Old Jun 23, 2012, 10:20 AM
Aaron 1 is offline
Find More Posts by Aaron 1
Joined Jun 2010
Flying wings?
I know just enough about conventional airplanes and what controls what to figure things out. Wings I know zilch.
I'm thing about buying a Mulitplez Xeno wing . Just looking at it it looks like the fin area is too small and inboard on top of it. A search of owners brings up a question of stability at very low speeds. Probably made worse when the motor is turned off as in landing.
I wonder what happens if you add vertical tips to the ends of flying wings? A lot, if not most wings have huge vertical tips at the wing ends. I had a Zagi years ago that had this feature and it had no low speed problems.
Anybody try this or can guess what happens if you make the tips to large?
" Modification always lead to grief" is an excellent thing to not to ignore but it sure is a lot of fun.
Aaron 1 is offline Find More Posts by Aaron 1
Old Jun 23, 2012, 10:49 AM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I'd suggest flying it first. If you notice a slow speed fall off or hunting around then add some small tip plates.
You certainly do not need to add a huge amount of area. Even just 2 or 3 sq inches of area at the tips or making the stock fins bigger and extending them further behind the trailing edge would be enough.
BMatthews is offline Find More Posts by BMatthews
Old Jun 24, 2012, 05:06 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Aaron1, this thread may be worth a read - Models with no vertical stabs.
eflightray is offline Find More Posts by eflightray
Discussion 32 in flying wing dr rc Flying Wings 7 Jul 04, 2012 09:08 PM
Wanted Combat Wing, Flying Wing 36" wbrannies Aircraft - Electric - Airplanes (FS/W) 7 Jun 23, 2012 08:28 PM
Help! Flying Wing Questions Zachlevet Power Systems 3 Jun 20, 2012 03:22 PM
Discussion Flying Flying Wing From Flying Wing TjW Flying Wings 5 May 19, 2012 09:52 AM
