Old Jan 05, 2014, 12:49 AM
elkski's Avatar
United States, UT, Sandy
Joined May 2013
NE1 ever offset a wing servo to cancel peg mass?
I can't be the first to think of this. But if you have a 3-4 g t blade why not mount that top drive wing servo closer to the root to help with lateral balance?.
And as a followup ? Do any TX's let you use a 3 pt curve to program servo travel?
elkski is offline Find More Posts by elkski
Old Jan 05, 2014, 12:54 AM
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
I did it with my Neos.
davidjensen is online now Find More Posts by davidjensen
Old Jan 05, 2014, 12:59 AM
It's a mere flesh wound!
Buddy Roos's Avatar
Woodstock,Ga.
Joined Jun 2004
IIRC...Oleg built one of his Taboos with one of the servos closer to the root of the wing a few years back. It's really hard to come up with something that hasn't been tried before.
Buddy
Buddy Roos is offline Find More Posts by Buddy Roos
Old Jan 05, 2014, 01:01 AM
Hugh Blackburn
floquet's Avatar
Melbourne, Australia
Joined Jun 2005
Bob McGowan did this with an Absalut back around 2005.
Hugh
floquet is offline Find More Posts by floquet
Old Jan 05, 2014, 01:03 AM
elkski's Avatar
Joined May 2013
It just seems like it would be standard especially when using the new heavier t blades?
Old Jan 05, 2014, 01:31 AM
United States, CA, Tehachapi
Joined Jun 2011
It certainly has been done and is much better than adding lead to the opposite wing tip. I'm of the philosophy that 4g is way too much weight for a peg install. My blades are probably around 1-1.5g installed. I use straight blades, not T blades or gull wings, for that very reason. To each their own, though.
Many people paint stripes only on the non-peg side of the wing to balance it out. There are other ways of doing it I'm sure. Or you could just use aileron trims to keep it flying straight. GT did an analysis that concluded that the extra drag from the aileron trim had less effect than the extra weight used to balance the wing.
bwill6 is offline Find More Posts by bwill6
Old Jan 05, 2014, 04:02 PM
G_T
Joined Apr 2009
A T-blade can be down to about 1.4g. A straight blade can be down to about 0.8g without getting too extreme. Many are two or even three times this weight. That is seriously way too much weight to be putting on the wing tips! All the work we do to increase launch height, and then just throw it away with a blade and even in some cases with balance weight on the opposite wing tip! Not ideal, IMHO.
Dr. Drela, many years ago, showed how to easily make a throwing blade that is under a gram. They are comfortable, efficient, and more than strong enough.
A T-blade is harder to make light but it can be done. 1.4g is the lightest I'd achieved, by cutting down one of Gavin's old blades reducing all the mass that wasn't needed.
Install in both cases should be a couple tenths of a gram. A straight blade needs more reinforcing around it. A T-blade needs more epoxy (filled, lightened, but still structural) to glue it in. I consider that part about break even.
People are routinely doing the equivalent of throwing an extra penny on the throwing blade side of the wing. Is it any wonder they encounter trim issues?
Gerald
G_T is online now Find More Posts by G_T
Old Jan 05, 2014, 04:40 PM
United States, NY, Buffalo
Joined May 2013
So that begs the question: how light is light enough without compensation?
Even if I had a 1g throwing peg, wouldn't that still lead to trim issues?
DrewV is online now Find More Posts by DrewV
Old Jan 05, 2014, 05:32 PM
Joined Jun 2011
I've never noticed a need to trim for a ~1g blade.
Old Jan 05, 2014, 05:35 PM
G_T
Joined Apr 2009
Given the state of production of wings, it is more likely you'll have trim issues from slight warpage of the wings or the flaperons. In any event, 1g extra mass at a wing tip of a 270g model only moves the CG a tiny bit laterally. The wings have great leverage - the trim will be almost invisibly small.
Ideal of course is to have no imbalance and light wing tips. Having a light throwing blade, and moving the servos in the wings a little, is one way to achieve this. From when I've investigated it, generally adding weight to the light wing tip is not a good approach. It does more damage to performance overall than trimming would do. The sink rate increases more from the added weight than the increase which would be caused by the extra drag from slight trim.
There can be exceptions when the imbalance is sufficiently severe - though at that point one is pretty much screwed anyway. Then I'd suggest seriously offsetting the servos.
Alternatively, one could design wings specifically for blade vs non-blade side. Nobody is doing this and I don't think the required work is worth the payoff.
When looking at trim issues with DLGs, people look at the weight of the throwing blade. But they neglect to look at the drag of that blade. The drag attempts to yaw the plane towards the blade. A tiny bit of rudder or slight offset of the vertical tail, could compensate. On the last plane I built (almost finished) the vertical tail is offset towards the non-throwing blade wing. So its drag is offset from the centerline of the plane. This should help compensate the drag of the throwing blade.
If one doesn't compensate the drag, then (1) the plane wants to yaw (2) one uses a tiny bit of rudder to compensate, so (3) the plane now flies slightly sideways due to the lateral force generated by the rudder.
It is best to use light, low drag throwing blades. Not thick chunky heavy ones.
FWIW, blisters or calluses on fingers are a function of the trailing edge shape of the blade (look up Drela's design for a good suggested shape) and even more a function of how the blade is held and released. But that would be the subject for a different article.
Gerald
Old Jan 05, 2014, 11:04 PM
Tut, Tut...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
Hey, Bill Watson did a DLG with an asymmetric wing several years ago.
Tom Watson
No relation
tewatson is online now Find More Posts by tewatson
Old Jan 06, 2014, 11:14 PM
Buddy Roos's Avatar
Woodstock,Ga.
Joined Jun 2004
Tom Watson
No relation
Do you mean this one:
Buddy
Old Jan 07, 2014, 11:02 AM
elkski's Avatar
Joined May 2013
What a waste of time! what a useless attempt at improving anything! that's not an airplane!
That guy could have better spent his time refinishing his wood deck!
My attempt at sarcasm and imitation.
But , really moving the CG away from the arm is a concept worthy of exploration to improve the engergy that can be imparted to a DLG
Old Jan 07, 2014, 11:57 AM
G_T
Joined Apr 2009
More pilots are power limited than speed limited. Hence the desire for higher aspect ratio lighter DLGs. Therefore moving the mass farther out won't help much if at all.
Gerald
Old Jan 07, 2014, 02:11 PM
2013 US F3K Team Manager(ret)
Newbury Park, CA
Joined May 2005
Buddy
That was Breck Baldwin's version of an asymmetric DLG.
It is much more extreme than Bill's.
You can check it all out on this thread: Asymmetric DLG design...
Here is Bill's: (Photo by Chris Adams)
dlgdude is online now Find More Posts by dlgdude
Sold Old Futaba FP S48 Servos and Mounts, Offset pin G Plug alexhallmalta Aircraft - General - Radio Equipment (FS/W) 3 Dec 31, 2014 08:06 PM
For Sale SWB Double Offset Servo Arm, 4", JR baumerm Aircraft - General - Miscellaneous (FS/W) 0 Nov 29, 2013 02:55 AM
Discussion Throwing peg offset Bad scientist Hand Launch 14 Jul 08, 2010 03:06 AM
Discussion retractable launch peg ne1? DrFragnasty Hand Launch 10 Dec 29, 2009 01:03 PM
Discussion offset aileron wing servo pinball64 Foamies (Kits) 2 Jul 26, 2006 11:24 PM
