Old Oct 12, 2003, 11:22 AM
Coop is online now
Find More Posts by Coop
Lawton/Fort Sill, OK
Joined Sep 2002
Strega power upgrade
Guys I need your help. I just flew my Strega a couple of times and the IPS motor just doesn't seem to cut it. I have a lipoly 340mah from LightFlight RC per his recommendation and the plane just doesn't have in umph. What would be a good motor upgrade for this along with ESC and battery. Thanks for the input.
Coop is online now Find More Posts by Coop
Old Oct 12, 2003, 04:15 PM
Thatovalguy is offline
Find More Posts by Thatovalguy
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
Coop a easy straight up swap would be a GWS 7.2v IPS-S1 Twin. It will rip the wings off of it if your not careful. The other is a M100 conversion. You pick.
You'll need to step up to a GWS 300 esc and 600 lipoly's, your 340's would work but you won't have much run time.
Thatovalguy is offline Find More Posts by Thatovalguy
Old Oct 12, 2003, 05:37 PM
Coop is online now
Joined Sep 2002
Hey TOG what is a M100 conversion? Which one would be better of the 2 you gave me? Also where can you the IPS twin? Thanks a bunch.
Old Oct 13, 2003, 01:51 PM
Coop is online now
Joined Sep 2002
TOG did you get my last post about what is a m100?
Old Oct 13, 2003, 02:39 PM
Foam rules
HdG Md.
Joined Jan 2003
Check this thread out for the M100
http://www.rcgroups.com/forums/showt...70#post1373270
But really a S1 geared twin is a direct fit and you could use the same prop and have major increase in performance.
Old Oct 13, 2003, 02:50 PM
Coop is online now
Joined Sep 2002
TOG S1 geared twin? What is the GWS part number for this if you got it. Thanks.
Old Oct 13, 2003, 02:58 PM
Foam rules
HdG Md.
Joined Jan 2003
try this
http://www.balsapr.com/catalog/motor...ductId=S012457
Old Oct 13, 2003, 02:59 PM
Coop is online now
Joined Sep 2002
TOG thanks I just found it before you replied. Would a etec 700 be a good battery for it along with a GWS 5 amp esc?
Old Oct 13, 2003, 03:06 PM
Foam rules
HdG Md.
Joined Jan 2003
Yep, and I use my 340's too.
Old Oct 13, 2003, 03:41 PM
Coop is online now
Joined Sep 2002
TOG it seems like with the standard motor wouldn't get a little more power with the 700's or is that with a 3cell 700?
Old Oct 13, 2003, 04:12 PM
Foam rules
HdG Md.
Joined Jan 2003
Its all in trust and prop speed. Put a twin in it and you be happy you did, believe me. (2 cell) 3 burns things up if your not careful.
Strega Power Upgrade Coop Parkflyers 12 Oct 13, 2003 02:35 PM
Looking for a cheap (brushed) Skimmer 600 power upgrade BigShark Electric Sailplanes 18 Jan 25, 2003 04:12 PM
Mefisto (Reichard) gets power upgrade... pullin-gs Electric Sailplanes 3 Jan 23, 2003 08:46 AM
Pico FD with EDP-100 Flight report (or what's the best power upgrade?) Peter Khor Parkflyers 6 Oct 22, 2002 03:38 PM
Twin star power upgrade S Anastasio Foamies (Kits) 1 Oct 15, 2001 09:21 AM
