Old Jan 20, 2012, 12:33 AM
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
New 120mm Panther @ Hobby People
What do you all think?
http://www.hobbypeople.net/index.php...s-struts.html#
tulz43 is offline Find More Posts by tulz43
Old Jan 20, 2012, 12:42 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
http://www.rcgroups.com/forums/showthread.php?t=1548844
http://www.jethangar.com/Aircraft/NT.../NTPanther.htm
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jan 20, 2012, 01:40 AM
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Thanks for the links.
Search function on here is garbage!
Old Jan 20, 2012, 12:28 PM
JetMang's Avatar
San Diego, California, United States
Joined Feb 2002
The airplane is an awesome flyer and is nicely built. Super stable with a huge speed range.
Chris
JetMang is offline Find More Posts by JetMang
Old Jan 20, 2012, 12:32 PM
Swat Team Member
P. Richards's Avatar
LV, NV
Joined Apr 2003
The speed control
Why not place the speed control behind the motor and fan? most of the
120mm fans have the ESC in the flow of air to keep it happy.
I will have to see how this works out...
P. Richards aka SwatTeam
P. Richards is offline Find More Posts by P. Richards
Old Jan 20, 2012, 01:10 PM
The fan man
Canada, ON, Lindsay
Joined Jan 2012
Very expensive , i,m sure if you shop around you can find same size for cheaper .
arcdirect is offline Find More Posts by arcdirect
Old Jan 20, 2012, 01:11 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
good luck with that.
corsair nut is online now Find More Posts by corsair nut
Old Jan 20, 2012, 02:04 PM
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Man... some people just don't get it. It's a large 120mm jet with full retracts. How is that expensive?? Just because you might not be able to afford it doesn't make it expensive.
Old Jan 20, 2012, 07:15 PM
JetMang's Avatar
Joined Feb 2002
I will have to see how this works out with the first victims, I mean customers...
Victims, really? We have tested both in and out of the duct with the ice 160 and have not had any issues either way. Does the esc run cooler in the duct? Yes. Will it catistrophically fail if outside the duct as you are implying? A resounding NO. So long as you have sufficient margin for the amps rating (which our system has), there should be no problems. Do I plan to put the esc partially exposed in the exhaust duct of mine? Sure, because running the esc cooler is always a good thing. but that doesnt mean that all of a sudden airplanes will be falling out of the sky if you don't.
Chris
Old Jan 20, 2012, 08:03 PM
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Chris,
The model size looks promising and practical. Are you going to add some dihedral to the wings? looks too flat to me. Nonetheless looks decent....leads me to ask, anyone want to buy primed ziroli/pst kit bashed panther from me??
strictlyscale is offline Find More Posts by strictlyscale
Old Jan 20, 2012, 08:06 PM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
no but id gladly take it from you!
Originally Posted by strictlyscale View Post
Chris,
Old Jan 20, 2012, 08:11 PM
JetMang's Avatar
Joined Feb 2002
Yeah, the flat wing would be my only complaint...though, it doesn't bother me enough to modify the wing attachment to increase it (though, it will get a new paint job). There is a little dihedral, but far from enough. Actually pretty much every panther arf and a number of kits out there fall short. The full size airplane had 5 degrees dihedral in it.
Chris
Old Jan 20, 2012, 09:26 PM
FlyBoyTha1's Avatar
The Greater Bay Area
Joined Sep 2008
AWESOME R/C PANTHER. 72IN WINGSPAN Kits Worth $479.00
RETRACTABLE LANDING GEAR & LEG SET FOR AWESOME R/C PANTHER Retract Worth: $430.00
$909 bucks i guess the custom still eats the shipping charges
Hobby people price $1,399.99 where's the savings
FlyBoyTha1 is offline Find More Posts by FlyBoyTha1
Old Jan 20, 2012, 09:29 PM
kevin's Avatar
ohio
Joined Aug 1999
no, but how about the learjet
Chris,
kevin is offline Find More Posts by kevin
Latest blog entry: Video of my HK Cobra
Old Jan 20, 2012, 09:31 PM
Die Meistertinkerer
Frankensteen's Avatar
United States, GA, Columbus
Joined Jan 2006
I'm seriously considering this Panther-how robust are the retracts and mounts I wonder?
Frankensteen is offline Find More Posts by Frankensteen
Sold ASM 120MM 72" Panther Ready To Fly Asking $1500 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 1 Jun 16, 2011 02:23 PM
For Sale Only $85!!! - $100 new hobby people / hobby shack gift card!! KellenR Aircraft - General - Miscellaneous (FS/W) 2 May 15, 2011 04:28 PM
