Old Jan 02, 2013, 04:36 PM
Dave Grife is offline
Find More Posts by Dave Grife
Dave Grife's Avatar
Coldwater, Mi. USA
Joined Jul 2000
CC Cappack application
Hi,
I'm working on an Airworld Me 262. (twin motor)
I plan on installing 2 Ice 100 lite ESC's in the Tailcones behind the motors.
I plan on using one Cappack per ESC.
How long can my Esc to Battery length be ???
(measuring from ESC circuit board to actual lipo)
-DG
Dave Grife is offline Find More Posts by Dave Grife
Old Jan 03, 2013, 08:02 AM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
This is information from http://www.castlecreations.com/produ...-cap-pack.html
Aircraft: Larger electric power systems lead to larger electric powered aircraft, and sometimes the distance between the battery pack and the ESC grows beyond the length of the wires installed on the components. Adding wire also adds inductance, which can increase the ripple voltage in a system. CC CapPack essentially negates the ripple caused by the addition of up to 8 inches of length to the battery wires.
You can add an additional 8 inches of wire to the ICE 100... from the end of the case my original wire is 6 inches long... so this would give you about 14 inches... You can also log the ripple to make sure "Ripple voltage peaks should always be less than 10% of the total pack voltage; the smaller the ripple voltage the better. "
Clintstone is offline Find More Posts by Clintstone
Old Jan 04, 2013, 08:36 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
make your own with identical caps from digikey for about 2 bucks
ApexAero is offline Find More Posts by ApexAero
Old Jan 04, 2013, 11:18 AM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
What about shipping?
Alan Hahn is offline Find More Posts by Alan Hahn
Sold CapPack by Castle Creations Steph280 Aircraft - Electric - Power Systems (FS/W) 4 Nov 19, 2012 01:39 PM
Discussion using high C lipo for low C application jy0933 Batteries and Chargers 7 Jul 14, 2012 11:12 AM
Discussion Castle creations CC CapPack drcigg Multirotor Talk 1 Jan 09, 2012 01:34 PM
Discussion CC bec vs CC bec pro..... applications Stevo Revo Power Systems 1 Jan 31, 2010 01:30 PM
Lithium application question- RZ300, CC 10amp MHawker Power Systems 2 Aug 04, 2003 05:01 PM
