Old Jun 18, 2012, 08:07 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
What makes a jet fly fast?
So I'm still new to these EDFs. I have a 50mm F-22, 6 blade with 4S. How could I get more speed out of it? Does increasing the Kv of the motor and decreasing blades mean more speed? What about the opposite? Does decrease kv more blades mean more thrust and less speed? What determines how fast an edf flies (besides a less draggy airframe)?
Cheese5 is offline Find More Posts by Cheese5
Old Jun 18, 2012, 08:21 PM
pylot2b is offline
Find More Posts by pylot2b
Virginia Beach, Virginia, United States
Joined Jan 2004
Money!!
pylot2b is offline Find More Posts by pylot2b
Old Jun 18, 2012, 08:58 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
big batts rpm and good inlet and exhust ducting .
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jun 18, 2012, 10:58 PM
capt soap is online now
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Pushing the throttle/ thrust lever's forward!!!!!!!
capt soap is online now Find More Posts by capt soap
Old Jun 19, 2012, 02:19 AM
iamzoli1 is offline
Find More Posts by iamzoli1
iamzoli1's Avatar
Joined Jan 2009
you need as much thrust as possible and a higher eflux....
eflux is the max speed you can fly ... thrust is the force that pushes you towards that speed
but there are other ways to make a jet to seem fly more faster like cocaine and lsd
iamzoli1 is offline Find More Posts by iamzoli1
Old Jun 19, 2012, 03:53 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
+1 on the above but I think that the most significant is a slippery shape with the lowest drag. Composite airframes are usually "faster" than most foam airframes.
After that lower kv motors, higher cell count batteries give setups with manageable amps for more kWatts. Proper ducting and thrust tube give the eflux speed to achieve the top end speeds required.
anlucas is offline Find More Posts by anlucas
Old Jun 19, 2012, 04:16 AM
ticketec is offline
Find More Posts by ticketec
Brisbane, Australia
Jet A1 !! and lots of it!
ticketec is offline Find More Posts by ticketec
Old Jun 19, 2012, 05:19 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Depends on what you may think as fast. A couple fellows have gotten a 50mm F-18 from nitro hobbies and they really fly well after adding a Don's fan system. An F-22 is lots of drag, I believe you could have three more toys by the time you spent enough to make it go fast. To answerer your question it takes rpm and enough motor, battery and ESC to sustain said rpm.
ApexAero is offline Find More Posts by ApexAero
Old Jun 19, 2012, 12:39 PM
Vantagepoint is online now
Find More Posts by Vantagepoint
United States, TN, Nashville
Joined Aug 2008
Originally Posted by pylot2b View Post
Money!!
I have been wondering the same, and the answer has always come back to more dollars. You spend the right amount and get the right equipment, motor, batteries, esc, and yes, the right airfarme, then you get speed. By the way, my definition of speed for the edf is anything in excess of 150 mph. For the kero burners, 175 mph minimum.
Vantagepoint is online now Find More Posts by Vantagepoint
Old Jun 19, 2012, 01:22 PM
Cheese5 is offline
Cheese5's Avatar
United States, CA
Joined Jul 2010
Hmm if I increase the blades and lower the kv, wouldn't that produce more thrust which means more speed for a given airframe? How does that compare to high Kv decreased blades?
I guess money is the main factor. To support a big fast motor, need a good esc, and a good battery. All= money. Switch that foamy into composite and that's more $$$$
Old Jun 19, 2012, 01:23 PM
mario alvarez is online now
Find More Posts by mario alvarez
Fight On!
mario alvarez's Avatar
San Salvador, El Salvador
Joined May 2001
Aerodynamics.
mario alvarez is online now Find More Posts by mario alvarez
Old Jun 19, 2012, 01:45 PM
UltraMicro is offline
Find More Posts by UltraMicro
UltraMicro's Avatar
United States, CA
Joined Jul 2011
I also have this question. I wanted to also know whether the blade count matters?
UltraMicro is offline Find More Posts by UltraMicro
Old Jun 19, 2012, 02:01 PM
Doug Bateman is offline
Find More Posts by Doug Bateman
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
It's not a linear relationship, power and speed. If you double your power you will not double your speed. It takes almost a fourfold increase in power to double the speed. A well matched power plant to aircraft is what you should seek. Something light enough to allow slow speed flight, powerful enough for scale speed plus and efficient for decent flight times.
Doug Bateman is offline Find More Posts by Doug Bateman
Old Jun 19, 2012, 02:23 PM
RPatrick is offline
Find More Posts by RPatrick
RPatrick's Avatar
Hurst, Texas USA
Joined Jan 2002
Does the pitch of the blades matter, or are they all the same ?
RPatrick is offline Find More Posts by RPatrick
Old Jun 19, 2012, 02:33 PM
old_dude is offline
Find More Posts by old_dude
Groundloop World Champion
old_dude's Avatar
USA, AZ, Glendale
Joined Jan 2002
Yes, and they are definitely NOT all the same.
The blade width and shape are also factors.
old_dude is offline Find More Posts by old_dude
Discussion What to make to fly inside the house? gt35r Scratchbuilt Indoor and Micro Models 4 Jan 14, 2012 07:34 AM
Discussion What Motor for Yardbird Pusher Jet? I wanna go fast. samolot Pusher Prop Jet Models 6 Jun 14, 2009 06:54 AM
Discussion 40" cat hull what motor or motirs would make fast Cliff Smith Racing Boats - Electric 1 May 22, 2009 11:04 PM
How do I make the Kamdax Mig 15 fly fast as possible? Starguard Electric Ducted Fan Jet Talk 4 Nov 16, 2005 02:21 PM
