Old Aug 29, 2013, 08:46 PM
Registered Crasher
Joined Feb 2011
I do. But, being a software engineer, I get really lazy sometimes, and don't wanna drive to the park across the creek to fly.
No, really this is more about wind. If I can fly in the cul de sac then I'll have 70' of trees keeping the 15mph winds at bay. If I go to the park, it's open and it's often too windy to fly the crack yak (and the layering, ugh).
Old Aug 29, 2013, 08:58 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
If wind is the issue in the more open areas then I would actually recommend one of the Eflite ultra micro plane WITH AS3X. I have the umx Yak and routinely fly it in winds of 10 to 15 mph. The AS3X really does work and dampens the effect of wind.
Old Aug 29, 2013, 09:41 PM
Registered Crasher
Joined Feb 2011
That's what I was thinking. They have a few now, but I know nothing about the differences between the beast, sbach, or yak. Any thoughts on that?
Old Aug 29, 2013, 09:46 PM
Registered Crasher
Joined Feb 2011
... wrong thread
Old Aug 29, 2013, 09:55 PM
Markran is offline
Find More Posts by Markran
Markran's Avatar
United States, CA, Sacramento
Joined Aug 2011
I have a CY and I used to require a ball field too. Keep practicing. Now I can fly it just about anywhere. My front yard has a grass patch about as big as a small-ish swimming pool and I can fly there now. It's a very constrained space with hazards on every side from trees, to two story roof, to stairs. And I don't just hover. I do actually fly (I land by catching it). Three months ago the thought of flying there would have seemed insane to me.
Last weekend I went to a park with a larger plane but the ball field was occupied so I got out the CY and went flying in a grassy area covered with large trees (no more than a few open feet between the branches). I just wove the CY around the trunks of the trees, under the canopy of branches, through the covered picnic table area (empty), under the jungle gym (also empty) and back to myself. It was a fun obstacle course and I spent an hour flying the CY through it at a walking speed. To be clear, I'm not talking about hovering, obviously you can fly in a closet if you're only hovering. I was flying mostly level with occasional partial harriers (nose slightly up) but just in tight spots or doing a 180 around a tree trunk. Just keep working on the skills. I now believe these kinds of planes can fly just about anywhere.
Edit: There is a video I saw a while back of a teenager flying a CY around his tiny back yard, under tables, through doorways and more. I can't find it now but it was some crazy stuff. I think he was somewhere in Europe. At the time I thought "Maybe the gravity is different there :-)" I'm not as good as he is but I'm getting closer.
Markran is offline Find More Posts by Markran
Old Aug 30, 2013, 11:27 AM
Die Hard is offline
Find More Posts by Die Hard
Joined Mar 2013
Mark,,,, we are just more talented in Europe
As Usual Spin is right, so often people think they need a small plane to fly in a small place, when in actual fact, it is wrong thinking. It is the 'control-ability' that is desired in a small place and this often comes with a slightly bigger plane. Becoz of the wing loading, but also becoz proportionally surfaces/controls to weight/power is much better.
OP asked 'What's the best tiny 3D Foamie out there'? Well,, in my opinion,,, the best is 'Lounge'. There are plans of it on this site, i think the model even uses standard gear if i remember right :-
http://www.rcgroups.com/forums/showt...8#post25815932
Lounge Walk Around showing Set Up and Quick Flight (4 min 23 sec)
Die Hard is offline Find More Posts by Die Hard
Yippee! Backyard Foamies RANDY W. 3D Flying 59 Feb 21, 2004 02:20 PM
Backyard Foamies Edge 540 Model Aero 3D Flying 5 Feb 08, 2004 08:46 AM
Recommendations for foamie in large backyard Mac8 Foamies (Kits) 1 Jan 27, 2004 09:49 AM
Backyard Foamies Extra whirlyspud 3D Flying 1 Jan 21, 2004 06:35 AM
