Old May 21, 2012, 01:05 PM
Flyboy Steve is offline
Find More Posts by Flyboy Steve
Joined Nov 2007
Hobby King ESC Programming
I have this ESC http://www.hobbyking.com/hobbyking/s...dProduct=17793 on a foamy I built. I was playing with the throttle limits, and think I messed up the programming.
Did not get any instructions from HK with the ESC.
Anybody know how to program this one?
Thanks!
Steve
Flyboy Steve is offline Find More Posts by Flyboy Steve
Old May 21, 2012, 01:07 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Steve at the bottom of the page under files you get this
http://www.hobbyking.com/hobbyking/s...90X90943X5.pdf
Wilfor is offline Find More Posts by Wilfor
Old May 21, 2012, 01:11 PM
Joined Nov 2007
Saw that, but it's not enough.
I think I've inadvertantly messed with the timing -- although maybe this ESC does not ALLOW changes in timing?
Motor and ESC USED to run good -- now the motor runs, but slowly. Tried to adjust min / max throttle, but may have messed up the ESC.
Is there a way to "reset" it? I know I can do that w/ some more expensive ESC's I own (and have instruction sheets for!).
Appreciate any help you can give...
Steve
Old May 21, 2012, 01:16 PM
Joined Nov 2007
I just found this on line: http://www.hobbyking.com/hobbyking/s...022X7478X9.pdf, but I'm not sure it's for the same ESC that I have ?
Old May 21, 2012, 01:51 PM
dedStik is online now
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
It's not. Wilfor posted the link for your ESC. I have that same model as you.
dedStik is online now Find More Posts by dedStik
Old May 21, 2012, 01:58 PM
Joined Nov 2007
So, there IS no timing adjust on this ESC that I could have messed up?
I would assume that with a Lipo, it would "auto count" the number of cells, so no adjustment there.
I understand brake
Neither of these should effect how the motor & ESC work together.
If the motor USED to run fast, and is now running SLOW, any other ideas as to what may be wrong? I THOUGHT I'd messed up the timing, but perhaps not...
Thanks!
Old May 21, 2012, 03:27 PM
Wilfor is offline
RC Adddict
Wilfor's Avatar
Joined Jan 2010
do you have it set on nicad ? instead of lipo ?
Old May 21, 2012, 03:30 PM
Joined Nov 2007
Don't know. How do I tell? And how do I change it back if it's wrong?
Thanks!
Old May 21, 2012, 04:28 PM
dedStik's Avatar
Joined Feb 2012
Crap I'm sorry Flyboy Steve. Mine is the 18A version of that ESC not the 20 like yours. Mine HK-SS18A yours HK-SS20A.
Put throttle to full, plug in ESC battery. After you hear beep pause beep set throttle to off. Should be set for lipo.
If when you plug in battery you hear beep beep pause beep beep your ESC is set for ni-XX
Old May 21, 2012, 08:40 PM
vtdiy is offline
Find More Posts by vtdiy
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Suggestion, check your 3 wires to the motor for a broken connection.
vtdiy is offline Find More Posts by vtdiy
Old May 22, 2012, 08:30 AM
Joined Nov 2007
Tried to reset the ESC to "lipo" per the instructions above.
IT WORKED! Yahoo! I'm flying again!
Thanks for the help, folks.
Steve
Old May 22, 2012, 09:02 AM
Wilfor is offline
RC Adddict
Wilfor's Avatar
Joined Jan 2010
Great to hear that worked .
Happy flying
Old May 22, 2012, 10:28 AM
dedStik's Avatar
Joined Feb 2012
Great, now post some pics of the plane please.
Help! hobby king ESC programing Aero12 Power Systems 3 Apr 18, 2012 09:01 AM
Help! Problems with Final Programming of Hobby King KK board V1 srs5150 Multirotor Talk 5 Apr 09, 2012 03:57 PM
Discussion Hobby King junk esc bmwbob Power Systems 4 Mar 30, 2012 06:45 PM
Discussion Hobby King 14S ESC lrb75 Electric Ducted Fan Jet Talk 8 Mar 21, 2012 02:38 PM
Discussion Quality of hobby king’s esc? Ken Smith Power Systems 6 Mar 11, 2012 08:22 PM
