Old Oct 09, 2012, 01:48 AM
starcad is offline
Find More Posts by starcad
AMA 667982 KG7NKY
starcad's Avatar
Tucson, AZ, USA
Joined Sep 2000
Throttle Cut-off switch Futaba 7C FASST
I have a Futaba 7C FASST radio. The other night I was in the process of setting up control throws on a new model before maiden the next morning. With the plane sitting on the kitchen floor, I was moving the rudder and bumped the throttle up just enough to start the plane rolling across the floor. Now I'm usually Mr. Safety and quickly shut off the motor and unplugged the battery. I then removed the prop.
This all started me thinking, could I mix a switch on my transmitter to use as a safety switch? Well, searching the internet ( if you what to find out anything about anything just search the internet ) I came up with the answer and thought others may benefit.
With computer radio transmitters, it is possible to assign a switch to disable the throttle function. In the example below, the throttle functions normally when the switch is in the up position. In the down position, no power can be applied to the motor.
Use the down position any time the plane is not flying. If you inadvertently bump the throttle stick, nothing happens.
Futaba example is shown. Note that the MASTER and SLAVE are the same the throttle channel, channel 3 on Futaba.
Futaba 7C
To use switch F ( or any of the other switches ) as a throttle disable:
P-MIX 1 > ON
MAS > CH3
SLV > CH3
SW > F ^ ( or any of the other switches )
RT > -100%
> +100%
OFS > SET
With the cursor on OFFSET and the throttle stick closed, press and hold the dial/press control on the transmitter.
It would really be nice it the manuals that come with these radios would include this little easy to program tip.
starcad is offline Find More Posts by starcad
Old Oct 09, 2012, 02:17 AM
Threshold is offline
Find More Posts by Threshold
Threshold's Avatar
London UK
Joined Jul 2004
on my Futaba T8 FG Super it won't let me select a model unless my programmed kill switch is on which is even safer. What is strange is that although I have been showing guys at the field how to do that with many radios they never seem to bother to do it. I guess they are waiting until they have a serious problem before finding out how to program their radios. I hope you have better results.
Threshold is offline Find More Posts by Threshold
Old Oct 09, 2012, 04:26 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Doesn't the 7C have a THR HLD function? If so, you simply set its throttle value to zero.
abenn is offline Find More Posts by abenn
Old Oct 09, 2012, 09:13 AM
starcad is offline
AMA 667982 KG7NKY
starcad's Avatar
Tucson, AZ, USA
Joined Sep 2000
Yes it does, however this function is only in the Helicopter setup. So, I guess my question would be will this function be available in Acro/Aircraft setup for the model I'm using if activated in the Heli setup?
Old Oct 10, 2012, 04:06 AM
abenn is offline
Joined Jul 2004
No, if it's only available in heli mode, it will not be available when you switch back to acro mode. I no longer have my 7C, but I'm surprised the same or equivalent function doesn't exist in acro mode -- even the basic Futaba 6 trannies have some kind of throttle cut button or switch IIRC.
Old Oct 10, 2012, 09:35 AM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
My answer is a strap the holds the throttle down ALL THE TIME, except when actually flying. When I land the strap goes back on... For safety issues that can result in blood I like to be able to see the 'safety device' and know w/o a doubt that it's in place...
rtbates is offline Find More Posts by rtbates
Old Oct 10, 2012, 12:53 PM
arnav is offline
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
Trying to figure out how to do it on the 8FG drove me crazy for a few days, until finally someone here told me how to do it (god bless him.. ). The key for electric was not to do it through the throttle kill function at all but rather through the motor function. I don't know whether it will help you or not as we don't have the same radio, but maybe it will point you in the right direction.
Good luck. I think it is worth setting up...
arnav is offline Find More Posts by arnav
Old Oct 13, 2012, 05:22 AM
pwg212 is offline
Find More Posts by pwg212
United States, MI, Middleville
Joined Mar 2012
thanks for this, it really came in handy. now i dont have to install anymore disarm switches in my planes and can still use the servos
pwg212 is offline Find More Posts by pwg212
Old Oct 13, 2012, 08:56 AM
eliworm is online now
Find More Posts by eliworm
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
Wow, Guy, thanks. I was just thinking the other day if/how this could be done.
eliworm is online now Find More Posts by eliworm
Old Oct 13, 2012, 01:22 PM
scottflight is offline
Find More Posts by scottflight
scottflight's Avatar
Arvada, CO
Joined Aug 2004
I program a mix from throttle to a three way switch. Only when the switch is in the middle position can the throttle be armed. That way if you bump it in any direction, the default is throttle off. It's been very helpful. I use this on both the 7C and the 8FG, not too hard to do.
scottflight is offline Find More Posts by scottflight
Old Oct 13, 2012, 01:48 PM
Endlesslag is online now
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Daytona Beach
Joined Jan 2011
Anyone know how to do this on a jr x9303?
Endlesslag is online now Find More Posts by Endlesslag
Discussion Futaba 7C fasst throttle question scigs30 Radios 10 Jan 19, 2012 11:56 PM
Discussion Programming futaba 7c throttle cut off switch ? iflyrc4333 Fuel Heli Talk 4 Jun 10, 2010 10:26 AM
Question Futaba 7c: Throttle Hold or Throttle Cut agran1021 Beginner Training Area (Heli-Electric) 7 Jun 26, 2009 07:54 PM
Question Switch Characteristics of the Futaba FASST 7C Warren E Radios 5 Mar 12, 2009 08:37 AM
Futaba 7C Throttle cut palu Radios 6 Jul 24, 2006 11:12 AM
