Old Apr 23, 2006, 01:32 PM
ShadowGibbon is offline
Find More Posts by ShadowGibbon
Joined Apr 2006
Question
Long Leads
Just wondering:
If I have to run a long set of leads, which would be preferable:
Short lead from Batt to ESC, long lead to motor;
or Long lead from Batt to ESC, short lead to motor.?
ShadowGibbon is offline Find More Posts by ShadowGibbon
Old Apr 23, 2006, 01:43 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
long heavy leads from batt to ESC is better for brushless... for brushed it doesn't matter if the long leads are between motor and ESC or Batt and ESC.
Be sure to use heavier guage wire when running longer leads. Minimizes resistance in the wires.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Apr 23, 2006, 02:39 PM
GlasairAllen is offline
Find More Posts by GlasairAllen
I'll fly anything...
GlasairAllen's Avatar
United States, CA, Palm Springs
Joined Aug 2001
It will be interesting to see what others say (not saying you are wrong) ... I've heard different stories.
On my YF-23 I have about 4-5 inches from the batteries to the ESCs and then about 24" from the ESCs back to the motors. Am I asking for trouble? Or do I have it right?
Lets hope others chime in on this issue. ...and soon, I'm almost ready for my maiden flight.
GlasairAllen is offline Find More Posts by GlasairAllen
Old Apr 23, 2006, 03:12 PM
Richie Simpson is offline
Find More Posts by Richie Simpson
Pittsburgh,PA.,USA
Joined Mar 2006
I am NO expert here, but<g> from what I have read... long leads are a no no from battery to esc. 18" max including what is in the battery pack. OR you should put some large caps(330mf & greater voltage than used) on the leads near the esc. 22-23" is probably pushing it a little?
Richie Simpson is offline Find More Posts by Richie Simpson
Old Apr 23, 2006, 03:14 PM
Pittsburgh,PA.,USA
Joined Mar 2006
Opps, forgot ,
sounds to me that you have it correct.
Old Apr 23, 2006, 03:17 PM
Jack Brewer is offline
Find More Posts by Jack Brewer
United States, IN, Lafayette
Joined Dec 2003
Long leads from battery is OK with reason. One of my brushless motors says distance from ESC to motor leads should be NO longer than 8".
Jack Brewer is offline Find More Posts by Jack Brewer
Old Apr 23, 2006, 03:44 PM
Joined Apr 2006
one way or the other I'm looking at about 18-20" of leads total from batt to ESC to Motor. (for the tail motor) Wings are no problem.
Old Apr 23, 2006, 04:07 PM
speleopower is offline
Find More Posts by speleopower
Hey Now
Cocoa Beach, Florida
Joined Feb 2004
I've spoken with some old timers who have lots of experience with radars, brushless and brushed electric motors. One friend has an oscilliscope and other measuring tools. He has told me longer leads from the battery to ESC is a better choice on brushless if you need longer leads. He's not sure if it really matters one way or another within reason of course. He just says to twist all the wires in a tight bundle when ever possible to help cancel out the electric fields around the wires. He was saying they used twisted wire bundles in every part of the radar systems when it was possible.
See ya-Scott
speleopower is offline Find More Posts by speleopower
Old Apr 23, 2006, 04:16 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2015 , May 28-31
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
I have used over 18" of wire for my motor-to-battery connections.
The conclusion that most of us have is that as long as your load isn't real close to your controller limits you should be fine. This gives you a cushion for any "spike" that could occur. I also twist my leads.
My Super Hornet has about 22-24" of motor-to-battery cable.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Apr 23, 2006, 04:55 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Nice hat!
gregg f is offline Find More Posts by gregg f
Old Apr 23, 2006, 04:57 PM
Kevin Cox's Avatar
Joined Jan 1997
LOL.....Thanks Gregg
Old Apr 23, 2006, 06:09 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Wow..look at those "demon" eye's..
Steve
St. Martin is offline Find More Posts by St. Martin
Old Apr 23, 2006, 06:12 PM
Kevin Cox's Avatar
Joined Jan 1997
LOL...man tough crowd
Old Apr 23, 2006, 07:35 PM
Hey Now
Joined Feb 2004
wow, nice airplane....
Old Apr 24, 2006, 06:05 AM
Whistling Watts is offline
Find More Posts by Whistling Watts
Braintree, Essex
Joined Mar 2006
That will be the Jetti then. I had 28cm leads from the pack to the ESC but the pack was a large 5s2p 66000 lipo. If you measure the RED lead inside the pack, its longer than 8 inches anyway. According to the MNF of the esc, there is no way you can connect a battery like this whatever you do
I had a Jetti 77 burst into flames using this pack, it got REALLY hot and was only pulling 62 amps. No way should a controller do this if used within normal operational conditions
Whistling Watts is offline Find More Posts by Whistling Watts
Long leads - Battery or Motor? CenTexFlyer Power Systems 9 Jan 12, 2005 11:10 AM
Long Leads? umrk Castle Creations 2 Jun 27, 2004 08:48 PM
twin BL - one ESC - long leads OK? hardlock Power Systems 4 Nov 01, 2003 10:45 PM
long leads how long is too long? JimF Electric Ducted Fan Jet Talk 2 Jul 08, 2003 01:20 AM
