View Poll Results: Will this work
Yes 1 20.00%
NO 4 80.00%
Voters: 5. You may not vote on this poll
Old Jan 13, 2004, 11:04 PM
simituff is offline
Find More Posts by simituff
Kansas City, MO
Joined Jan 2004
P-51
I am just beginning to build my P-51 and have decided to up grade the motor to a GWS EPS 400C with a gear ratio of 3.90. I have also decided to go with the 1080X4 and a 3 Cell 11.1V, 1500 mAh Li-Poly Battery. Does anyone have any do's and don'ts
for me or is this a bad idea all around? I am also going with retractable landing gear. I am really looking to get some speed out of this thing without killing it the first time out. Any help would be welcome.
simituff is offline Find More Posts by simituff
Old Jan 13, 2004, 11:30 PM
Phreakish is offline
Find More Posts by Phreakish
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
you'll probably want to fix the timing too... from what others have concluded, the motor has about -4^ of timing, so you may want to add 4-8^ or so... This should wake up the motor some.
The 4 blade prop has a reputation of being garbage as far as performance, I'd stick to a two blade setup, and maybe experiment with the 4 blade a little later...
Phreakish is offline Find More Posts by Phreakish
Old Jan 15, 2004, 08:27 AM
simituff is offline
Kansas City, MO
Joined Jan 2004
Phreakish what do you mean by timing? the gears on the reduction? I will take your advise on the 4 bladed prop. What do you think about batterys for best proformance and flight time for the flight time.
Simituff
Old Jan 15, 2004, 12:30 PM
Nickel what?
Phreakish's Avatar
Joined Jan 2003
well, I love kokam lipos, 1500hd is what I use but the 350 only draws about 8A (12A max).
Timing meaning the timing of the brushes in relation to the commutator. You can rotate the back plate of the motor to get more rpms, at the cost of amps (until the law of diminishing returns kicks in).
I just got through with another flight on my stang. I added a couple degrees of timing to MY 350, and it flies wonderfully. It wont hover, but it'll torque roll at the top of a good climb (about 75 ft). Its fast, not lightining fast, but good for a parkflier this size. I'll get some video for you.
I havn't tried the 400 yet, so I can't suggest much on that, but if you do use the GWS motor, it has to spin in reverse rotation to spin the gb the right way, so it's timing is retarded (relative to reverse rotation), so you have to add some to it. Search for some threads about retiming, and a thread in power systems called "GWS speed 400 needs timing?" or something to that effect.
Ezone/Rittinger P-51 Python Slope Nut Electric Plane Talk 20 Mar 09, 2002 02:58 PM
Herr P-51 Info? byoung Electric Plane Talk 7 Jun 05, 2001 12:56 AM
Powering a HOB P-51 .19-.20 KMKAZE Electric Plane Talk 6 Apr 30, 2001 10:25 PM
Ace Simple P-51 or Extra, etc anyone electrified these? NewbieX Electric Plane Talk 4 Apr 22, 2001 05:24 PM
HOB P-51...Anyone built it? KMKAZE Electric Plane Talk 16 Apr 22, 2001 12:18 AM
