Old Aug 10, 2014, 02:16 PM
meerkat13's Avatar
United Kingdom, Birmingham
Joined Jan 2013
Originally Posted by invertmast View Post
Looks awesome man! Count me in if youd like to sell one
cool.... that's made my day
meerkat13 is offline Find More Posts by meerkat13
Old Aug 10, 2014, 03:30 PM
United States, FL, North Port
Joined Mar 2004
I like hunters! Id love to have one or Mick reeves' kits, but the exhange rate and shipping almost makes it cheaper for me to scratch build my own composite version of that size.
invertmast is online now Find More Posts by invertmast
Old Aug 16, 2014, 03:57 PM
meerkat13's Avatar
Joined Jan 2013
Ducting Moulds
Ducting Moulds
I thought I would try something new this week and designed duct moulds to create foam plugs. The idea being that I could them easily cast plugs to try different layups, rather than print and hand finish the HIPS plugs each time I wanted to try a different layup. Im really keen on the ducts having no seams, which is why Im going down the loss foam / HIPS route.
The exhaust mould was easy enough to design, but the inlet mould was a bit more complicated because of the parting lines and it size. I ended up printing the inlet moulds in 4 sections which worked well and good experience for when I come to the wings and fuselage moulds.
It took a couple of attempts to understand that back pressure is everything when casting with urethane foams. I did get some minor chips along the seam when removing the flashing which were easily filled and sanded.
I changed the layup from the last test I did as follows
  • Cut 1 strips of 25g Fibreglass
  • Laid them as slightly overlapping bands.
  • 2 layers no carbon fibre
  • 1 strip of peal ply wound tightly around.
As you can see from the photos it turned into a bit of a train wreck.
  • When I removed the peal ply I could see the layup was dry in areas.
  • The layers had shifted and wrinkled with the inlet layup.
  • As the foam doesnt dissolve in acetone I had to remove the foam mechanically.
  • The foam was very dense and strong due to the amount of backpressure in used.
  • The cured fibre glass felt like tissue, very thin and easy to tear.
  • I managed to remove the foam from the exhaust but it was very weak and the internal surface wasnt great.
I had some old plaster paris so cast a hollow version of the inlet. The thinking been that its would be a lot easier to break and remove then the dense foam. The plaster went off really quick but was good enough for a proof of concept. When I get a chance Ill lay it up.
Im going to revert back to the previous method for the next layups and then take it from there.
Old Aug 18, 2014, 08:12 AM
meerkat13's Avatar
Joined Jan 2013
Exhaust Duct Loss HIPS method
This is easily my best layup to date and Im starting to get a much better feel for composite work.
The process was as follows -
  1. Exhaust duct printed in HIPS at 0.1mm layer height, 2 shells.
  2. Sanded down to 2000 grit wet and dry.
  3. 2 coats of Ease Release sprayed.
  4. Primed grey acrylic (wont do this again)
  5. 2 x 25g glass fibre (West 205 system)
  6. Left to go off tacky
  7. 30K carbon toe rings added in 5 places
  8. 1 x 25g glass fibre
  9. Left overnight to cure.
  10. Ends trimmed and submerged in Orange turpentine to dissolve the HIPS.
  11. Agitated and scraped of soft HIPS every 20 minutes.
  12. 2 hour later and the part is finished the Orange Turpentine also dissolved the grey acrylic.
Weighs 2.3g and plenty strong enough.
I have done a ABS version which I will layup and then use Acetone to dissolve the ABS. I just want to compare methods to see which is easier.
Old Aug 18, 2014, 01:59 PM
Greenwood Indiana
Joined Jun 2004
Your build is coming along very well. I like how you are willing to try different "recipes" to come up with a part that works well. I might have to try that technique on my F-4 when I can find the time, work and family have consumed every last minute.
danj31 is online now Find More Posts by danj31
Old Aug 19, 2014, 03:46 AM
meerkat13's Avatar
Joined Jan 2013
Good hearing from you Dan.
I think that one of the best things about working at this scale is that you really need to consider everything to get the best balance between weight, strength and finish. Going off on tangents is all part of the fun and adventure.
Looking forward to see you back on your builds when time permits. I've been pretty lucky of last but sure do hear you with the work, family, hobby balance.
Be sure to give me a shout if you need your ducts printed etc.
Old Aug 20, 2014, 06:18 AM
meerkat13's Avatar
Joined Jan 2013
Exhaust Duct - Loss ABS Method
The loss ABS method worked even better then the loss HIPS method previously.
  • ABS was easier to print and finish - could use Acetone Vapor Bath for a supper smooth surface as a final step.
  • Took about half an hour to remove the ABS with the acetone.
I also reduced the carbon toe to two bands around where the duct is glued to a former in the fuz.
The weight is right down a 1.7 grams. The best usable ABS printed duct I've done to date came in at 3 grams and is no where near as strong as this last composite version.
Old Aug 24, 2014, 04:59 AM
meerkat13's Avatar
Joined Jan 2013
First duct set complete
I completed the ducting last night. I'm constantly refining the process and for the right hand inlet, managed to get the ABS plastic out with out using acetone. Took about 15 minutes and no mess .
The ABS shroud is printed and finished. I've had some ideas on how I can reduce the amount of printed plastic (weight) so will redesign for the flying model. I'll use this version in the test rig to tie down a EDF system.
Old Aug 24, 2014, 07:45 AM
BVM Viper Fever
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Awesome work!
pdawg is online now Find More Posts by pdawg
Old Aug 24, 2014, 10:46 AM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Man that's some cool stuff....
Old Aug 24, 2014, 11:36 AM
meerkat13's Avatar
Joined Jan 2013
Cheers guys,
Just set it up in the test rig and all looks good
Old Aug 24, 2014, 12:18 PM
Breaker of Things
elbowdonkey's Avatar
United States, OR, Portland
Joined Dec 2011
I'd love to hear more about this.
I've been ramping up to do some fiberglass wing layups for a micro hotliner using a lot of 3D printed tools (molds, foam cutting airfoil templates, jigs, etc). I'm really interested in avoiding the "lost ABS" technique. Are able to preserve your 3D printed pattern part with your latest technique?
elbowdonkey is offline Find More Posts by elbowdonkey
Old Aug 24, 2014, 03:23 PM
jumo004's Avatar
Joined Apr 2010
Cheers guys,
Looks GREAT !!
jumo004 is online now Find More Posts by jumo004
Old Aug 25, 2014, 05:45 AM
meerkat13's Avatar
Joined Jan 2013
Sounds like fun .
I expect with some clever design it may be possible with the wings. The thin walled ABS flexes which is good when removing the former. The glassfibre releases from the ABS really well, just make sure you have a bit of draft on your former.
If add about 0.5 degrees on the exhaust I could reuse the former. The former for the reducer from the EDF to exhaust came out in one piece.
Build Log 1/7 Aermacchi M-346 / Yak-130 / T-100 2x90mm Composite Scratch Build ysolomon Scratchbuilt EDFs 113 Dec 07, 2014 08:14 PM
Build Log Hawker Hunter Scratch Build Sandracer17 Scale Kit/Scratch Built 51 Feb 02, 2014 12:49 PM
New Product F-117 Stealth Fighter 70mm EDF jet. Scratch build crispy1074 Parkflyers 0 Jan 08, 2014 06:05 AM
Build Log Hawker Hunter- First Scratch Build rhinophoto Foamies (Scratchbuilt) 12 Jun 19, 2008 10:48 PM
Video Scratch Built 24" span Hawker Hunter EDF rcminiman Electric Plane Talk 2 Aug 08, 2007 02:55 AM
