Old Oct 04, 2012, 01:56 PM
Mgblunt is offline
Find More Posts by Mgblunt
Meramec Mike
Mgblunt's Avatar
Joined Dec 2011
Glow to Gas
I have a 40 size great planes Escapade with a .46 glow and I want to change the engine to a size 15cc gas ,will this engine work on this plane and will the fuel tank from the glow engine work with gas?
Mgblunt is offline Find More Posts by Mgblunt
Old Oct 04, 2012, 02:03 PM
Green Fuel Boy is offline
Find More Posts by Green Fuel Boy
Green Fuel Boy
United States, OR, Newberg
Joined Sep 2009
Hi, The fuel tank stopper will have to be changed to a gasoline stopper. You will have to use gasoline fuel lines and a good fuel filter. The engine will use less fuel than a nitro engine in that size class. I had a escapade a couple of years ago with a nitro engine. The 15cc gas will fly it will authority but just might be a little heavier than your nitro engine.
Green Fuel Boy is offline Find More Posts by Green Fuel Boy
Old Oct 04, 2012, 02:18 PM
Mgblunt is offline
Meramec Mike
Mgblunt's Avatar
Joined Dec 2011
That's what I was thinking about the weight but I have about three ounces of weight in front to balance it so that will take care part of the weight difference ,,thanks for the info and the reply
Old Oct 06, 2012, 04:07 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Beware....once you switch to gas....you may not come back to nitro! At least that is what a lot of gas guys are saying.....
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: Gee Bee by Seagull
Old Oct 06, 2012, 06:00 PM
scaleman57 is offline
Find More Posts by scaleman57
United States, NJ, Upper Pittsgrove
Joined Mar 2011
He wont come back to nitro, had 8or9 glows then switched my H9 cub to DLE20 from Saito 180 flew it once the performance, the lack of oil all over the belly the fuel burn was a third of $22 a gallon nitro. Ive already changed 6 planes to gas going to do the rest asap.
scaleman57 is offline Find More Posts by scaleman57
Old Oct 06, 2012, 07:55 PM
jetmech05 is online now
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
A 46 powered airplane switching to a 15cc gas is gonna be way over powered a 15CC is about a 90 glow.
Everyone's correct about gas once you get over the learning curve you wont wanna fly glow.
Love my gassers
jetmech05 is online now Find More Posts by jetmech05
Old Oct 07, 2012, 10:16 AM
Mgblunt is offline
Meramec Mike
Mgblunt's Avatar
Joined Dec 2011
Jetmech05; I just want to experament with a gas setup and since I had to add quite a bit of weight to the front of this plane I figured it might be a good choice to use,,it appears to me that the 15cc gas would be slower at least that's what it appears to be on youtube anyway any help you can give me would be greatly appreciated
Old Oct 07, 2012, 04:14 PM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
MG the biggest thing you need ta do, is get the fuel system figured out! its completely different then a glow fuel set-up!
you could cruise through the giant scale fourum and see how there set-ups look, as most are gassers!
yes you will need to change out all the fuel lines! and I think you will be fine with that 15cc as a 20cc is actualy what replaces a 91 two stroke!
whiskykid is offline Find More Posts by whiskykid
Old Oct 09, 2012, 01:32 PM
Jacksonville Fla.
Joined Mar 2007
The math says 10cc equals 60 2 stroke glow....it just comes to a point that you can over power an airplane to the point the airframe just can't handle it. weight and speed equals too many G's.
Good Luck though
Sold Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 15, 2012 02:43 PM
Sold 17cc Gas Engine replaces glow .90 engine! unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 6 Jun 15, 2012 02:35 PM
Sold Back in stock-9CC Gas Engine Lower Price $179-replaces .40 size glow engine. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 15, 2012 02:04 PM
Sold Glow to Gas easy with new 9CC Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 13 Jun 08, 2012 04:33 PM
Sold NEW ITEM-NIB-Gas engine the size of a .40 glow-Save money by not buying Glow Fuel! unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 13 Apr 03, 2012 04:28 PM
