Old Dec 05, 2012, 10:15 AM
Ahhgh! Not ANOTHER new plane!
Robert Stinson's Avatar
San Diego, CA
Joined Dec 2001
Trainer Switch Reassignment
Got a question about the Spektrum DX-8 Trainer Button:
I am entering the FPV arena of our hobby. Since our club regs require a visual spotter co-pilot, I have a buddy box trainer cable setup on my Spektrum DX-8. This way, if the video link fails, we can maintain control of the plane. Also, I use the slave Tx to allow others to experience goggle-FPV piloting while I retain control of the master Tx.
I'd like to reassign the trainer function to another switch that is non-momentary, so that I don't have to hold the button down constantly. My finger gets cramps! Also, the head tracking function appears to be activated through the trainer cable, so a non-momentary switch would be preferable.
I've read that others have physically replaced the button, but I wanted to do it through programming if possible, but I haven't had any success.
Any help would be appreciated. Thanks in advance!
Robert Stinson is offline Find More Posts by Robert Stinson
Old Dec 05, 2012, 10:22 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
You don't mention what radio you're using.
The DX10t, DX18, and DX18QQ allow you to select any switch for trainer.
I do a lot of training for our club, and I always use my DX18 for it. I use switch A (Gear) with Master Override enabled. This takes care of not having to hold the switch in. As soon as I move the controls, I regain it until I cycle A again.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Dec 05, 2012, 10:29 AM
San Diego, CA
Joined Dec 2001
Dx-8
Old Dec 05, 2012, 10:35 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
DX8 trainer switch is not mappable.
The only way to do it would be to put a toggle in there, and then you'd have to manually flip it to regain control. And it would mess up binding a bit too.
Andy
Site Sponsor
Old Dec 05, 2012, 12:18 PM
San Diego, CA
Joined Dec 2001
Andy, thanks for the quick response. A follow up question, what would the binding problem be? If the toggle was in, say, position zero, that would be "bind or trainer, off", and position one would be "on". Turning on the tx at zero would be normal operation. Turning the tx on at "one" would be for binding until the process completed. Switching it to "one" while the tx is already on would activate the trainer function, and for me the head tracking function. Is that right, or am I missing an unintended consequence?
I'm not worried about the "dead man switch" for training recovery functionality, since I don't do that hardly at all.
And yeah, I know the warranty issue, but I bought my DX8 the first day it appeared at our store, so it's a veteran!
Old Dec 05, 2012, 05:54 PM
United States, CA, Camarillo
Joined Jul 2012
They sell mini switches that are Momentary ON in one direction, off in Neutral, and ON in the other direction.
http://www.ebay.com/itm/2-NEW-SINGLE...item48428be481
That would be what your asking for. You could wire it in place of the existing button to use it for both bind (Momentary), and locked ON for Trainer.
Barry2020 is offline Find More Posts by Barry2020
Old Dec 05, 2012, 08:36 PM
San Diego, CA
Joined Dec 2001
Oh, perfect.. Excellent, thanks Barry.
Old Dec 05, 2012, 08:38 PM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
You will still have the issue with the Bind Process if you forget the switch in the ON position.
freechip is online now Find More Posts by freechip
Old Dec 07, 2012, 12:33 AM
Joined Jul 2012
You could add a timer to disable the 'dead man switch' during boot up of your DX8 so as to prevent the transmitter from going into 'bind' mode.
Here's a timer switch. The listing shows a circuit driving a separate relay that could be connected to the dead man switch.
http://www.ebay.com/itm/1s-20h-Adjus...21035621509%26
Discussion How do I modify the trainer switch for Head tracking on Futaba TX? Kahnx FPV Talk 6 Aug 03, 2012 01:59 AM
Discussion Futaba 6J Trainer Switch Buschbarber Radios 0 Jul 19, 2012 07:41 PM
Whoops! Broken dx6i trainer/bind switch.. 3d astronaut Radios 8 Apr 15, 2012 04:23 PM
Discussion Anyway to get Futaba 7C to reassign sticks between channels (on a switch)? Jhondra FPV Talk 1 Sep 17, 2009 05:24 PM
reassigning switch function on 9303? cudaboy_71 Radios 0 Sep 09, 2005 08:07 PM
