Old Mar 29, 2013, 01:15 AM
Exploroman is online now
Find More Posts by Exploroman
Explorocam
Exploroman's Avatar
Canada, ON, Ottawa
Joined Feb 2012
BeastX on 450, Tail Wag
Hi guys,
I've seen a few posts on this problem but just kind of dwindled off. Hoping someone has some info to help. Sorry if this is redundant.
  1. I have a Trex 450 FBL and I'm running the BeastX. I just updated the firmware to 3.0.12. and I'm getting tail wag that I can't seem to get rid of.
  2. Radio Gyro setting is set to "G" on the beast.
  3. Pot 3 is dialled at about the 1-1:30 position.
  4. New tail assembly with new tail blade grips & grip bearings.
  5. New main shaft and main shaft bearings.
  6. New Belt (the orange one).
  7. Tail servo is Futaba S9650
  8. Tail servo center position pulse length 1520 us
  9. Tail servo frequency 333Hz.
  10. Beast is mounted on 3M outdoor mounting tape on the heli and on the Beast and 3M rubber foam pad sandwiched between the two outdoor mounting tapes. (Pretty sure very little vibes are getting through; plus the servo wires are free and unrestricted by about a an inch from the Beast; pretty sure vibes are low) {The tail wag is the same when I used the 3M outdoor mounting tape alone.}
Anyone got any advice?
Exploroman is online now Find More Posts by Exploroman
Old Mar 29, 2013, 04:45 AM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Try the inner most hole on the servo arm.
ridge_racer is offline Find More Posts by ridge_racer
Old Jul 16, 2015, 12:25 PM
Axefly is offline
Find More Posts by Axefly
South Africa
Joined Feb 2010
did it work ?
Axefly is offline Find More Posts by Axefly
Discussion CopterX 3x1000 Gyro [ Tail Wag ] old4570 Electric Heli Talk 2 Jan 15, 2013 06:41 PM
Discussion Nano cpx initial tail wag fix helipilot23 Micro Helis 4 Jan 11, 2013 02:43 PM
Help! 450 clone ...HOW DO I STOP TAIL WAG cantyman Electric Heli Talk 10 Jan 04, 2013 09:06 AM
Discussion [Solved] Trex 450 SE v1 tail wag w/gy401 and analog tail servo cvance090685 Mini Helis 16 Oct 06, 2009 07:42 PM
Discussion tail wag on t-rex 450 sajeev Mini Helis 15 Sep 02, 2008 08:36 PM
