Old Dec 16, 2012, 03:09 AM
Joined Dec 2008
F4 after burner
Well folks I was unsatisfied with the stock plastic after burner cone on my fms f4 . So I cut it off ,removed the plastic turkey feathers and sanded the trailing edge to a fine edge instead of the stock square edge .Then using some stainless steel .005 sheet , got the basic shape cut out preburned with a propane torch and this is the end result .. Also I changed the thrust angle downward to prevent ballooning on acceleration ala Gdimonte mod ..
pencon is offline Find More Posts by pencon
Old Dec 16, 2012, 03:47 AM
Joined Dec 2008
another shot
Old Dec 16, 2012, 04:07 AM
Joined Dec 2008
This is practise for my Eflite f4 when I build it . On the next cone I'll put a band of black stainless around the foam before gluing on the tailfeathers .Stainless sheet colours up real nice with a torch .Any comments welcome ..
Old Dec 16, 2012, 07:28 AM
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Looks fantastic!
The color you were able to obtain with the torch is very realistic!
Hover or die is offline Find More Posts by Hover or die
Old Dec 16, 2012, 07:49 AM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
S-mokin!(in a Jim Carey accent)
Stupot46 is offline Find More Posts by Stupot46
Old Dec 16, 2012, 10:59 AM
So many planes, So little time
Xflyfun's Avatar
United States, OR, North Plains
Joined Jul 2010
Very nice!!
I'm going to post some pictures of the real deal..
This is the f-4 that's at the Evergreen Air Museum...Oregon!!
This is for all the f-4 guys who want to do nice mods like Pencon
Name: Turkey feather 1.jpg
Description: Name: turkey feather inside.jpg
Description:
Name: turkey feathers.jpg
Description: Name: Evergreen air f-4.jpg
Description:
Hey Pencon did you use rubber cement to attach the S S to the foam?
I like your Idea, I'd rather burn some metal before I tried to paint the foam..
P.S. Ivan here's the pictures I told you I'd send
Xflyfun is offline Find More Posts by Xflyfun
Old Dec 16, 2012, 11:41 AM
Joined Dec 2008
Xflfun , yes 3m77 works great for attaching sheet metal to foam , both wings and the underside of the tail area are covered with .005 aluminum sheet as well . I painted the cone black before applying the stainless but the only paint I had was attacking the foam so a barrier of 3m 77 solved the problem .
Old Dec 17, 2012, 05:57 PM
Joined Dec 2008
Well , I liked the result on the stainless turkey feathers so I decided to peel off the aluminum from the underside of the tail and go stainless there too
Old Dec 17, 2012, 06:46 PM
EDF Jet Jam 2015 , May 28-31
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Nicely done!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Dec 19, 2012, 02:43 PM
Joined Dec 2008
Thanks Kevin , it's winter , I have too much time on my hands
Old Dec 20, 2012, 07:02 PM
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
Nice metal work!! I will look great on the Eflite F-4 also,
Here is what I did on my Starmax with my custom made nose and corrected angle tail. The light’s also show up well during the day. The 3rd flight before paint I found out the CG was a little far back and on a low speed turn it nosed up and thud. I was a minor fix and it’s ready again with paint.
Starmax F 4 90mm 3rd flight (3 min 28 sec)
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Dec 20, 2012, 07:24 PM
Joined Dec 2008
Good job on the paint , those Lights are sure bright , what brand ?
Old Dec 20, 2012, 07:33 PM
St. Peters MO.
Joined Nov 2007
I used Hobbypartz strip LED’s tied to a brushed ESC in the exhaust cones. The strips are set for 12V but they can be separated and use 5V servo power for other areas. Cheap and easy.
Old Dec 20, 2012, 07:37 PM
Kevin Cox's Avatar
Joined Jan 1997
I hope to experience that soon
Looks great Jeff!
Old Dec 20, 2012, 10:44 PM
Joined Dec 2008
If anybody's curious about weight gain Here's the stock plastic tail feathers which I removed at 3.3 grams or .115 of an oz . And the stainless piece equivalent size needed to make a cone at 4.2Grams or .145 of an oz . Plus I would need to cut some stainless away to make the individual strakes .So really there's no down side to the tailcones for weight .
For Sale After burner ring tiny_feet Aircraft - Electric - Jets (FS/W) 4 Nov 19, 2011 01:06 PM
Discussion RCLander new Lighting & After Burner system Tim Wan Foamy EDFs 0 Oct 18, 2009 12:45 AM
Discussion After burner on small EDF's.....look here stuart warne Foamy EDFs 7 May 26, 2007 05:20 PM
edf after burner rotccapt Electric Ducted Fan Jet Talk 17 Dec 05, 2005 04:17 AM
